E36 (1991 - 1999)
Old 10-31-2007, 09:49 PM
djnv325i djnv325i is offline
Mein Auto: 325i 4d
Exclamation Oil leaking on plugs HELP
Hey everyone I just change my valve cover gasket due to oil on the plugs. The car was running really bad, I thought after changing the gasket it would run better but the car is still running bad, misfiring every time I get on the gas! I checked the plugs today and I still have oil on them so I got some high temp RTV to try to seal the valves up good but itís still misfiring just not as bad? And I know the coil packs are good because every time I clean the plugs and put them back in it runs fine. Dose any one knows what could be wrong?
"Float Like A Cadillac Sting Like A Bimmer "
BMW 325I 4D JLAudio 13W7/ 7" touch screen/ 18% tint back windows / Clear coner lights / Black E46 style grill
Old 10-31-2007, 10:10 PM
slavka slavka is offline
Mein Auto: 1999 BMW 328is
Check the tube that your plugs going in to make sure there is no cracks. Or if its not rounded on the end that will cause the seal not to sit properly so it will leak.
Old 11-01-2007, 09:13 PM
Mein Auto: 325i 4d
I checked everything seamed to be ok? any thing eles to look at?
Old 11-01-2007, 10:29 PM
Andycapps's Avatar
Andycapps Andycapps is offline
Mein Auto: 94 BMW 325is
You might have leaky valve stem seals or maybe your rings are worn enough to allow excessive amounts of oil to come from the bottom end. Just a thought.
Old 11-01-2007, 11:32 PM
PhilipWOT's Avatar
PhilipWOT PhilipWOT is offline
Turn Burglar
Location: Atl: Come for the pollution, stay for the traffic
Mein Auto: Red Assless Chaps
ooooooh
Knock on wood!
Old 11-04-2007, 08:24 AM
bimmeraddiction bimmeraddiction is offline
Mein Auto: 740IL
HI buddy
I think your engine get some problems on ignition system . If you want to know exactly what the problem is , you have to check step by step . The oil sucks in to the end of the spark plugs are not relating to the misfiring engine .
First of all , you must start your engine up , and disconect the ignition coil one by one , if the enigne RPM drop at the cylinder that you are diconect , that means the spark plug, the ignition coil and the fuel injector are ok . This action to help you know which cylinder cause the engine misfire . for example , you find out the cylinder number one , then you switch over the ignition coil between the cylinder 1 and 2 , then restart the engine up , disconect the ignition coil od the cylinder 2 , if the engine drops the RPM , now you can expect that ignition coil is not good .
Second thing , if you could not find out any problem on your ignition system , yo have to do the compression check for each cylinder .
Hope those thing help you to solve your problems .
