Old 11-07-2007, 02:03 PM
ebelony ebelony is offline
Mein Auto: 2005 BMW 745i
Hidden Navigation Menu Options
Has anyone ever came across a hidden set of navigation options (view only) while in the Navigation Menu? I would like to know if I could program or change some of these options?
Follow these steps to get the menu:
1) INSERT KEY IN IGNINTION TO POSITION 1 (do not start engine)
2) GOTO NAVIGATION MENU
3) SELECT ANY DESTINATION IN ADDRESS BOOK UNTIL YOU SEE A MAP
4) WHILE IN THE MAP SCREEN, PRESS iDRIVE TO SHOW MENU OPTIONS
5) SELECT THE SPLIT SCREEN ICON WHICH PUTS THE NAVIGATION MAP ON THE RIGHT SIDE (very important. It will not work unless map is on the RIGHT SIDE)
6) NAVIGATE THE iDRIVE OVER THE LITTLE ORANGE SPEAKER (LOCATED BETWEEN THE "MUTE ROUTE GUIDE" AND "AVOID TRAFFIC" ICONS.
7) PRESS AND HOLD iDRIVE FOR 10 SECONDS THEN RELEASE.
A menu will appear with Navigation, GPS, etc... Does anyone know what else can be done with these options?
