Old 11-08-2007, 09:34 AM
///M Rakete's Avatar
///M Rakete ///M Rakete is offline
Rocket Scientist
Mein Auto: 2010 M3 and 2011 135i
What do the Cornering Lights on the LCI/2008 Cars Do?
And how well do they do it? I understand that flash-to-pass is now handled by the Bi-Xenons and that the Cornering Lights replaced them.
Thanks.
2010 BMW M3 Coupe M-DCT w/Tech-EDC, BMW M Performance Exhaust, BPM Stage I Tune, Space Gray / Fox Red Extended, and a Trunk Monkey known as "Der Stig",
plus the daily driver...
2011 BMW 135i M Sport DCT, w/BMW Performance Power Kit, Exhaust, and Brake Rotors, Space Gray / Coral Red, known as "Stiggie" with an outlaw F20 "M135i" badge.
Old 11-08-2007, 10:50 PM
545iSMG 545iSMG is offline
Mein Auto: 2008 550i Sport w/SAT
Cornering lights work pretty well but only at slow speeds. They're tied to the steering wheel angle and they're tied to the turn signals so they turn themselves on and off at the proper times.
As far as lighting the corners, they work very well. Overall, the headlights are improved from the pre-LCI cars...
Rudy
2008 Alpine White 550i w/Sport Package, Sport Automatic Transmission, Ventilated Comfort Seats in Beige Nasca Leather, Dark Poplar Wood, NAV, HUD, Active Steering, Comfort Access, Night Vision, Lane Deviation Warning, Active Cruise Control, Cold-Weather Package, Heated Rear Seats, Folding Rear Seats, Rear Sunshades, Rear Air Bags, Logic 7, HD Radio, Sirius Satellite Radio, iPod/USB Adapter.
Build completed June 4, 2007
2004 Alpine White 545i SMG -- gone but not forgotten!
Old 11-08-2007, 11:50 PM
BMW_tech's Avatar
BMW_tech BMW_tech is offline
Send a message via Yahoo to BMW_tech
Mein Auto: rickshaw
Thanks.
The cornering light is integrated in the headlight where the previous
high beam lamp was located. The light beam is reflected to the
side by the special shape of the deflector and the position of the
H3 bulb. The cornering light cannot be ordered as a separate
option as it is an added function of Adaptive Headlights (SA 524)
The special arrangement of the mirror surface in the reflector and
the special shape of the lens deflect the light beams to the side
while preventing forward dazzle.
The cornering lights illuminate when the respective turn signal is
operated and or the steering angle sensor indicates a turn below
40mph.
The angle of the steering wheel to activate the cornering light differs
depending on the type of steering system used (power steering
or active steering), steering gear and steering gear ratio. The
steering wheel lock to activate the cornering light when the vehicle
is stationary is between approximately 40 and 75 depending on
the type of steering.
Flash to pass does not affect the cornering light nor does the hazard
function activate it.
Note: Both cornering lights come on when the reverse gear
is selected to help illuminate the way.
Switch-on conditions for the cornering lights
The corresponding cornering lights will illuminate depending on
the following criteria:
The selection of the turn signal below 65kph/40mph
Steering angle input while driving below 65kph/40mph
With vehicle stationary and engine running a steering angle of
40 to 70, depending on the steering system
With reverse gear engaged both cornering light will illuminate
Switch-off conditions for the cornering lights
The cornering lights switches off in the following conditions:
Adaptive headlight off
Direction indicator off
Directional constantly on above 40kph/25mph
Steering angle is reduced ( by 5-10 after switch-on condition
with vehicle stationary)
Steering angle increased while driving above 70kph/43mph
While drifting (Steering lock and yaw rate in opposite directions)
While turning at a traffic light there is a 4 sec time out
Headlight temperature too high (headlight protection)
Reverse gear disengaged
Advantages of the Cornering Light
The cornering light makes it possible to recognize people or traffic situations earlier in the
turning area.Pedestrians are recognized before the vehicle actually turns.This function represents a considerable increase in safety for thedriver and other road users.
The special arrangement of the mirror surface in the reflector and the special shape of
the lens deflect the light beams to the side while preventing forward dazzle.
YOUR SECRET ADMIRER
Old 11-09-2007, 12:34 AM
Rocket Scientist
Thanks, couldn't have hoped for a more complete technical reply. I've seen your other posts, glad to have your contributions.
Old 11-09-2007, 12:45 AM
BMW_tech's Avatar
Mein Auto: rickshaw
I just hope that nobody ticks me off and id be forced to defend myself and I have got such a New Yorker attitude and tend to lose it.Last time it was a BMW parts guy accusing us techs of throwing parts at every vehicles.If this was true,why do we have to ask PuMA for authorizations??? And before we even ask we would need thorough diagnostics and only as a last resort we have to contact PuMA.For now I shall continue to educate the masses because of your passion for these vehicles that I also possess.Lets face it,the more you know the less we have to explain what work was or has to be done and "together" we can correct a problem on a timely manner.But thats just me!
YOUR SECRET ADMIRER
Old 11-09-2007, 07:58 AM
stream's Avatar
stream stream is offline
Mein Auto: '05 545i
Originally Posted by BMW_tech View Post
The cornering light is integrated in the headlight where the previous high beam lamp was located.
As you're aware, on pre-LCI E60s, there is not separate high beam on cars with bi-xenon headlights, and the second lamp location is used for flash to pass and DRLs.
How is flash to pass accomplished on LCI cars with bi-xenons?
2005 545i - sold
Old 11-09-2007, 08:36 AM
LCI cars simply flash the bi-xenons instead of having a dedicated lamp...
Rudy
Old 11-09-2007, 11:33 AM
Rocket Scientist
Yes, apparently the warm up (full brightness) time is much faster (a few tenths of a second rather then a full second) compared to Xenons of a few years ago. So using them to flash is acceptable. Having seen this myself though.
Old 11-09-2007, 11:35 AM
photoz photoz is offline
a guy in a car
Mein Auto: 02 330Cic
can someone explain the LCI moniker?
been trying to figure that out for awhile, I realize its later model 5ers, but what does it signify?
Old 11-09-2007, 12:39 PM
stream's Avatar
Mein Auto: '05 545i
Life Cycle Impulse, I believe. BMW speak for model mid-life refresh/facelift.
2005 545i - sold
Old 11-12-2007, 05:26 PM
MN2828 MN2828 is offline
Mein Auto: BMW 535i
So what cars are the LCI cars?
On my 08, the cornering lamp is the inner angel eye on each side. it comes on at slow speeds when I turn a corner or pull into a driveway or parking space. I know because I see the reflection from the side of my office building when I pull in every morning.
Old 11-12-2007, 07:32 PM
stream's Avatar
Mein Auto: '05 545i
On the E60, LCI started with the MY08 cars.
2005 545i - sold
Old 08-27-2012, 04:18 PM
twindon98 twindon98 is offline
Mein Auto: 2008 535xi Navi
can you make the cornering light LED?
Old 08-27-2012, 05:22 PM
Ramsey Barnette Ramsey Barnette is offline
Mein Auto: 2007 BMW 550i
You have to get a really big spoiler before the LED lights can be added. Use a big hammer to put it on. Then get the Tornado, +100HP and +35MPG!
Old 08-28-2012, 10:45 AM
NoQuarter's Avatar
NoQuarter NoQuarter is offline
Just to add a bit more..
Not so much the lamp is flashed to a higher beam or anything like. A motorized shade is momentarily lifted up to allow the beam to project further/higher.
I think this is also why some people feel their beams are adjusted too low because there is a definite line where the light is and where it stops. "Normal" low beams just sort of fade from a bright spot to not so bright.
Edit: Just to clarify my own thought some more:
What I just described is the difference between high beam and low beam. Flash to pass using the xenons is a programming option because moving the shade is a bit slower than flashing the inner lamp.
Old 01-10-2015, 05:13 PM
JEL395 JEL395 is offline
Mein Auto: E39, E90, E34
Cornering Lights / Confirming if they are working ?
[FONT="Arial"]
Hats off to Secret Admirer. Terrific description and explanation on how they should function? My question is IF all the bulbs ( H3 brand new ) are in place and I still don't have lighting under the conditions you described in either side. Do you think it may be the control unit ? I have a 2009 E90. Also appears there is a access panel forward in the both front wheel wells. Could this be the access to change the contol module? Seems kind of strange both of the units would be out on a part only illuminated rarely? Also Penske Parts show this module is a $ 224.00 part for one. Your insights and opinion are appreciated. Miffed in San Carlos.
