Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Car Audio & Electronics Forum
Hi-Fi upgrades, XM Radio, Sirius, Bluetooth, and Radar Detector discussions here!
Old 11-12-2007, 06:32 AM
max.lamers max.lamers is offline
Mein Auto: 2003 325i
e46 325i HU turns itself off after 20 min
Hi,
I recently purchased a used 2003 325i and I think someone has wired the HU and ipod interface incorrectly. This is the factory HU and BMW ipod adapter. There are 2 main symptoms.
1. HU turns itself off after 20 min while driving. I can turn it right back on and it picks up where it left off. It doesn't matter which mode is selected; it turns off every time.
2. The HU does not turn off with the ignition.
Does someone have a proper wiring diagram or ipod adapter install instructions that I can reference?
Old 11-12-2007, 07:25 AM
Technic's Avatar
Technic Technic is offline
Test... 1, 2 ,3
Mein Auto: 2012 M3 - 2010 CC
Originally Posted by max.lamers View Post
Hi,
It seems to me that the ACC line into that OEM HU has been replaced by a constant 12V line... that will explain the 20 minute shut off (that's a feature and not a fault, you can play the radio without a key for those 20 minutes), and why the HU does not turn off with ignition: http://www.bimmerboard.com/forums/posts/26961
I would pay attention to the way pin 5, the ACC line in your OEM main radio harness is connected to the OEM iPod adapter.
Old 11-30-2007, 08:17 AM
It was a fuse
Turns out that a fuse was blown that recognized whether the car had the key in the ignition. It was working like the car was off at all times.
Old 03-25-2010, 12:31 PM
Icemanleo Icemanleo is offline
Mein Auto: 2004 325i
What fuse # would that be?
edit: N/M is fuse 7.... if fuse 7 is out the radio wil be turning off every 20 min. and it won't shut off when you turn the car off
