Old 11-12-2007, 10:27 AM
bmwhsu bmwhsu is offline
Mein Auto: 1998 528i
socket size for oil filter cap
Hello-
I'm attempting my first oil change. I was able to drain the oil, but for the life of me cannot take the plastic oil filter cap off.
I tried the filter wrench and a plumber wrench but it won't budge.
What is the socket size?
Don't worry, since my vehicle has 120k on it, I've got a new oil filter cap coming.
thanks!
Old 11-12-2007, 10:33 AM
Never mind.
Repeat after me. The search function is my friend.
I need a 36mm.
Thx,
Old 11-12-2007, 10:49 AM
la528it's Avatar
la528it la528it is offline
Mein Auto: 2000 528it
ADvice: open it VERY slowly, and when you are done; tichten the cap using your hand on the socket, when you can;t go anymore, give only the SLIGHTEST tug on the socket with your ratchet.
Old 11-12-2007, 11:44 AM
Michael Star's Avatar
Michael Star Michael Star is offline
Medium Pimpin
Mein Auto: 540i/6
Ya, sucks when you have to buy a $4 socket.
Old 11-12-2007, 11:45 AM
chivas's Avatar
chivas chivas is offline
You Lick It, You Own It
Send a message via ICQ to chivas Send a message via AIM to chivas
Mein Auto: 98 540i/6
open while holding the canister. if not, you're going to break the two rubber pads very easily.
slow and easy... it's about torque and not hp.
americandan.com
It takes a lot of work to be lazy.
Beau6183 Beau6183 is offline
Send a message via MSN to Beau6183
Mein Auto: 2007 335xi 6-spd, Dinan 2
And for God's sake LUBE UP THE NEW O-RING WITH NEW OIL!
When I first got my 5er, I took it to crappy Lube for a change... not only did they NOT replace my o-ring, they also didn't lube it back up when rescrewing the cap back in. It wore the o-ring too thin and caused my housing to leak oil REALLY all over my engine compartment.
(they also stripped my oil drain plug, but that's another story -- still waiting for a reimbursement check from them for a new pan, gasket and plug).
Old 11-12-2007, 01:31 PM
ross1's Avatar
ross1 ross1 is offline
Mein Auto: Pretty much had 'em all
36 mm This is a fairly common hub nut size so you may find an inexpensive one made from sheet steel rather than a broached socket.
It doesn't need to be very tight.
Take my advice, I'm not using it.
Old 11-12-2007, 04:36 PM
Thanks for the advise.
I picked up a 36 mm socket from Sears. Had it done in 5 minutes.
I did have a hard time getting the cap off and on. I'm glad I made the socket purchse. Otherwise, I probably would've chewed the plastic oil cap with the plumber'w wrench.
The cap was hard to put back on because the Mann Oil filter 0-ring gasket was slightly larger than original. I doubt I can hand tighten it. I had to use some force.
Next big project. the cooling system.
Old 11-12-2007, 05:04 PM
Ågent99's Avatar
Ågent99 Ågent99 is offline
Moderator, 5-Series
Mein Auto: ...a lot of people crazy.
Ah, your fun is only beginning....
2001 530i/5 (E39), Topaz Blue/Stone Green/Black (sold) *very rare interior/exterior color combo*
2005 545i/SMG (E60), ED Order, Titanium Grey/Grey (lease over)
2014 335i/Auto (F30), Mineral Grey/Black (lease over)
2017 340i/Auto (F30), ED Order, Estoril Blue/Black
Old 11-12-2007, 06:28 PM
dvsgene dvsgene is offline
Search, Read, THEN Ask
Mein Auto: 98 540i M62 3.15
+1 Yes, hold the canister while loosening the cap, those two silly rubber insulated bolts are a terrible design and easily torn apart if you do not hold the canister in place....
Old 11-12-2007, 08:12 PM
cn90 cn90 is offline
Welcome to the bimmer fun!
The P.O. (or Jiffy Lube) torqued my 36-mm cap so much that when I removed it, it cracked. I did not notice the crack until I start the engine and check for oil leak before closing the hood, sure enough, lots of oil came through the crack!!!!
I am glad you got a new O.F. Plastic Cap: for $27.00 it is peace of mind!
After 10y/100miles, do not trust any plastic. Plastic dies with time and heat.
Old 11-13-2007, 05:32 AM
rph74 rph74 is offline
Send a message via AIM to rph74
Mein Auto: 98 540ia Sport
FYI for others in a pinch you can use the wrench that comes in the trunk tool box, or better yet, use a traditional oil filter strap wrench at the bottom of the cap.
99 Toyota Land Cruiser, 08 Dodge Ram Quad cab 4wd 6-speed manual, 01 BMW X5 4.4 All high mileage, but paid for!
An armed society is a polite society
Old 11-13-2007, 05:41 AM
yep, first time I tried to get it off, I used a plumbers chain type wrench on the wider part of the cap. much more surface area and perhaps less likely to crack
