E36 (1991 - 1999)
Old 11-15-2007, 05:25 AM
im im is offline
Mein Auto: bmw325i /318ic
help e36 oil leak: under crankshaft pulley
car: 1996 318 convert. , manual 5 speed, about 125,000 miles
symptom: just started to notice a 1 drop per day leak, very clean oil, traced to behind crank shaft pulley, i used degreaser all around the engine (top/sides/bottom) and cleaned it very well in order to isolate the area.
pin point location: seems to be located behind the main pulley...crank shaft pulley...the one in the center of the engine towards the bottom.
question #1: could this be the main crankshaft seal? or another seal?
question #2: is this a do it yourself?-i work on most items in my cars and motorcycles
question #3: has some one paid to have this done? if so how $$$
thank you.
Old 11-15-2007, 05:34 AM
Pirate_copy's Avatar
Pirate_copy Pirate_copy is offline
Still here
Send a message via MSN to Pirate_copy
Mein Auto: M3
Hi
I had the same on my 328i a few months back - http://www.bimmerfest.com/forums/sho...d.php?t=188324
I had to replace the hub behind the pulley as well as the seal - (6) - http://www.realoem.com/bmw/showparts...35&hg=11&fg=18
Not a fun job but wasn't massively difficult. Cost about $100 in parts i guess
Your maybe your sprocket or seal - http://www.realoem.com/bmw/showparts...21&hg=11&fg=18
2001 Mini Cooper R50
Edirty6 for life
Old 11-15-2007, 05:40 AM
im im is offline
pirate , the pictures are "RIGHT ON EXACTLY"..did you do it yourself? how long did it take?
$100 for parts..is that in pounds? ..not fun usually translates to at least 4 hours to me.
Old 11-15-2007, 05:52 AM
Still here
Mein Auto: M3
I did it with my mechanic. Took him about 1-2 hours i guess.
Have you got a manual to help you?
$100 is in USD (50 for the hub from BMW)
Edirty6 for life
Old 11-15-2007, 05:53 AM
im im is offline
thank you
Old 04-03-2012, 05:50 AM
Greg19 Greg19 is offline
Mein Auto: 3 Series 1995 (E36) Coupe
Help...
Looks like I have a similar problem from the same location on my 316i 1995 Coupe.
A few drops of oil after swithing off the engine (& only when oil is hot) not a great problem but making a mess on my driveway!
Has anyone had this job done by a garage & can anyone give me an accurate idea of how long & how much the job might cost?
I understand that the Crankshaft Pulley Bolt is always replaced at the same time as the Seal.
Thanks in advance.
Old 04-03-2012, 01:51 PM
JoshuaG's Avatar
JoshuaG JoshuaG is offline
Natasha 95M3
Mein Auto: 95' E36 M3
What the hell are you swithing your engine for!?! That's just Nast dude seriously!
Originally Posted by kaos_325i View Post
Maybe I haven't been here long enough to realize the knowledge you have to share. But, from all I can tell you are just an over opinionated, rude, prick.
My .02
Old 04-03-2012, 04:46 PM
Apologies for the typo, I did of course mean switching.
Just joined the forum & was hoping for some serious comment/advice not much appreciating the smart ass reply but thanks anyway...
Old 04-03-2012, 05:46 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
well this *is* the e36 forum, so we do get a bit rammy. please do not be offended. it's just that some of the members here think that the guys from over on the other side of the pond tend to talk funny, even though it's still 'english'.
the same goes for canada. (and they're al weird anyway...)
and arkansas. (weirder than the canuks, i tell ya...)
but i digress.
to answer your queery, yes, it is most likely going to be from the front crank seal, and yes, the bolt for the crank does need to be replaced. you may wish to look into getting a proper diameter pin to hold the flywheel stationary while torquing down to spec. it's pretty hefty.
and welcome to the fest. looks like you used the search function.
now, since you have been welcomed all proper like, it is in the rules that new members post pics of their vehicle and buy us all chips.
seriously though, would like to see your car, and if possible, some engine pics. we don;t see too many of the 1.6 engine.
oh, and as for how to keep from getting oil on the driveway?? park in the grass??
df
Old 04-03-2012, 08:59 PM
veteran011's Avatar
veteran011 veteran011 is offline
WARNING: Has Dumb Ideas
Mein Auto: 97 328is
i see what you did there...
dab of oppo anyone?
Project List:
Replace coolant temp sensor
Replace starter
Brake and Power Steering Fluid Flush
Front Control Arms, Bushings, and Tie Rods
Replace Passenger Lock Actuator
Reglue Peeling Hedliner
Swirl removal
Old 04-04-2012, 03:39 PM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
from the front crank seal, and yes, the bolt for the frank does need to be replaced
now, since you have been welcomed all proper like, it is in the fules that new members post pics of their vehicle and buy us all chips.
ISWYDT
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic SOLD 3/2016
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 04-05-2012, 04:47 AM
Originally Posted by petriej View Post
ISWYDT
what???...whaddidoo??
see what happens when you try to tyoe too fast...
df
Old 04-05-2012, 05:26 AM
Thanks all for your really helpfull & useful comments...
Old 04-05-2012, 06:22 AM
veteran011's Avatar
Mein Auto: 97 328is
If you actually read he DID answer your question (albeit in a hefty sarcasm sandwich).
As to costs for having a shop do it there are "estimates" earlier in the thread... Read it.
dab of oppo anyone?
Project List:
Replace starter
Swirl removal
Old 04-05-2012, 07:18 AM
...Should have stuck with my Saab & The Saabsceneforum. Admin, please feel free to delete my account.
Old 04-05-2012, 09:00 AM
petriej's Avatar
Five posts! Is that a record?
GGC BMW CCA #443004
Join the BMW CCA!
Old 04-05-2012, 09:29 AM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
Pity that Saab's have gone the way of the Dodo..
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 04-05-2012, 10:16 AM
JoshuaG's Avatar
Natasha 95M3
I think he cried... :.( poor guy. I waited for the relevant information and everything. Must be a "sob" thing.
My .02
Old 04-06-2012, 04:22 PM
well, i thought i was being helpful.....
df
Old 04-06-2012, 05:48 PM
Drivinfaster, you were very helpful thank you.
Old 04-07-2012, 11:06 AM
hornhospital's Avatar
D'oh, You Kids!
C'mon, guys, cut the guy some slack. He SEARCHED, which most noobs don't do, and outside the typo, he posted an understandable question (sort of).
Greg, stick it out. Credit the attitude you got from us to your being new here, and the replies as a welcoming initiation. Very few new members to the E36 forum get by without a few battle scars at first. Us old timers get them occasionally, too. No harm meant, I assure you.
Quotes to live by:
Old 04-08-2012, 03:16 PM
Thanks for the kind words Hornhospital...
Thought I'd been very clear with my request for information on this subject....
Had hoped for some feedback from members who had this problem fixed by a garage (workshop) & prefereably in the UK.
I have been quoted around 30 for the parts, Oil Seal & Crankshaft Pulley Bolt & around 320 for labour (I'm told 3 hours) 350 in all.
Just wanted to ask how this compared to other owners with the same problem.
Just didn't see what justified the stupid & ignorant reply from JoshuaG.
Have a better sense of humour than the next guy but maybe something got lost in translation.
Thanks to all who have made positive replies.
