E90/E91/E92/E93 (2006 - 2013)
Old 11-17-2007, 08:50 PM
BMW_tech's Avatar
BMW_tech BMW_tech is offline
Send a message via Yahoo to BMW_tech
Mein Auto: rickshaw
More effort needed to press the brake pedal to start?
Anyone experiencing increased effort on the brake pedal to start your engine ??
Although the brake pedal can be pressed,it can be quite noticeable on the brake pedal feel.This situation can occur if the vehicle sits for extended periods of time and vehicles E9x up to 9/07 are affected according to BMWNA database.Only vehicles exhibiting this situation should visit their dealerships.It is not a problem or a recall but rather case by case basis.The vacuum check valve, fitted at the brake booster, may leak due to component tolerances within the valve assembly.
YOUR SECRET ADMIRER
Old 11-17-2007, 10:25 PM
elguevon elguevon is offline
Mein Auto: '07 335i Coupe
Yeup....basically its a stiff brake pedal. It always starts when I press on it, but nonetheless I would expect the pedal to be soft and not have to exhibit the force equivalent of a quick stop. It hasn't been a show stopper but good to know this is a recognized issue.
I guess I'll have it looked at when I need to bring the car in for an oil-change, but no need to go out of my way....yet.
My car was built 09/07...so basically the end of the '07 models.
'07 335i Coupe - Space Gray - Auto|Nav|Sport|Heated Seats|BT|PDC|Sirius|HD|6FL
'05 525i - Space Gray - Auto| Heated Seats|BT|Sirius (Retired)
Old 11-17-2007, 10:40 PM
ddtan ddtan is offline
Officially Welcomed to the 'Fest!
Mein Auto: 07 335i Sedan
Do you mean that when I first step on the brake pedal in the morning, that I find that it hardly depresses much, but as soon as the engine starts, then the brake pedal releases, and moves down to it's usual brake position? It is as if the power assist was off, and then came on.
I didn't know that was a problem, but my car does that.
ED 4-18-07: AW335i E90
Redelivered 6-15-07
Old 11-17-2007, 10:47 PM
BMW_tech's Avatar
Mein Auto: rickshaw
consider yourself aware.
Yes.
YOUR SECRET ADMIRER
Old 11-18-2007, 06:42 AM
Snareman's Avatar
Snareman Snareman is offline
Leave gun. Take Canoli.
Mein Auto: 335 Coupe, Grand Cherokee
Mine only seemes to do this sometimes, but I've never been able to (or really tried I guess) to correlate it with anything.
Old 11-18-2007, 08:04 AM
krash's Avatar
krash krash is offline
Mein Auto: 2013 335i Sport Sedan
I noticed this when the weather started to get colder. Sort of strange, but I am not really concerned about it.
2013 335i: Sport Line, Premium, Technology, DHP, HK, 8 Speed Sport w/Paddles, Heated Seats, PDC, Camera
Old 11-18-2007, 04:40 PM
bigslickak bigslickak is offline
Mein Auto: '11 E90 335d
Been noticing this as well on my June build 335i. Only started recently, don't know if it corresponds to the cooler weather (not that it's that cool here in California). It doesn't happen on every start either. This has corresponded to a "Service Engine Soon" light. I will be bringing the car in for that and will mention the stiff brake at starting as well.
Old 11-18-2007, 11:23 PM
BMW_tech's Avatar
Mein Auto: rickshaw
any driveability issues with your S.E.S. lamp?
YOUR SECRET ADMIRER
