E36 (1991 - 1999)
Old 11-26-2007, 07:54 AM
bobby_southward bobby_southward is offline
Mein Auto: Audi S3
Thumbs up Oil light and inspection light reset
hi all, well i just thought i'd share the wealth with every one on this.
i bought a carsoft diag kit and had a fair few problems, but thanks to a very kind and helpful member of this forum i got sorted. cheers Pirate-copy.
Anyway i gave my girlfriends 323 a full service, oil, power steering fluid etc, and tried to reset the oil service and inspection lights using the CARSOFT kit, but to no avail, i've also seen loads on reset tools on the web, ebay etc and all cost a few quid. well i came across this site
http://www.unofficialbmw.com/e36/ele...ce_lights.html
i've just done it myself using a 6" long bit of speaker wire/cable, which cost my erm nothing as found it in the garage.
hope everyone can find this a cheap and easy way to reset your servive indicators.
for all with an E46 try this site, it also works as agian done it with mine.
http://www.bmwtips.com/tipsntricks/reset-plug/reset.htm
that bottom link also contains a description of how to reset the lights on an e36 but there's no pictures to go from.
Old 11-26-2007, 08:26 AM
Pirate_copy's Avatar
Pirate_copy Pirate_copy is offline
Still here
Send a message via MSN to Pirate_copy
Mein Auto: M3
Quite a few people have use this method buddy, i am not a fan myself as i am a big wuss
2001 Mini Cooper R50
Edirty6 for life
Old 11-26-2007, 11:53 AM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is offline
I Am The Machine
Mein Auto: Dreier, Fünfer & Siebener
Yep, its what I do too. I love it.
// Chad //
// 2006 BMW 330i Sport 6MT // 2006 Toyota Highlander Hybrid //
// 1997 Range Rover 4.0 // 1994 Range Rover Classic //
// 1997 Land Rover Discovery // 1998 Land Rover Discovery //
// 2009 Kawasaki Concours 14 // 2006 Kawasaki Ninja 250 //
// 1999 Chevy Tahoe //
Ok...this is getting ridiculous. Someone come buy a few of these things.
Originally Posted by SlimKlim View Post
You're a derbanana
Old 12-02-2007, 11:21 PM
Ethirtysicks Ethirtysicks is offline
HUMAN WRENCH.
Mein Auto: 97 328is
i work at a dealer....i just ground the pin with my test light instead of searching around the shop for the reset tool. it's pin 7. but just a FYI an easy way to remember how to reset the inspection/oil svc lights.-on the round obd connector under the hood... when you take the top off, inside it looks like a pac-man mouth. it's the outside pin that looks like pac-mans gonna eat. you ground it for about 12-15 seconds with the key on.
A CROWDED ELEVATOR SMELLS DIFFERENT TO A MIDGET.
Old 12-03-2007, 07:26 AM
Pahipo Pahipo is offline
Mein Auto: E84 X1, E46 M3, 01 Miata
It's a great tool that I use all the time. Since my clumsy hands are prone to slipping once in a while, I installed a low amp fuse on my reset wire tool for extra protection. Not sure what those other pins do and don't want to "short" anything out.
E36 Phantom - hope you don't mind, my signature pic was inspired by yours. Nice looking ride by the way. Thanx...
Old 12-23-2007, 10:33 PM
odp314 odp314 is offline
Mein Auto: 1994 BMW 325i convertible
Great info...Thanks
ODP314
Old 12-24-2007, 01:13 AM
jason_recliner's Avatar
jason_recliner jason_recliner is offline
Don't ask me, I'm a sofa.
Mein Auto: Bostongrün 1995 320i
That's exactly the way I remembered it after I did it first time.
The TIME is still unknown though. I read it as seven seconds for oil, fifteen for inspection.
After repeated increasing tries, I got oil to reset at somewhere around 12-15s.
Haven't got to cleared my inspection lights yet; they're still showing until I get around to finished whatever needs doing, probably diff or gear oil at 200,000 km.
"The Wheelie Bin" - 1995 320i Boston Green
A word on our sponsors: Iridium sparks thanks to NGK. #42 wheels are lovingly dressed by Yokohama C-Drive. The dark road ahead is turned into daylight by Eagle-Eye 6000K HID, supplemented by 7000K CCFL Angel eyes. HB/Fog have selected to go with Philips 4000K BlueVision. Engine parts choose to slip and slide with Castrol's finest 20-50 GTX genuine dinosaur slime, renewed every 10,000km.
Old 12-24-2007, 08:59 AM
TheOnlyE36 TheOnlyE36 is offline
Mein Auto: 1995 BMW 325is, 97 Ranger
Thanks for the info!
If you can't show me the way, then forgive me for being lost!
Old 12-24-2007, 10:08 AM
gldfshkpr's Avatar
gldfshkpr gldfshkpr is offline
OCD Slacker
Mein Auto: 1997 318i BMW
What do you mean by a "test light". This sounds simpler than making the tool outlined in the link.
Peace,
Kirk
Old 12-27-2007, 03:44 AM
A test light is basically just a screwdriver-like prod with a bulb in the handle, and a ground wire on the other side, maybe with an aligator clip.
With only a few ohms across the (cold) filament, it's also perfect for grounding the reset line.
Old 12-27-2007, 01:15 PM
gldfshkpr's Avatar
OCD Slacker
Cool, thanks. Will this work?
http://www.sears.com/shc/s/p_10153_1...ord=test+light
Peace,
Kirk
Old 12-28-2007, 01:54 AM
Yes. So will a paperclip, which is what I used.
Old 12-28-2007, 03:50 AM
guest0926 guest0926 is offline
Banned
Mein Auto: 1998 e36 318iS saloon
Will this service light / oil reset method apply to my 1998 e36 318iS saloon?
Regards,
Pete.
Old 12-28-2007, 05:21 AM
If it has a plug like that, then yes.
Old 11-25-2009, 09:18 PM
TnT817's Avatar
TnT817 TnT817 is offline
Mein Auto: 1993 325i 4dr
Wow were did you come from? Thats for an e90 like usama told you. Theres no reason to bring back a 3yr old thread.
Old 04-21-2012, 11:14 PM
Si e30 Si e30 is offline
Mein Auto: E36 M50TU
my E36 320i '93 has 20 pins data link,after Inspection signal visible on Cluster and do the service as listed in Bentley manual also below mentioned step ( grounding pin 7 to pin no 19 also to ground at body ) wait for 15 sec to reset the Service light but not work , Inspection with Clock signal remain on and green bar not illuminate
any one please help and Advice, what went wrong ...thanks
Old 04-22-2012, 12:06 AM
hornhospital's Avatar
D'oh, You Kids!
See my answer in your other thread about this.
Quotes to live by:
