Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > The MINI Board
The MINI Board
The Mini Cooper Forum
Old 11-26-2007, 09:43 AM
Gammaman Gammaman is offline
Mein Auto: Z8, X5 4.8, 540i
Question Space saver spare
The owner's manual for a 2007 S describes a space saver spare that fits under the rear of the car. Is it possible to retrofit this, or does the center exhaust get in the way? Would love to ditch the run flats!
Old 11-26-2007, 10:33 AM
gjhsu gjhsu is offline
Plucky MINI bloke
Mein Auto: 2007 MINI Cooper S, LiB/W
THey really need to remove that section of the manual, or more clearly label it as "Cooper" and not 'S'. Ditch the run flats, and play the odds that you won't get a blow out. Or have a friend on speed dial - just in case.
Old 11-28-2007, 01:17 PM
mtbscott's Avatar
mtbscott mtbscott is offline
Mein Auto: 2012 991 Carrera
The day I drove my '06 S home, I pulled of the runflats and put on my aftermarket wheels/performance tires, lost 7 lbs per corner in the process. Unbelievable difference in cornering and ride/harshness, I was reminded when I put the RF's back on when I sold the car. I made up my own little mobility kit for the trunk with an air compressor, can of Fix a Flat, and a plug kit. Never had to use it.
