E46 (1999 - 2006)
Old 12-01-2007, 07:44 PM
llando88 llando88 is offline
Mein Auto: Ram 2500 4x4
DIY: Removing Stuck-on Alloy Wheels
I had my first occasion to remove a wheel on my E46 today, thought I would pass along a problem and the eventual solution that I came up with. KrisL please comment, is this common I wonder?
Anyway, I had discovered last week I had a nail in my left rear tire. It was down to 21 psi, so I pumped it up until I could sort it out today.
I chocked the front wheel, then jacked up the car with the service jack. I removed the wheel bolts, but the wheel would not come off.
I tried a soft-faced mallet, but the wheel would not budge.
Eventually, what I did was to gently lower the car on the jack so that the wheel was taking some of the weight of the car. I never let it off the jack completely, but this was enough to be able to shift the "stiction" that the wheel was suffering and allowed me to get a thin screw driver in and gently lever the wheel away from the hub.
(I got the tire plugged ok, turns out it was not a nail but a bolt broken off in the tire. Yikes.)
I noticed after I got the wheel off that the interior of the hub had rusted/corroded where the alloy wheel sat. I take it there was some kind of electrolytic reaction between the cast iron of the hub and the alloy of the wheel... I smeared a very thin layer of grease on the hub landing to prevent this from happening again, although I guess I have this same problem to look forward to with the other three wheels.
Glad I did not have to buy another tire, they are down to about 4 to 4.5mm depending on where I measure the rears, so its not far away though.
Was this ok? What do other people do if their wheels stick on?
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.”
- J.C. Watts Jr.
Old 12-01-2007, 07:58 PM
KrisL's Avatar
KrisL KrisL is offline
Ubergeek
Send a message via AIM to KrisL Send a message via Yahoo to KrisL
Mein Auto: 330i ZHP
Yep, that's just fine.
Step 1 is always kick the wheel/tire really hard. really hard.
if that does not work, proceed to step 2, which is what you described - lower the car onto the wheel. I think it's even OK to drive it back and forth a few feet with the lug bolts loose.
I always grease my hubs whenever I remove my wheels. I remove them to clean them fairly regularly, and they always fall right off.
Old 12-01-2007, 10:03 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
What you`re experiencing is called "Galvanic Action", a chemical reaction between dissimilar metals (steel/iron hubs & alloy wheels), which actually bonds the two together to an amazing (and alarming) degree. If you live in an area that gets snow, the salt spread on the roads intensifies the effect.When changing wheels, it`s important to clean hubs & wheel mating surfaces (a wire brush works well), then coat both mating surfaces with a thin coat of white Lithium grease, wheel-bearing grease, etc.This will make things a LOT easier next time around. To free those stuck wheels (rears are *always* ten times harder than fronts), jack up the car so there`s about an inch of daylight under the tire (lugs removed, of course :-), then take a short piece of 4 x 4 lumber, and lay it on the ground up against the edge of the tire, and with the biggest hammer you can find (my 4-pound sledge does the trick) whack the living piss out of the 4 x 4, alternate inside to outside, `til it comes free.
Regards,
Bob
Old 12-01-2007, 10:11 PM
sierrakilo99 sierrakilo99 is offline
Send a message via AIM to sierrakilo99
Mein Auto: 2008 328i/1989 Civic HB
I keep a 4-lb small/short handled sledge hammer in the back of the car just for this purpose. Even with grease on the hub, I have one wheel that just won't come off without whacking the living daylights out of the perimeter of the tire with that hammer. But it works...
Old 12-02-2007, 05:41 AM
Thanks all...good to know I was doing it ok.
Fast_Bob - You get my vote for most appropriate use of descriptive English language in a car-guy post -- succinct and to the point.
- J.C. Watts Jr.
Old 12-02-2007, 10:27 AM
Guys/KrisL - Assuming it was ok, I submitted an entry to the E46 wiki with the collected thoughts here.
- J.C. Watts Jr.
Old 12-02-2007, 10:47 AM
ktc ktc is offline
Mein Auto: '05 330i ZHP
Reminds me of last year when I drove the entire salty winter season in Boston with one center cap off one of the rears. This spring, I had the exact same problem -- I had my car up on 1 jack (no other supports), and I was beating the living snot out of that wheel without it budging. The entire time I watched the car sway back and forth on the jack with every hit, and I was trying to pry the thing loose with all my might while praying that the jack won't fail.
I know, very stupid of me. Plus I was at a remote storage site (where I store my wheels) and there wasn't anyone else around
Oh well, still here, got all digits and toes. It took me like 20 minutes of sweating and cursing and I was ready to just give up and drive home on 1 snow and 3 summer tires.
Old 12-02-2007, 10:53 AM
BLT's Avatar
BLT BLT is offline
Mein Auto: 330i, Mazda6, R90/6 R60/5
I leave on one lug nut that has been loosened and then whack the tire with a 4x4, works every time.
Old 12-02-2007, 11:44 AM
jeffreyslc's Avatar
jeffreyslc jeffreyslc is offline
Mein Auto: 2002 330xi
Do you guys put anti-sieze (not sure of the spelling) compound onto the lug bolt threads before putting them back on? I just changed to snows and didn't think about doing this.
Old 12-02-2007, 12:32 PM
Fast Bob's Avatar
Keeping it surreal
I always clean the threads well with a wire brush, but I don`t grease `em, cause it affects the ability to get an accurate torque setting.
Regards,
Bob
Old 12-02-2007, 12:46 PM
jvr826's Avatar
jvr826 jvr826 is offline
Is it Trackday yet?
Mein Auto: 05 330ci 6MT
Not on the bolts, but a little around the hub won't hurt. I do this to help wheel swaps go easier. Be sure to use a brush to remove the rust first, a dremel works nicely too.
Jeff R.
Old 12-02-2007, 01:41 PM
Fast Bob's Avatar
Keeping it surreal
Addendum:
The best tool I`ve found for cleaning lug bolts & bolt holes is the cheapie battery-post-cleaning tool commonly found at auto-parts stores.... it comes apart in two halves, a female wire brush side (for the bolts), and a male side (for the holes)....works real well.
Regards,
Bob
Old 11-03-2012, 03:10 PM
Wagons Wagons is offline
Mein Auto: BMW 540iT; Honda Pilot
Old post, but just saved me much frustration and a tow.
Whacked away at my rear wheel with a small sledge and 2X4 and off the wheel came.
Now to figure out why it's leaking.
Thanks Bimmerfest.
2000 540iAT; driven in Germany for 3 years and now is in the US
Old 11-05-2012, 07:59 AM
rruiter rruiter is offline
Mein Auto: 04 M3 Coupe SMG
Thanks Bimmerfest.
I've had some bad experiences with chromed wheels. They corrode where the tire seals and cause it to slowly leak. The tire shop was able to clean it up and put something on it to prevent it and so far so good no more leaks.
04 BMW M3 Coupe SMG-II Carbon Black
