E46 (1999 - 2006)
Old 12-06-2007, 08:18 PM
kenk kenk is offline
Mein Auto: 2005 325Ci
Auto Xenon Headlight adjustment?
I just bought a 2005 325Ci with Xenon headlights that have the auto leveling feature. I would prefer to have the low beam cutoff to be a little higher. Is there a way to adjust the target level so I can see a bit farther ahead??
Ken
Old 12-06-2007, 09:53 PM
downtown downtown is offline
Mein Auto: 2004 BMW 330i Sport 6MT
I can't answer this, infact, I don't know what the benefit is of the auto leveling feature. My not just have them fixed? Seriously, is there really a benefit.
- Downtown -
2004 BMW 330i 6MT Sport Silver Gray
Old 12-07-2007, 04:27 AM
G. P. Burdell's Avatar
G. P. Burdell G. P. Burdell is offline
Rambling Wreck
Mein Auto: E46
Yes, you can. There are two plastic adjustment knobs on the headlight assemblies. One is for vertical aiming, and the other is for horizontal aiming. The adjusters on my lights look like little black thumb wheels with a hex socket in the center, but they may also look like white nylon screws that you have to turn with an Allen wrench.
Aim the lights according to the procedure linked below.
http://www.danielsternlighting.com/tech/aim/aim.html
Old 12-07-2007, 08:01 AM
jvr826's Avatar
jvr826 jvr826 is offline
Is it Trackday yet?
Mein Auto: 05 330ci 6MT
They are different on the facelift coupe, no thumb wheel. It is a screw like adjuster that will accept a philips head screw driver or a hex key/allen wrench. Driver side...
Jeff R.
Old 12-07-2007, 11:17 AM
Thanks! You guys are correct. I stopped over at my BMW dealer and one of the managers showed me where the adjusters are. I just don't know which is vertical and which is side to side. I guess I'll have to experiment
Ken
Old 12-07-2007, 04:43 PM
autobahn's Avatar
autobahn autobahn is offline
Mein Auto: 2004 BMW 330xi
Ken
Just had my dealer show me too. One on the outside is for left right. The one in the middle is for up and down.
2004 330xi: Steel Blue/Sand, SP w/ Run Flats, PP, CWP, PDC, BiXenon, Step
Old 12-07-2007, 05:56 PM
Rambling Wreck
Mein Auto: E46
Thanks for clarifying.
Is that a loose cable clip I see? Two of mine have become brittle and snapped off thus far - the others probably won't last long.
Old 12-07-2007, 07:07 PM
george1202 george1202 is offline
Mein Auto: 04 330CI ZHP
So you can adjust the focus of the beams manually even with self levelling features?
2004 330ci ZHP
Old 12-07-2007, 07:10 PM
traderhen traderhen is offline
Is the driver side headlight suppose to point lower than the passenger side headlight?
Old 12-07-2007, 07:19 PM
autobahn's Avatar
Yes. Just need an allen wrench on the sedan. The black knobs are behind the light. Middle one does up/down. Outer one does left/right.
Old 12-08-2007, 04:23 AM
Thanks autobahn.
Traderhen, yes the right headlight focus is slightly higher than the left side for most BMWs so as not to blind oncoming vehicles.
2004 330ci ZHP
Old 12-09-2007, 01:51 PM
Last night I did some adjusting.....vertical only. Clockwise turn of the adjuster raises the aim point....counter clockwise to lower the beam. I ended up turning the adjuster around 1/2 turn. I may change it again, based on experience with oncoming drivers.....I don't want to blind someone.
Thank!!!
Ken
Old 12-09-2007, 05:51 PM
simon325e's Avatar
simon325e simon325e is offline
Mod the driver
Mein Auto: BMW
Just FYI
For the self-leveling clueless: the auto leveling compensates for vehicle loading. It keeps the headlights to the adjusted level when the rear of the vehicle is loaded (that's why they adjust down). This is common in HIDs setups, but some are manual. In fact, ECE Regulation 48 requires manual systems on all vehicles (ECE=United Nations Economic Commission for Europe) and self-leving for cars with headlamp bulbs producing more than 2,000 lumens (like HIDs).
In the US, self leveling HIDs are just cool technology; useless for 99% of people.
Old 12-14-2007, 07:59 AM
wdaveweaver wdaveweaver is offline
Send a message via MSN to wdaveweaver Send a message via Yahoo to wdaveweaver
Mein Auto: 2004 330i ZHP
I posed the same question to my BMW SA about the drivers light being slightly lower that the passenger as I though there was an alignment issue. My SA (who is also a family friend) informed me that the Zenons come from the factory aligned this way as US law dictates the drivers side must be aimed slightly lower to keep from inadvertantly blinding or distracting oncoming drivers. I would assume you could adjust this to compensate, but if you get a very picky inspector when you go to inspect you vehicle once a year in your state they may fail you due to this fact. Just keep this in mind!!
Gig'Em Ags
Old 01-09-2008, 01:16 PM
dastrix dastrix is offline
Mein Auto: E46 325 Ti Compact
Guys, I have a E46 that has manual adjusting headlights via my Light switch. I'm installing BiXenon OEM housings, it looks like a straight swap - am I right in saying I dont need 'self leveling' sensors, I can just use the switch to move them up and down?
Old 01-09-2008, 01:17 PM
KrisL's Avatar
KrisL KrisL is offline
Ubergeek
Send a message via AIM to KrisL Send a message via Yahoo to KrisL
Mein Auto: 330i ZHP
Correct.
Old 01-09-2008, 01:19 PM
KrisL, can I pick your brain a bit further about LCM reflash procedures?
Old 01-09-2008, 01:27 PM
KrisL's Avatar
Ubergeek
Mein Auto: 330i ZHP
Don't know anything about it other than "go to a dealer"
Old 01-09-2008, 01:33 PM
haha ok Cheers
Old 01-09-2008, 02:30 PM
alaamuq alaamuq is offline
Mein Auto: 2003 BMW 330ci
Hi all,
A problem with my Xenon headlights started about 2 weeks ago. The headlights in my 2003 330ci were moving up and down, even though there was no car ahead of me, and the road was flat. As time went by, the problem is becoming more frequent. Also, a couple of flickering happened here and there. I saw flickers even when the headlights switch is on the OFF position.
Can anyone please give me any hint.. Thanks in advance.
Cheers,
Alan
