Using regular and not premium gas - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > General BMW Questions
Use this forum to ask general question about the BMW ownership and keep up on the latest BMW news. Direct all model specific questions to model specific forums below.
Old 12-09-2007, 05:28 AM
ssminnow ssminnow is offline
Mein Auto: Audi A4 --> 328xi
So somebody told me that it is fine to use regular gas in a BMW. They said that the computer would compensate for the lower octane by changing the timing and it is a waste of money.
Does anyone know if there is any truth to this? Real evidence not just someone saying it is a stupid thing to do and why would you want to do that.
Old 12-09-2007, 06:04 AM
llando88 llando88 is offline
Mein Auto: Ram 2500 4x4
What does your owner's manual say?
Mine says to use Premium.
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.”
- J.C. Watts Jr.
Old 12-09-2007, 06:25 AM
MightyY MightyY is offline
Mein Auto: 05 M3
Why would you want to retard your engine timing on purpose? Spend the extra $2/tank.
Old 12-09-2007, 06:27 AM
uncle ken's Avatar
uncle ken uncle ken is offline
Mein Auto: 2014 M6
Talking
When you use 87 octane your knock sensors will retard the ignition advance in an effort to avoid engine damage. Of course the engine has to ping a few times before the knock sensors function...or you could just do what BMW recommends. If you are determined to pump regular grade gasoline be sure and add a Turbonator to compensate for any power loss!
http://www.turbonator.com/index.html
"Whither goest thou, America, in thy shiny car in the night?"
- Jack Kerouac, On the Road
Old 12-09-2007, 06:29 AM
Boile Boile is offline
Mein Auto: .
He doesn't have a BMW owner's manual.
Stop the madness: U.S. National Debt Clock
This post is brilliant. Completely spot on and chock full of useful information. Pure genius and original.
- Frank Rizzo
Old 12-09-2007, 06:30 AM
Mein Auto: .
To save $2.
- Frank Rizzo
Old 12-09-2007, 06:41 AM
I'm not 100% sure. Why would someone come onto a BMW forum and ask a question like that without a BMW?
Sorry, I was distracted by the football game I was watching on TV.
- J.C. Watts Jr.
Old 12-09-2007, 07:10 AM
First off, it was merely a question. My shampoo instructions says to wash, rinse and rewash. I dont do that either. I am sure you do though.
Old 12-09-2007, 07:19 AM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
BMW engines are high compression, high-performance machines, and require premium fuel to perform at their maximum potential.
Regards,
Bob
Old 12-09-2007, 07:35 AM
ktc ktc is offline
Mein Auto: '05 330i ZHP
I'm going to assume that if you can find the low-grade enough gas, there isn't anything the engine timing can do to prevent the fuel from just auto-combusting... I would hate to have to clean up that engine afterwards. Talk about a good way to reduce longevity.
Aside from octane, I would try and use top-tier fuel as much as possible. I plan on keeping my car for at least 5+ more years, and the thought of all that junk accumulating and slowly impairing the engine is just sad.
YMMV.
Keith
Old 12-09-2007, 07:37 AM
vern vern is offline
Send a message via AIM to vern
Mein Auto: 01 330ci 05 530i 06 X3
Very bad cmpareison unless you got pistons on your head. just do what BMW recomends and use premium gas and you will be doing the right thing without engine problems down the line. If you want tons of information on the subject do a SEARCH, the subject matter has been beaten to death. Good luck
cheers
vern
2012 335iA Blk. Sapphire- Sport-Blk. Dakota Leather/Red-Brushed Alum.Trim-DAP-PP-CWP Rear View Camera-BMW Asst w/Enhanced BT&USB-High Gloss Blk.Trim Hghight-PSP-Speed Limit Info-Tech. Pkg-PDC-Rear Manual Sun Shades-SAT-Variable Sport Steering-Wheel Locks- Rubber Mats-Euro Del 5/14/12-Redelivery 7/16/12 2006 X3 3.0iA 4/6 Silver Gray Metallic-Black Leather-Nav-PP-SP-Xenon Headlights-PDC-Heated Front Seats-Privacy Glass-Servotronic Steering-Premium Sound System-R R R- Wheel Locks- Rubber Mats
Old 12-09-2007, 07:40 AM
Mein Auto: .
Regards,
Bob
But that doesn't answer his question.
Will the engine self-compensate for the lower octane gas? YES.
Is it a waste of money to use high octane gas? NO. You get lower mileage per gallon with low octane gas, so you end up losing more than $2 per tank.
- Frank Rizzo
Old 12-09-2007, 08:25 AM
AzNMpower32's Avatar
Tar Heel Faithful
Should you eat canned foods all the time to save a bit of money, or should you eat fresh foods?
Old 12-09-2007, 08:59 AM
akhbhaat akhbhaat is offline
In vino veritas
Mein Auto: German Civic
The short answer is: it is technically acceptable to use "regular" (lower octane) fuel in a BMW.
To understand why, you must know why BMW recommends high octane fuel in the first place. To avoid writing a novella, I'm going to assume that whoever reads this has some fundamental grasp of physics and chemistry.
Octane rating is a measure of the gasoline's resistance to detonation. Note that octane itself is a hydrocarbon atom (not unlike butane, heptane, propane and so forth). This is an important measure because gasoline is a relatively volatile substance. If you increase the pressure or temperature inside the cylinder, you increase the likelihood that the fuel will detonate before the spark plug fires (uncontrolled detonation/engine knock). Uncontrolled detonation can obviously cause serious damage to the engine.
Most of BMW's engines run relatively high compression ratios, which for our purposes is essentially akin to saying that they operate with high cylinder pressures. By running lower octane fuel with the factory specified compression ratio and ignition timings, you run a high risk of uncontrolled detonation. Of course, knowing that the average consumer is an idiot or that high octane fuel may not be available in all regions, BMW has installed knock sensors to adjust the engine's ignition timings if they detect conditions that would lead to premature detonation.
Thus, it is "safe" to run 87 octane in the car (I knew a friend who did just this for years in his 528i). However, this comes at the price of reduced fuel economy and power because the remapped timings are not as efficient as the factory defaults, obviously. And just be aware that if a knock sensor fails (given the failure rate of sensors in German cars, it's a valid concern), you could be in a spot of trouble.
At current fuel prices, the difference in price between 93 octane and 87 octane is less than 7%. If you don't mind losing power and fuel efficiency (which will actually mitigate some of the cost savings) and implicitly trust your engine's knock sensors, then by all means - run 87. But if 2 or 3 dollars per 50 dollar tank is of any concern to you, perhaps you bought the wrong car?
No significant quantities of judgment-impairing narcotics were consumed during or before the creation of this message.
Old 12-09-2007, 09:19 AM
djfitter's Avatar
djfitter djfitter is offline
Mein Auto: BMW '08 535i
His post of a few days ago says he is going in for negotiations and hasn't purchased yet, so no Owners Manual.
Maybe so he can figure the cost of ownership.
cheers
vern
He made an analogy not a comparison. The IDEA of whether to blindly follow the instructions given is what was in question not if he shampoos his pistons on his head.
Again, another comparison that has nothing to do with the original question.
At least Boile and ahkbhatt offered up some kind of pertinent information.
dj
'08 535i
Deep Sea Blue
Cream Beige
Dark Poplar
6 Sp Manual
Sport
Premium
Rear Shades
BMW CCA #392316
Old 12-09-2007, 09:24 AM
Mein Auto: .
At last. Someone that gets it.
- Frank Rizzo
Old 12-09-2007, 10:46 AM
jcatral14's Avatar
jcatral14 jcatral14 is offline
Running around in circles
Mein Auto: E46 ZHP
Excellent, excellent post. You should save this in a Word document to paste in future threads like this
And yes, I do shampoo, rinse and repeat
2005 Imola Red 330i 6MT, ZHP, ZCW, Xenons
2014 Blue Water X3 xDrive28i ZCW, ZLP, LUCZ
Previous Bimmers
2007 Mystic Blue 530i - ED 12-15-06
2003 Grey Green 330i
2003 Electric Red 325iTa
Angular velocity is where it's at
-Jay
Old 12-09-2007, 10:54 AM
dj
You make some good points. I just thought it was a strange question, that frankly could be answered in a few minutes by a google search, or by searching this board. Perhaps people are more interested in starting a new conversation on a topic these days, then taking a few moments to research the issue for themselves.
I thought providing a comment relating to the fact that the OEM in my case recommends premium fuel was pertinent information. Excuse me.
To the OP - Good luck with your question. Here is some additional information you might want to check out:
http://www.bimmerfest.com/forums/sho...remium+regular
- J.C. Watts Jr.
Old 12-09-2007, 11:10 AM
Mein Auto: .
We don't want to waste time researching so we can spend more time watching football.
- Frank Rizzo
Old 12-09-2007, 11:28 AM
True, that.
Did you ever come back on the brake thread? Apols if I missed it. I was interested if anyone was planning on using the BMW Performance rotors...I think I'll just stick with OEM rotors and pads (my first E46 brake job, 44K miles) this time around, but those performance rotors do look cool...
NM, got it: http://www.bimmerfest.com/forums/sho...9&postcount=21
- J.C. Watts Jr.
Old 12-09-2007, 11:35 AM
Mein Auto: .
True, that.
I'll be doing my brakes in 3K miles.
I started looking at prices online and pretty soon I remembered why last time I bought my discs from the dealer. Those things are heavy and after you figure out shipping, dealer is only $5 more. Brake pads, yes, buy online and get the Axxis Deluxe or Ultimate.
If I were to do anything non-OEM it'd be for looks, not performance.
- Frank Rizzo
Old 12-09-2007, 12:22 PM
Valley320i Valley320i is offline
Mein Auto: 2004 320i
I'm in Nova Scotia. On a couple of cold mornings my Canadian 04 320i took a couple of trys to get started. The dealer told me they had a technical bulletin for just the 320i recommending running a couple of tanks of 87 octane (regular) to "reset" the anti-knock sensor. I'm on my fourth or fifth tank of regular and have noticed no difference in fuel economy or performance. The only difference I've noticed is the car hasn't had any more issues cold starting. I'm sure this must have everything to do with the lower detonation point on the regular. Anyway I've been hesitating going back to the premium. Based on the mileage I put on the car and the price of gas here I'm looking at an extra $500 dollars or so a year for the premium fuel. I probably will go back to premium simply because I've always taken care of my vehicles and followed the manufacturer's recommendations. It's resulted in years of worry free driving for me...so why stop now.
Old 12-09-2007, 12:35 PM
ktc ktc is offline
We're in the same boat. I wouldn't mind having colored calipers
Keith
Old 12-09-2007, 01:37 PM
bunnies's Avatar
bunnies bunnies is offline
Mein Auto: Looking at a 335i =)
Like akhbhaat said Why would you want to drive with reduced power and fuel economy. Why would you want to risk potentially damaging or destroying your engine to save $2.00 a tank? To me that just doesnt make sense. If you can afford a BMW shouldnt you just not worry about an extra $2-4 a week ?
Old 12-09-2007, 04:00 PM
tturedraider's Avatar
Freedom isn't free!!
+1 - and driving 15k miles per year, getting only 21 average mpg, premium gas only costs about $200 more annually if the price difference is 30 cents per gallon.
www.bmwcca.org
