E36 (1991 - 1999)
Old 03-29-2009, 02:24 AM
artychoke80 artychoke80 is offline
Mein Auto: 2001 - 318i
Originally Posted by rkrug View Post
Try disconnecting the connection to the heater control valve ... See if you have heat then .You stated before the temp gauge was straight up and you could feel air blowing out the ducts...
Excuse me for late entry
My Heater does not work unless i pull the electrical connection from the water valve. I.E, there is constant power to the water valve keeping it closed.
Any clues on what is causing this - control module??.
Old 05-26-2009, 06:23 PM
bimer123 bimer123 is offline
Mein Auto: bmw
I just bought a bmw 325i 1992, and when i got the car the lower hose that connects to the hcv jus at the fire wall, came offf so I put glue and stuck it back on, I drained the system flushed it, check thermostat and waterpump, filled it back up, and the engine overheats with cold air comming out the vents in the car... hmm could that hvc be the problem??hmm
Old 03-31-2013, 11:50 PM
bussinessacc bussinessacc is offline
Mein Auto: 323
in my case : valve its ok , 12 v on the pins are fine but the valve dose not close .
allways heat . seems that thr ground that come from resistor its bad not strong enough
Old 04-01-2013, 04:09 AM
dc_wright's Avatar
dc_wright dc_wright is offline
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
12V should always be present at the valve. It's controlled by switching the ground connection on and off through the temperature controller. A common failure on the valves is failure of the seals which allows coolant to get into the electrical portion of the valve and rendering it inoperable.
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 04-03-2013, 09:23 AM
Mein Auto: 323
Hi , i took off the valve and test it with diffrent 12v and its fine , my problem its that with the HCV connector pluged its not working but when i test the pins i have 12v in 1 and ground in pin 2 . I took diffrent body ground wire and its working . Witch component its controlling this HCV ? the resistor ?
thank you
Old 04-03-2013, 12:34 PM
dc_wright's Avatar
thank you
It's controlled by the temperature control unit inside the car. The unit where you set the fan speed and temperature.
Old 10-23-2013, 05:56 PM
knopp113 knopp113 is offline
Mein Auto: 2003 BMW 325xi
Problem: the ground in not working on the heater control valve so I am getting hot air on low temperature settings with the center vent on 3 dots. Could it be the hvac module?
Old 10-25-2013, 12:01 AM
Mein Auto: 323
do you have automatic climate or manual ?
in my case the heater valve was ok , the ground its controled by a management module or manual switch in the console .
