heater fan relay location - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 12-28-2007, 01:56 PM
dthurst dthurst is offline
Mein Auto: '97 740il
I am working on my brother-in-laws '95 318is. The heater fan is not blowing and I don't know where to find the relay. I have checked the fuse and it is good. I even replaced it for good measure. Let me know if I am way off track or if I'm hunting in the right field. I appreciate any help.
Old 12-28-2007, 08:55 PM
SAltonS SAltonS is offline
Mein Auto: 328i Sedan
I just got done playing with my heater. Ooooohhhh the fun!
If it is a digital control unit, then you might want to check the Final Stage Unit, which is found next to the gas pedal in the heater element. If you have the Manual Contols, then you have a Heater Resistor Pack and that should be found the same place, next to the gas pedal in the heater element.
I will try to give you a link.
Good luck
Old 12-28-2007, 09:01 PM
I hope this helps.
Final Stage Unit http://forums.bimmerforums.com/forum....php?p=3349096
Resistor Pack http://www.pelicanparts.com/bmw/tech...r_resistor.htm
Good luck.
Old 12-31-2007, 11:57 AM
Thanks! I will check it out.
dth
Old 01-02-2008, 06:56 PM
Good luck
