Old 10-14-2012, 07:37 PM
mcalic mcalic is offline
Mein Auto: 2001 530i
Abs module and battery disconnect
My abs lights have been on for for some time now on my 2001 530i. I had the abs remove and sent to aotoxpresstech which fix the problem for a short time. I removed the abs module to send it back for repairs but did not disconnect the battery before removal. I put the abs module back on after repair but it has not worked. Is it possible that the module does not work because I did not disconnect the battery before removal? Or does it matter eaither way? I have contacted bba and they have agreed to look at it. Please let me know if I have to disconnect the battery.
Old 10-15-2012, 09:19 AM
ultrevex ultrevex is offline
Mein Auto: 1999 528i
I asked my tech the same question, his answer was ' Eh, just don't have the ignition switched on when replacing the module.... duh!' I did not disconnect the battery, mine works fine.
Old 10-17-2012, 12:23 AM
Almost nobody disconnects the battery before removing or replacing their ABS control module.
Nothing wrong with doing so - and the 'formal' instructions say do to so ... but almost nobody does it.
Muuuuuuuuuch more detail here:
- How to diagnose & fix the ABS DSC (or ASC) BRAKE trifecta (1)
