Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > 5 Series DIY
5 Series DIY
Knowledge Is Power! ~ The place for do-it-yourself threads on a variety of topics. Start a thread describing a particular job (oil change, cooling system overhaul, brakes, shocks and springs, etc.) or search for one you need help with!
Old 12-18-2010, 06:08 AM
blubyu blubyu is offline
Mein Auto: 2001 530i Sport
Installed set up with TCU. Everything works great.
Old 12-18-2010, 06:17 AM
dalekressin's Avatar
dalekressin dalekressin is offline
Mein Auto: 2010 M3
I love my E39 2001.
This is a very interesting option for an upgrade.
For me this does not appear to be a DIY.
A drive to Toronto would be fun though.
94 530i sold (That was difficult for me)
01 530i >144,500+ miles SOLD
06 330XI winter's especially fun drive (SOLD)
10 M3 Sedan (sweet)
13 Nissan GT-R Black Edition
13 Porsche Cayenne Diesel
BMWCCA 4215
Old 02-02-2011, 04:03 AM
Andy_ran Andy_ran is offline
Mein Auto: E39 M5
Thanks for a brilliant thread. I have made a loom to match the pin outs in the first post and pluged in my TCU and it is showing up on the monitor (16:9) as Telephone yet when I try and select it from the menu screen i just stay in the menu
Any pointers?
The car is a 2000 M5 with Factory nav and DSP
i had the BMW GSM phone originaly which i have removed
Old 02-04-2011, 04:42 AM
Mein Auto: E39 M5
For those who have had the same problems as me i have now fixed it. I noted at least 2 users had the lack of Pins at 21 and 22
These are in the 18 pin connector under the arm rest and need to be either re routed to the boot or found else where in the car. I used 2 of the now un-needed cables in the loom and looped it back to the 25 pin connector and then into the 45 Pin in the correct place.
25 PIN 45 PIN
3 Ground ----------------------> 36 Ground
4 Voltage ----------------------> 17 Voltage
5 Terminal R ----------------------> 35 Terminal R
10 Tele Mute ----------------------> 51 Tele Mute
14 Microphone Negative ----------------------> 19 Microphone Negative
15 Positive Microphone ----------------------> 1 Positive Microphone
19 Positive Front Speaker ----------------------> 37 Positive Front Speaker
20 Sheild ----------------------> 21 Shield Microphone
25 Negative Frout Speaker ----------------------> 38 Negative Frout Speaker
18 PIN (under arm rest) 45 PIN
9 IBUS ----------------------> 15 IBUS
11 TELE ON ----------------------> 33 TEL ON
Old 03-10-2012, 12:37 PM
flatlander665 flatlander665 is offline
Mein Auto: 2002 X5 4.4
Question on the eject box harness
I have no eject box harness in my 2002 BMW X5. I saw in this post that for the 18 pin eject box connector, "pins 11 and 14 must be connected."
Does this mean:
A. pins 11 and 14 should be connected to each other (aka jumper)
or
B. pins 11 and 14 must be connected to some other two connections?
I have no audio for the Bluetooth at the moment. ULF box connected, SES jumper, and I've got DSP amp and Business CD radio.
Old 06-20-2012, 09:40 AM
rusty196500 rusty196500 is offline
Mein Auto: acs7 740i 1998
same problem
Originally Posted by overlordjd View Post
if the 18 pin connectore is the one I think you are referring to then pin 9 would be your I-Bus connector missing from 25pin DB.
on the same 18 pin connectore, pin 14 would be the tel on-out wire that you are missing from pin 21 on the 25 pin connector and may need to be looped to pin 11 of that same connector which is your tel on-in.
The information I am providing to you are all based on research as I do not have the same setup. Follow at your own discretion.
I nor bimmerfest accept no responsibility for any damages derived from folling any DIY instructions posted.
With that disclaimer out of the way, let me know how that works and pm me if you need any help.
hi i have e38 740 from 06/98 and my db 25 connector has nothing on pin 21 and pin 22 and would really appreciate some help with locating wires to feed to ibus and tel on for these connections thanks
Old 06-21-2012, 09:24 AM
no telephone optio on screen
hi all connected module up as per pinouts but now dont see telephone option on tv moniter. have traffic masrter installed could this be a problem any help would be appreciated
Old 04-11-2013, 09:28 PM
540 M-Sport's Avatar
Mein Auto: 01' 540 M-Sport cdn, F355
Originally Posted by speedninja View Post
can i us an iphone
Yes! I have an older 5th Generation ULF and last December I paired my Iphone5, no problem. Works great.
Factory M-Sport package with factory installed M-tech bumpers, factory Bluetooth, factory M-Audio 10" dual voice coil subs, Homelink, M5 rear stabilizer bar, Bilstein B14 PSS coil overs, Stop Tech ss brake lines, Akebono Euro Ceramic brake pads, oem Brembo and Zimmerman rotors, Dinan Stage 1 software, Strong Strut front upper stress bar.
