7 Series DIY
Do It Yourself forum dedicated for 7 Series BMW Owners |
Resource - Electronics/technical Q&A for "BMW_TECH"
is there a way to stop the passenger side mirror from going all the way down in reverse? its very annoying when parallel parking
because when the mirror is all the way down you can’t see the car behind you.
2012 X5d | White on Black | Fully Loaded | Sport Package Black Trim Painted White | JB Diesel Tuner - 525+ Pounds of Torque -2009 E320 Diesel | White on Black | H&R Springs | Kleemann KD-Box | 20" Monarch Hamburg Rims Black Roof | E63 Rear Lip | Hood Emblem Delete | Foglight Chrome Trim Delete Gone -2003 760LI Titanium Gray Metallic | Every option | H&R Springs upfront , via computer in rear OEM Style 128 21" wheels | 40% tint | AIB Angel Eye's w/ matching foglights Gone |
i still want it to go down but not all the way i dont want to use my rims as curb feelers
sorry... I should have known better than attempting to answer a question addressed to the Exalted, All-knowing, BMWTech...
sunny_j buddy,my suggestion is disabling the friggin curb function and using up one of your "memory function" for REVERSE purposes.This way when you throw the gearshift in reverse your right mirror would move exactly to where you want it,the headrest would come down so you can see (perhaps set the seat back to come down a little and seat would be raised a bit),the drivers mirror may tilt out a bit so you can see whats coming behind you without moving your head too much.And then set it to your normal driving position by pushing the other memory button.It sounds to me that you rarely (or avoid) back into a spot (or back out of).This may be the most suitable way for you,but thats just me.Ask yourself,how often would you need this darn button anyways? That would determine wether or not its worth the extra memory button. I have been meaning to ask you,any word on TV yet? Im still looking,there seems to be 2 ways.Do you have a Video Module in the trunk ? Another way I found is a "rigging kit" for DVB-T (Digital Video Broadcasting - Terrestrial) digital television transmitted via antenna ("terrestrial").It comes with a set top box and remote and seems like a failry simple rig by adding 2 antennae amplifiers (lt and rt of back windshield) and MOST connection with a few extra wires going into the NAV or DVD changer (this one is the trunk mounted one,if equipped).I wonder if you can even get Oprah or Jerry Springer,but I know Pay TV is NOT supported.
YOUR SECRET ADMIRER Last edited by BMW_tech; 01-14-2008 at 03:19 AM. |
i just saw your reply now. thanks but i dont think its worth using a memory button for reverse only.
im not to sure about the video module but i can watch tv/dvd in the rear no problem. so i guess i do have a video module. i also asked on the german 7 forum but no luck there either. its so stupid i can go buy a NAV TV unit which will allow me to watch a dvd while driving but bmw wont activate there tv function even though the video gets blocked out after 5kms. ![]() ![]() ![]() ![]()
for the past two days when i start my car for the first time i been getting random malfuntions. i couldnt take a pic of the one from yest but i managed to take one today, it said "Drive control! Drive moderately" Drive control systems malfuncion.
any idea's why this is happening? could it be the cold weather because it barely gets over freezing here.
If you notice,there is a level sensor there but you will never get a low level warning.What you do get is the message you are getting.If it is slightly low,simply top it off.If it is very low,time to visit the local techs to look for any leaks.If they do not take your word for it that the message appears,tell them to run it for faults.....they should see a level sensor fault.If they still don't believe you,dress up like an old lady (mrs. doubtfire) and see what that gets you.
YOUR SECRET ADMIRER |
you weren't joking about the cap and dipstick its actually there. i always thought there would be a mini version of bmw_tech attached to the cap
.... i checked the level is at "max"
Im sorry buddy,it must be a full moon.That's it Im going to bed !
'06 E65 740i High-Executive with Sports package . Alcantara headliner . Pearl leather . Comfort backseats . Comfortclose doors . 20" Y-spoke rims . |
BMW_Tech,
IS there a way to disable the TPM function by taking the sensors out or somthing? and is there a way to keep my EDC sport all the time not comfort thank's in advance Dude
![]() 00 E46 323I current 08 Jeep Grand Cherokee Laredo current 08 E60 535I LEASE OVER 02 E66 745LI LEMON 98 E39 528I SOLD 91 E30 316I SOLD |
momo get H&R springs. i would describe the ride quality of the car now in between comfort & sport on the edc
Sunny J, i just had tht same warning several times, first dealership said thy didnt knw, second fixed it and said something about something in the steering column..when i get home tommarrow i will post exactly what the SA put was the problem and what thy did to fix...havnt had the message since fix...
i dont have springs Sunny, I have the Damn Autoleveling thing so do i change the whole thing by getting the H&R springs?
i have rear self level suspension too. in the front i went with H&R springs and my SA hooked me up by lowering the rear via computer. Din used links to trick the computer. thats why i said i would compare the ride quality in between comfort & sport on the EDC.
I havent done this yet sir but I do think it may be possible to remove the entire system with your request to BMW engineers.They may be able to remove the "option CODE" for the TPM out of the Vehicle Order,the dealer would then save this in a "floppy" (yes the SSS has a floppy drive) or a CD and Adopt to your vehicle and that means PROGMAN (you know the drill).That way you don't neccessarily have to remove every component within the system that can cost you more money and grief (like tire valves in general,they may damage the wheel by removing or it could leak air as an example).
It could be from the deactivated Radar Detector, that's my best guess. I will go to BMW Welt this spring (its a 800 km drive), so perhaps they can follow the wiring or something ![]() Thanks for the answer
i asked the tv function on another bmw forum and this is what they told me. maybe bmw_tech would be able to translate it into simpler english.
![]() Quote:
I mentioned to you before in some thread here in our world,we cannot alter the Vehicle Order of any vehicle due to the complexity of these engineering codes that only has 5 characters at the most.There is no "master list" of codes unfortunately,and the software they provide cannot change any inputs other than the "preset" programs (retrofitting of accessories). In the event where the Vehicle Order of a vehicle has been erased somehow (perhaps during programming and the power went out),engineering from BMWNA would pick up the PuMA case (Montvale) and forward it to where they keep the engineers locked up (underground somewhere in Germany) and with the reply comes a formatted file to be saved on a floppy or a CD.The SSS takes over via PROGMAN and adapts the VO to the vehicle.Retrofits are then added one at a time because only the original equipment is contained in the VO.
thank you sir
Seems like you need to take out the bat. and some how ground the system/short it and lose it all, so BMW can reprogram the euro software to it
even if i cut the power to the dealer they still would reload the NA VO.
#25
I had them take mine out because I refused to pay $200 for 1 sensor for my spare tire.. Apparantly the sensor was missing from the spare wheel and they did not want to replace it for me under warranty so I said take it out then...
![]() ++ 2002 745 LI ++ MagnaFlow Universal with Dual 4" Tips + MTec V3's + 8000K HID Bulbs + BTU8000 Bluetooth + ACS Roof Spoiler + K&N Air Filter + Akebono Pads ++
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
