7 Series DIY
Do It Yourself forum dedicated for 7 Series BMW Owners |
#26
i got all four my sensors replaced and the control module for the tpm replaced under waranty bout month ago the batteries inside the sensors were low so they replaced them i didnt even get the chech tire pressure light they must have scanned it and told me the ordered the parts.
#28
National Highway Traffic Safety Administration (NHTSA) regulations on TPMS:
By 9/07, all vehicles must utilize a direct monitoring system with a pressure sensor inside each tire to broadcast the tire pressure to a central receiver on the vehicle. The yellow tell-tale must illuminate during the NHTSA required test within 20 minutes when there is a 25% loss in tire pressure (any or all of four tires). I guess this means jail time to those who remove this system that falls within the regulation guidelines.As for prior vehicles,Im sure there is a way to remove or disable the system.I haven't performed a reverse retrofit and with software updates,there are changes we aren't aware of until discovered.By now perhaps it cannot be removed from the Vehicle Order because its not a retrofit option in the US Market.Perhaps an "enable" or "disable" selection (iDrive) is in order for older vehicles not affected by the new regulations.Who knows? They might be listening.
YOUR SECRET ADMIRER |
#29
wierdest nosie , shaking and slammin
BMW Tech i had a wierd experince every time i kickdown and it happen to be little bumps on the street , i hear slamin like my shocks are out and even feel shaking underneath the car and on the arm rest like somthing hits me for the bottom ? what would that be??? any one know BMW_tech Your advice is greatly appreciated
![]() 00 E46 323I current 08 Jeep Grand Cherokee Laredo current 08 E60 535I LEASE OVER 02 E66 745LI LEMON 98 E39 528I SOLD 91 E30 316I SOLD |
#30
I think your problem may be the U-Joint.A deterioration or separation of the rubber in the universal joint located between the transmission and drive shaft assembly can cause clunking (during load reversal) or sometimes feel like being rear-ended (perhaps).Either way,I suggest taking it in for visual inspection of all your suspension components.The only way to determine if the noise is caused by a defective universal joint,the driveshaft must be removed from the vehicle. Once removed the metal collars can be checked for looseness or separation from the rubber material.Make sure they clear the adaptation values if they replaced the U-Joint.Vehicles produced from 10/22/2002 up to 3/2005 can be affected.
#31
BMW Tech - do you give relationship advice too?
2004 BMW 745Li 2003 Mercedes Benz SL55 AMG 2001 Toyota Landcruiser 2007 Infiniti FX35 1999 BMW 323i Convertible 1966 Ford Mustang Convertible 1974 Jensen Interceptor 2000 Mercedes E320 (R.I.P.) ![]() Sittin on stock 19s now. |
#32
thats exactly what happens not that i loose taraction and the triangle thing illuminates, but you know i tell that to the dealer , cant duplicate problem sir, is there a way you can say it so i can explain it to my SA cuz you know if they can't replicate bassically they would say its normal
#33
Yes,only straight.I don't do gay.Not that there's anything wrong with that.Would you like to give it a try bud ? Im all ears sir.
#34
SUBJECT Noise from Driveshaft Area MODEL E65 and E66 (7 Series) 745i and 745Li with N62 Engine and 6HP26 Transmission Vehicles produced from 10/22/2002 up to 3/2005 SITUATION One or more of the following complaints may be received from the customer while driving slowly, coming to a stop or at highway speeds: A clunk can be heard while rolling slowly and downshifting from 2nd to 1st gear coming to a stop. Load reversal causes a slight clunk noise. A clunk noise can be heard while shifting into forward or reverse gear from park or neutral
#35
#36
You like apples ??? How you like dem apples ????
#37
bmw_tech when BMW replaces the tranny what else is replaced. for example do they replace the torque converter ect....
2012 X5d | White on Black | Fully Loaded | Sport Package Black Trim Painted White | JB Diesel Tuner - 525+ Pounds of Torque -2009 E320 Diesel | White on Black | H&R Springs | Kleemann KD-Box | 20" Monarch Hamburg Rims Black Roof | E63 Rear Lip | Hood Emblem Delete | Foglight Chrome Trim Delete Gone -2003 760LI Titanium Gray Metallic | Every option | H&R Springs upfront , via computer in rear OEM Style 128 21" wheels | 40% tint | AIB Angel Eye's w/ matching foglights Gone |
#38
I have ran across 2 X5's with the ZF Transmission where after installing the "new" transmission,all I had was reverse gear and I had to do it all over again.When I reported the transmission serial number,all I got from the liason/engineering dude was OOPS.I wasn't going to complain unless they didn't pay me twice.The other transmission I knew was bad because it looked like it was dropped from an airplane without a chute.The box was missing and the pallet was reduced to one slab of wood barely hanging on to the oil pan.
#39
off the topic tech but other than the forklift what kind of car do u drive. in all honesty, would you recommend an e65/e66 to say - a family member. plead the 5th if you feel your job is in jeopardy.
![]() E66 SAPPHIRE BLACK |
#40
1) E-60 2) E-65/66 3) E-90/92 4) E-64 How's that for honesty man ??
#41
thats good man
.... lets see some pic's of your ride.
#42
honest as they come. personally, i think they should be paying you OT for putting in work on this forum. i'm thinkin' every member of this forum should donate to the "get BMW tech in an M5 cause". I got 5 on it. (dollars not thousand)
#43
man don't make me laugh.If my fillings happen to come apart it's going to cost me more than what you are going to give.Someday I hope to be able to sit down and have a beer with y'all.That's enough for a little good deed that everyone always seem to notice.My car isn't for show sunny_j.It looks like my grandpa,the grilles are missing along with splash shields (no front teeth)/dirty/and all panels are wrinkled.But the radio and engine sounds good.Every turn of the key guarantees a completed journey.As the great Marley said,my feet is my only carriage so I've got to push on through.I have been blessed to have worked (and continue to work) on the 2 best car line any kid could have imagined.Ferrari and BMW.My interest in having a nice car just disappeared when I became a single dad.My interests are what keeps her happy.If she asks me for an E-65,I might just give in.
#44
BMW Tech,
Would you happen to have the SIB # for the issue regarding the crackling sound in the speakers for the E6xs? My speakers do this occasionally but when I bring it to my dealer, they NPF me b/c the issue doesnt surface itself. Maybe with the SIB #, I can assist my dealer a little ![]() thanks.
2004 BMW 745Li 2001 BMW X5 |
#45
#46
There were low voltage faults found, but no trans faults which is what the car said to me and shut me down on the side of the road. |
#47
They took out the sensors and the Program so that I dont get any warnings...
![]() ++ 2002 745 LI ++ MagnaFlow Universal with Dual 4" Tips + MTec V3's + 8000K HID Bulbs + BTU8000 Bluetooth + ACS Roof Spoiler + K&N Air Filter + Akebono Pads ++
#48
CND-cannot duplicate NFF-No Fault Found NPF-No Problem Found TCU-Telematics Control Unit which you referred to as Tow Manage Control Unit Battery State of Health and Charge could cause all these problems.By disabling the TCU,it prevents it from waking up in order to transmit data and check whatever data it needs in order to operate/transmit.Since you don't have an active Assist contract,it is disabled.See my posting on AGM battery for information/clarification.
#49
^^ im telling you open up a shop up here.
#50
I got the same error, disappeared the next day
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
