Old 01-16-2008, 11:29 AM
Sunny 525i Sunny 525i is offline
2012 528i
Mein Auto: 2012 528i
WOW!!!! cool trick to fix rough idle
thanks to the guys over at e60.net
check out the link below
http://forums.e60.net/index.php?showtopic=40018
2012 528i - Tuned 4 -Banger
Old 01-16-2008, 11:30 AM
2012 528i
haven't tested it yet but i will today.
Old 01-16-2008, 12:14 PM
Ågent99's Avatar
Ågent99 Ågent99 is offline
Moderator, 5-Series
Mein Auto: Trek 6500 MTB
Uhm, isn't the trick for smoother shifting?
2001 530i/5 (E39), Topaz Blue/Stone Green/Black (sold) *very rare interior/exterior color combo*
2005 545i/SMG (E60), ED Order, Titanium Grey/Grey (lease over)
2014 335i/8-spd, Mineral Grey/Black (lease take over)
Old 01-16-2008, 01:48 PM
2012 528i
sorry for the mistake but i stand corrected, it is for smoother shifting.
Old 01-17-2008, 08:11 PM
Dmillion Dmillion is offline
Mein Auto: 2005 BMW 545i
Hmmm...I have an 05..and I think it worked, but I'm not sure. It definitely downshifted flawlessly...but 50% of the time I still experienced a slightly rough and barley noticeable shift from 1-2 gear. If I remember correctly, I would experience a rough shift from 1-2 95% of the time. I only drove the car approx 6 miles so I won't have more evidence until tomorrow...but it did seem to downshift like a dream. I floored it a few times while cruising at say 30-40 mph and I didn't feel a thing but a kick in my a** as the car took off…..it was very smooth!
Old 01-21-2008, 08:13 PM
BEMV BEMV is offline
Mein Auto: 2006 530i
You mention shifting while driving is good,how about when your stopped at a light with the shifter in Drive.Does it improve the idle or just the shifting?
Old 01-24-2008, 09:51 AM
2012 528i
well in my case it improved the idle and the shifting. my car use to have a very rough ide when i stopped at a red light or even in traffic and also rough shifting and now after the trick, havent had a rough idle yet and its been smooth shifting like the day i got it. its been about a week since i've done the trick and still no problems.
Old 01-24-2008, 12:23 PM
dbae23 dbae23 is offline
Mein Auto: 2008 E60 TT
I just tried resetting earlier today. I did notice a slight change...but i didn't get to drive it much. I'm going to go for a drive after work and see how the car feels on the highway. Will post result later
Does anybody else know of any other E60 "easter eggs"?
Old 11-12-2009, 01:34 AM
artisthand artisthand is offline
Mein Auto: BMW E60
try this it's easy to do only 5 minutes and solved all your rough idle and check engine light problems on your (2000-2009) later or newer yes! all BMW E60, X3, X5, 325i,330i,335i,525i,528i,530i,535i,... check out the manifold adjuster Google this up.
That appears to have been the problem the whole time. This is what caused the check engine light and O2 sensor fault and misfire codes. listed below are the codes that are caused by a broken Intake Manifold Runner Valve/Adjuster Unit!!!
Ignore these codes after changing your broken or damage Intake Manifold Runner Valve/adjuster Unit these codes will be gone.
P0171 = Fuel Trim, Bank1 System too Lean
P0174 = Fuel Trim, Bank2 System too Lean
P0300 = Random/Multiple Cylinder Misfire Detected
P0313 = Misfire Detected Low Fuel Level
P0741 = Torque Converter Clutch Circuit Performance or Stuck Off
P1083 = Fuel Control Mixture Lean (Bank 1 Sensor 1)
P1085 = Fuel Control Mixture Lean (Bank 2 Sensor 1)
P1342 = Misfire During Start Cylinder 1
P1346 = Misfire During Start Cylinder 3
P1348 = Misfire During Start Cylinder 4
P1350 = Misfire During Start Cylinder 5
P1352 = Misfire During Start Cylinder 6
The adjuster's part description on www.ecstuning.com
Air adjustment unit controls the path of the air in the intake manifold, allowing either a shorter or longer runner length. A common source of trouble causing low RPM sluggishness and accompanied by a clicking sound from the engine bay. The exact symptoms.
Location on driver's side. I already removed the two T40 bolts (upper right and lower middle.) Then simply pull the adjuster unit straight back out towards you. ( 5 minutes)
After removing the manifold adjuster you can also clean your idle control valve (ICV). It's easy to remove the ICV 12 minutes job and clean it with the Throttle Body & Air Intake Cleaner!!!
I can feel the difference in the acceleration and there's no slight hesitation or engine rough idle and after clearing the check engine light it will not come back on!!!
Old 11-12-2009, 07:27 AM
RedDvl33's Avatar
RedDvl33 RedDvl33 is offline
Glory Glory!!
Mein Auto: 2007 BMW 530i
Just reading this makes me excited! I can't wait to try it for my 63 mile commute home after work
| '07 530i | Mystic Blue Metallic | Auburn Leather | Sport/Premium |
RIP
2000 Toyota 4Runner
1997 Chevy Silverado
Old 11-12-2009, 10:03 AM
con_choa01 con_choa01 is offline
Mein Auto: 2007 525i
thanks guys. i've read something like the instruction up top somewhere and have not been able to find it, but this is pretty much the same thing. i'm gonna start keeping all these great tips in Microsoft word so i can refer to them easier.
Old 11-12-2009, 12:39 PM
Bart001's Avatar
Bart001 Bart001 is offline
Hofmeister kink ftw!1!!1!
Mein Auto: 2012 X5 35i Premium
I read that quite a while ago, and it did NOT fix the 'downshift SLAM into 1st gear' I was experiencing with my 2005 545i.
Old 11-12-2009, 08:45 PM
TopDownInFL's Avatar
TopDownInFL TopDownInFL is offline
Mein Auto: 2012 650 Coupe
I had that same issue with my '05 545. The reset did fix it.
Nick / TopDownInFL (sans the "top down")
2012 650 Coupe - Alpine White / Black Interior / M Package / Premium Sound
Previous Bimmers:
2008 650i Convertible
2004 645Ci Convertible - Reverse Sensors / Reverse Camera
2005 545i Sedan
2003 330Ci Convertible
2001 330Ci Coupe
1998 323i Convertible
1995 318i Sedan
Old 11-12-2009, 11:30 PM
sbrown712 sbrown712 is offline
Mein Auto: BMW 530i
I did this to my car a while back. One thing to keep in mind, if you baby the car after doing it you probably won't notice much change. I'm not saying that you need to go out and drive it like you stole it. What you will be doing to reteaching the transmission to your style of driving. I bought my 530 used and did this just a few days after getting the car. I noticed a marked improvement in both up and down shifts. As I understand it, it takes about 100 miles for the changes to be learned and used. A coworker did his car on my suggestion and he said that the downshifts in particular were much smoother after the reset.
Old 11-13-2009, 04:29 AM
wael farhat wael farhat is offline
Mein Auto: 530i year 2004
How to reset the automatic transmission of a 530i year 2004?
Old 12-01-2014, 12:12 AM
burner2004 burner2004 is offline
Mein Auto: BMW520D,E60,Y 2006,Msport
Unhappy
Hi guys,
A quick question from a noobie. I am experiencing only the rough idle situation when stopped. Basically the engine shakes the car a bit more than normal. I do not experience any delay or problems when changing gears manually or automatic. I have the E60 520D model march 2006. My question is:
Can I simply clean this part from that bad looking stuff on it without replacing the part?
From what I saw this part is like 200 USD, which will mean that in my country Cyprus they will be like 250 euro, which is not little.
Are there any consequences of not changing this Manifold Runner Valve/Adjuster Unit ?
Thanks in advance.
Old 12-01-2014, 05:30 AM
banglenot's Avatar
banglenot banglenot is offline
Mein Auto: 2007 530
Originally Posted by burner2004 View Post
Hi guys,
Thanks in advance.
You should start a new thread. Burying it at the bottom of a 5 year old one will not get you the visibility you want.
In any case, that's a DISA valve. Search by that name.
It failed often on the M54 engine, but there are rebuild kits for it. It fails less often on the N54, but it requires a replacement.
I don't know which type (if any) is on the "d". You should raise the question in the Diesel forum, below.
2007 530I
2003 325XI (gone)
2004 530I (gone)
2001 530I (gone)
BMW CCA Member 10+ Years
Old 02-12-2016, 02:48 AM
AugustBMW AugustBMW is offline
Mein Auto: E60 530i AT
Hello,
here is a new link, old one is not working any more:
http://5series.net/forums/e60-discus...er-shift-40018
