Old 01-23-2008, 05:50 PM
jmc jmc is offline
Mein Auto: 6 SPEED TS Z3M coupe
Traffic pro and OEM CD changer
For some reason my BMW traffic pro wont regonize my OEM changer. WHen I first reconnect the battery it reads loading then gives me an error message. After that it just reads NO CD. I checked the connection at the TP and it is the correct way not upside down. THe CD changer is PN 82111469404 so it should be compatible. ANy suggestions? THe CD has power and reads all the discs when a cartridge is inserted, so I think its an I bus issue.
THanks,
JMC
AA stage 3 TS
Old 01-23-2008, 06:04 PM
Ron Stygar's Avatar
19,585 Miles
THanks,
JMC
Is there a wire going to pin 7 of the BMW 17 radio connector on the TP side?
Old 01-23-2008, 06:07 PM
Ron Stygar's Avatar
19,585 Miles
Pin 7 should go to TP connector C2 pin 12.
Old 01-23-2008, 06:15 PM
jmc jmc is offline
I know the pins for the TP, but I dont know the pins for the OEM plug. DO you have a pic of the OEM plug with pin numbers for reference?
Thank you,
JMC
AA stage 3 TS
Old 01-23-2008, 06:21 PM
jmc jmc is offline
THere is a wire to pin 12 on the TP.
JMC
AA stage 3 TS
Old 01-23-2008, 06:27 PM
Ron Stygar's Avatar
19,585 Miles
JMC
JMC
7>12 is the I-bus line.
Old 01-23-2008, 06:33 PM
jmc jmc is offline
Thanks, I am at a loss then, it all looks in order.
JMC
AA stage 3 TS
Old 01-23-2008, 06:43 PM
jmc jmc is offline
I just figured out the problem, I think. THe I bus connector to the changer in the back should have 3 wires correct. Red/white, brown, and white/yellow. Mine only has two wires I am missing the white/yellow. Now the question is where could it be!!!!
Joe
AA stage 3 TS
Old 01-23-2008, 07:03 PM
Ron Stygar's Avatar
19,585 Miles
Joe
Pin 3 white/green/yellow.
Some Z3's missed the I-bus but I thought they were just roadsters but it's both.
What year is your car?
http://bimmerfest.com/forums/showthread.php?t=14151
Old 01-23-2008, 07:19 PM
jmc jmc is offline
My car is production 9/98. So basically I have to run the ibus wire from pin 7 on the OEM radio plug all the way back to the cd changer pin 3, that sucks!!!!
Thanks, as always you have the answers!!
Joe
AA stage 3 TS
Old 01-23-2008, 07:36 PM
jmc jmc is offline
Are either of these I bus cable PN's still available cause they dont show up on realoem
61 13 6 902 124 roady
61 13 6 902 201 coupe
I think this is one also (the only one that comes up) but I cant be certain
65 12 8 369 830
Thanks,
JOe
AA stage 3 TS
Old 01-23-2008, 08:03 PM
Ron Stygar's Avatar
19,585 Miles
65 12 8 369 830
Thanks,
JOe
Where did you get the 201 and 830 numbers?
Old 01-24-2008, 02:52 AM
jmc jmc is offline
THe 201 was from the coupe write up and the 830 was from a guy who did the I bus on his e36.
http://www.bimmerfest.com/forums/sho...ght=I+bus+wire
http://www.realoem.com/bmw/partxref....9830&showus=on
Joe
AA stage 3 TS
Old 01-24-2008, 09:38 AM
Ron Stygar's Avatar
19,585 Miles
Joe
201 is 207.
Has stock $1.50 retail.
Old 01-24-2008, 09:48 AM
jmc jmc is offline
THe PN in the write up is incorrect? I ordered that number from the dealer and it said "repair cable". If you have one to sell I will take that also. Paypal ok?
JMC
AA stage 3 TS
Old 01-24-2008, 09:51 AM
Ron Stygar's Avatar
19,585 Miles
JMC
Where are you getting that from? It says repair cable which is what you want.
Old 01-24-2008, 09:55 AM
jmc jmc is offline
I'm sorry I thought you were correcting the PN saying 201 is actually 207, but you mean they are the same?
JMC
AA stage 3 TS
Old 01-24-2008, 10:01 AM
Ron Stygar's Avatar
19,585 Miles
JMC
The coupe write up you linked shows 207 which is in the system.
201 you posted isn't.
Old 01-24-2008, 10:04 AM
jmc jmc is offline
AHH duh I will correct the post so the members will have the correct PN.
Sorry about that. I ordered the correct PN today.
JMC
AA stage 3 TS
Old 02-01-2008, 04:33 PM
jmc jmc is offline
I put everything in this week and it works great. Running the wire was easy, I actually was able to snake it under the rear compartment divider without having to remove it, it took all of 10 minutes.
I also fixed the ground loop and speed volume wire while I was at it.
Thanks for all the info!!!!
JMC
AA stage 3 TS
