97 740i power steering leak - Bimmerfest - BMW Forums
Old 01-25-2008, 08:16 AM
740icraze 740icraze is offline
Mein Auto: 97 740i
have a small power steering leak on ma 97 740i....
any help please on waht it could be...or can someone direct me to a repudable mechanic in the souther cali LA area...
thanks really appreciate it
Old 01-25-2008, 09:43 AM
PatrickfromATL PatrickfromATL is offline
Mein Auto: '99 740i Sport E38
Could be from your canister or one or both of the hoses coming off of it. I had all of the above on mine. Easy, but as always, expensive repair. You can get by until you're able to have it repaired by adding ATF. BE SURE TO USE THE PROPER FLUID, NOT POWER STEERING FLUID, BUT ATF (Dexron III, I believe) Check your owners manual.
Old 01-25-2008, 10:39 AM
Mein Auto: 97 740i
thanks really appreciate it..
I figured it was frm one of the hoses or around the canister...
thanks again
Old 01-28-2008, 03:36 PM
mandrews1119 mandrews1119 is offline
E38 - Flight on 4 wheels!
Mein Auto: 2001 750ilA
Be careful, even with DEXRON, or any ATF. To be most safe until you repair it, use the recommended Pentosin CHF 11, or 7 if your manual recommends it. Always be wary of substitute fluids, our cars are bred to run on the OEM and even things "close to it" can do harm to seals, hoses and the like and then you are looking at a much more expensive repair. It is more expensive, but cheaper than a full blown repair if the seals or other parts are negatively affected.
[SIGPIC]
2001 BMW E38/750il V12
Anthracite Metallic: If this car were any faster, I would have arrived yesterday!!
BMW, the ONLY driving machine.! By the way, yes, it's fast...and NO! You can't drive it!! Power, elegance, styling, technology that is still cutting edge, the ultimate driving machine for sure.!
Old 01-28-2008, 07:05 PM
crewdog843's Avatar
crewdog843 crewdog843 is offline
Mein Auto: '08 Z4 3.0si Roadie
If it says "ATF fluid only" on the filler cap, that's what goes in there, unless you have self levelling suspension.
jake
Old 01-29-2008, 07:27 PM
Correct crewdog,
I apologize for assuming the car automatically had self-levelling system. If it does, it will say either ZF on the cap, or list which Pentosin is needed.
[SIGPIC]
Old 01-30-2008, 08:52 AM
Mein Auto: 97 740i
koo koo....problem is ready to be fixed car goes in fri....
2 hoses were riped...
thanks to all....appreciate the help
Old 04-08-2008, 12:26 PM
Mein Auto: 97 740i
bummed out....
same problem...idk wat happen.... went back to mech n he didn't know wat it was...
now gotta fix it again...wat could have gotten wrong...
parked it...came out next morning felt sterring wheel really stiff...looked under al power steering fluid on floor..
?? help please....need directions to a good mechanic in souther cali LA area
Old 04-09-2008, 06:26 AM
crewdog843's Avatar
So.....you had the hoses repaired at the end of January and now in April, the hoses are leaking again....is that a correct assessment.
The power steering hoses on these cars are literally BMW's 'achilles heel'. Either your first mech did not know what he was doing, or something in your driving habits is affecting the hoses. I had a similar experience though: Car began leaking and I took it in to the dealer for replacement under warranty. Several months later, I was back at the dealer again for replacement (leaking again). Typically what happens is: The mechanic replaces one hose, and then the other hose starts leaking. Best to replace all hoses at the same time.
jake
Old 04-10-2008, 12:32 PM
Mein Auto: 97 740i
cool.....
had them fixed...u were correct crewdog...
the other hose was leaking...had it replaced
thanks a lot for ur help...now ma car is running great...
only problem....looks too stock...
Old 04-10-2008, 10:40 PM
crewdog843's Avatar
Good on you. Stock is not necessarily bad. You can cosmetically face lift it to look like the '01...change lenses front and read, paint the skirts, debadge the rear, buy M pars, drop the nose to give it more rake, black out the windows. Think outside the box, let your mind roll on.
Good luck.
jake
Old 04-17-2008, 06:28 AM
Mine is stock...I like stock.!
[SIGPIC]
Old 01-16-2009, 08:02 PM
riccom riccom is offline
Mein Auto: BMW 735 il year 1997
Unhappy My steering system is leak too..need help
Dear friends,
Mine 735 il year 1997 has same problem...the pentosin chf 11s always leaking on my garage floor. I had bring my bm to one of good BMW workshop but they suggest me to replace servotronics assy...its cost me about $ 2.300 without labour...any good suggest for me?...
Thx for advise me...
Old 02-06-2009, 01:29 PM
cgaribay cgaribay is offline
Mein Auto: 2001 740iL
I have the same problem with my 2001 740iL. My 2 atf hoses are also leaking, I was just wondering where can i buy these hoses and how much do they cost. Also, can you do this yourself?
Old 02-07-2009, 03:53 AM
crewdog843's Avatar
The job is a DIY if you have the time, money, tools, and inclination....but it is messy. Look at www.e38.org for a write up. Check around the various sites, such as autohausaz, bavauto, oembimmerparts, or as a last resort, buy from a dealer if you are in a hurry.
Buy the best hoses you can afford....the stock ones fail repeatedly, and if you replace one, replace all.
jake
Old 02-07-2009, 09:34 AM
nuttybgc nuttybgc is offline
Mein Auto: 98 BMW 740il
I have a quicc question about these power steering hoses what brand do you guys suggest is a better quality? And also, are the two hoses different, if so, which hose am I looking at because the hose on the left side (standing in front of the open-hooded car) of my power steering resovoir is the one leaking?
Old 02-09-2009, 03:01 PM
What's a reasonable price for the power steering hoses?
Old 02-09-2009, 03:18 PM
fear740il fear740il is offline
Mein Auto: 1995 740 IL
I just replaced the pressure hose on mine. Took me about an hour total time and the hose cost me $122 . A 19mm wobble socket and a long extension gets the box end pretty easily and the same with a short extension on the pump from under the car. Remove the plastic "skid" shield and it will be stairing you in the face. Don't forget to use new seals which are about .15 cents each.
MBMW is were I got the hose from.
8110 Aurora Ave N
Seattle, WA 98103
(206) 523-1804
Great service and a great price.
Definately use the correct fluid. It states on your cap which one to use and they carry it also. Like stated before its a little more expensive...ok, alot more expensive, but cheaper in the long run!
Does life get any better than this?
Old 03-13-2009, 02:33 PM
What are the electrical wires and parts that are screwed to the power steering resevoir called on a 1998 E38? Never really paid attention to it until it started make a fairly fast ticking sound after the car is warmed up. Is that normal?
Old 10-22-2012, 08:38 PM
Bw740 Bw740 is offline
Mein Auto: Bmw 740il
Hello i need help here please if any could tell me when ever I turn steering wheel all the way to the left or right i hear like an air leak coming from inside by the steering column. Is that normal or do i have air leak there somewhere. I would apreciate any help.....
Old 08-24-2015, 03:00 PM
Asia Asia is offline
Mein Auto: Bmw
I'm having this issue with my 1998. I was about to order the power steering hose.but it's two hoses there what is the other hose called. I found a power steering hose on car parts.com and its 55.00 but on sale for less now. I need some help as to what other hose I need. Thanks
Old 08-24-2015, 03:02 PM
Mein Auto: Bmw
Hello there can you tell me what two hoses they are? I need help today
HTML code is Off
