E34 (1989 - 1995)
Old 01-26-2008, 01:20 AM
Rodrick Msuya Rodrick Msuya is offline
Shiz Niz
Mein Auto: BMW 525i
525i Owner's manual
When I bought my BM it came with a Japanise one and now I am looking for English Language.
Any idea where I could get a soft-copy from?
Old 01-27-2008, 12:11 PM
bimmer dot info bimmer dot info is offline
The Biggest P0st Whore!!
Mein Auto: 91 525i
Not sure where you would look for a soft copy. There is an electronic copy of the manual online. You should be able to find it searching on this forum.
Old 01-27-2008, 09:00 PM
Shiz Niz
Mein Auto: BMW 525i
Yeah! that's what I mean, a soft copy, electronic copy are all the same. I have just did a searched "owner's manual for 525i" nothing came up that is related to this. Any idea?
Old 01-28-2008, 04:42 AM
Shiz Niz
Mein Auto: BMW 525i
BMW 5 Series Workshop Manual: 1989-1995 (E34) downloadable copy. This is what I am looking for. Please need help here!
Old 01-28-2008, 05:23 AM
TrevsE34 TrevsE34 is offline
Mein Auto: 1990 525I
Try this one, maybe it will help you out. It is the Bentley 5 series E34 Service Manual 1989-1995. It is about a six to ten minuet download if you have broadband. This File requires Adobe Acrobat Reader.
http://luuk.xs4all.nl/bmwboeken/Bent...ice_Manual.pdf
Old 01-29-2008, 08:12 AM
Shiz Niz
Mein Auto: BMW 525i
Thank you for the link man, the manual was very useful. I also needed Owner's manual the one that came with the car is in Japanese.
Is there a link for English one?
Old 01-29-2008, 09:20 AM
I am not sure of the year of your car but there are many places you can buy one from.
here is a link to what I pulled up from "Google"
http://www.google.com/search?hl=en&q...+Owners+Manual
The below is great but will only ship to USA. Once again, I am not sure what year your car is.
http://cgi.ebay.com/ebaymotors/BMW-e...QQcmdZViewItem
Old 01-29-2008, 09:40 AM
xstorted2006 xstorted2006 is offline
Send a message via Yahoo to xstorted2006
Mein Auto: 95 535i
What Year
What Year Is It Cause I'm Showing Some Warehouses With It In Stock For 1994 Let Me Know What Year It Is And I Can Give You A Great Price On It I'm From Anderson Bmw
Old 11-10-2012, 03:40 PM
Anndrea Anndrea is offline
Mein Auto: 1989525iBMW
I bought a 1989 525i BMW
I just bought a 1989 525i BMW and it passsed smog no problem. When I test drove it I didnt see any problems and it drove fine. Its a 5speed and ater about a week it overheated pretty fast when I left my house one day. I went 10 miles and had to pull over three times each way to cool it down enough to drive it home. I repaced the thermastat and flushed out the radiator and put a new sensor in the housing to the thermnastat and it runs good but the idle is going up and down when I start it and it was reading the temp guage but it is not now and it idles funny plus the stop leak the guy I bought it from put into it was the reason that it overheated due to it clogging the thermastat. And I dont see the thernastat guage working now Im confused . Also I flushed the radiator twice and the stop leak the guy put into it is thick and coming up in the radiator still. Any advise?
Old 11-10-2012, 04:26 PM
Banned
Mein Auto: car
Keep flushing the radiator. And do not buy stop leak or headgaskets in a can products which contain silicates which have a bad record of sedimenting out in solution (these are the cheaper stuff). Only purchase non-silicate coolant compatible hg seal products, if you wish to try any. These cost $90-$100 for our car.
Don't bother with radiator flush fluids at this time either. You just need to ....hey you have an 89 car. That's an M20 engine. SO do this. Remove the thermostat and replace the housing without it. Its easy as pie on your car. Then flush the radiator. Leave the hose in the expansion tank and undo the top radiator hose at the radiator fitting (do not undo any other hoses. Start the car and come back ever 15 minutes to check on the sedimentation that's coming out. Your engine will remain cold throughout due to the garden hose so you don't need to monitor constantly. You may need to do this for an hour....sounds like the silicates are stubborn things.
Are you sure that your water pump is working fine ? Or anything else related to the cooling system ? It may not be the silicates...after all, you bought it because you had an overheating problem to begin with.
Bleed the radiator properly after you've replaced the thermostat following the flush. Please follow the Bentley manual's instructions on bleeding. It is not difficult at all, and don't worry about bubbles being in the system, there will always be some air in the system its fine.
Old 11-10-2012, 04:50 PM
goosefoot33's Avatar
goosefoot33 goosefoot33 is online now
Manualaholic
Mein Auto: 01 330Ci/94 530i
How did you find a thread that is close to 5 years old regarding a user manual and post an issue about overheating?
Sent from my ADR6410LVW using Bimmer App
Full 1995 530i Part-out! http://www.bimmerfest.com/forums/sho...d.php?t=568506
BMWCCA Member# 451235
(Summer) 2001 330Ci - ZSP
(Winter) 1994 530i "Greenie" - LOADED
Old 11-10-2012, 09:01 PM
Banned
Mein Auto: car
Stress, especially that caused by a solution implemented that leads to even more problems instead.
Old 11-12-2012, 05:11 PM
BMWFatherFigure's Avatar
Old School
I got a new (unmarked) handbook off e-bay. Excellent value.
Current:
Previous:
