E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008)
Coupe and Roadster talk with our gurus here... |
The first taste of a true Canadian winter..
Just wanted to let you guys know that the Z4M seems to handle the frigid cold like a champion. It has been -20 degrees celcius (-35 with the wind chill) and the starts and runs great.. The only thing that seems to be acting up is the tire pressure sensor light. It was too cold to check the tire pressures but visually they looked okay.
+1 ... I've got a set of Dunlop M3's on the factory 18's and the car pulls through the snow without any problems whatsoever. The traction control is great keeping the car out of trouble and those brakes are a thing of beauty! My Coupe seems to be even better in the snow than my RX8 which was twitchy ... probably because of the weight difference!
Zoomby_U |
Only drove mine once in snow last season. Had snows on, however, after seeing the car covered in salt and others flying off guard rails and other cars, I parked it from January 15th until March 15th. This year; Saturn Ion.
2006 Z4MC - #LL93158 - SuperSprint Race - OE STB - Dave Z Modified CDV - Ground Control Coil Overs - Stoptech lines - Stoptech Pads - RE Clutch Stop - RE Transmission Mounts - LeatherZ M Shift Boot - ZHP Shift Knob |
I have yet to get a chance to drive the MC in the snow (central NJ gets a max of 2-4 snowstorms), but I have the snows on (Pirelli Snowsport 210s). Good to know that there is a chance to get home in this car
EB |
Apparently 17's do fit with the proper offset ... but you can't even put a piece of paper through the opening between the wheel and the caliper :-)
Cheers, Zoomby_U |
I take her out on dry clear days and even the slightest amount of salt on her brings tears to my eyes. |
As was pointed out, the wheel weights have to be placed at the very edge of the rims to clear to calipers. TireRack mis-mounted the weights on one of the wheel/tires combos they sent to me, but the shop I had put the wheels on popped on a new weight in a minute. Tire Rack apologized like crazy and offered to pay any charge the shop added (they didn't). EB |
07 ///M Coupe (Premium Package) Black Saphire Ext. Imola Red Int. Best Website in the History of the Internet! |
I'm running 17" M5 replicas and they fit tight but have been okay so far. Again I can't fit anything between the caliper and the wheel weights but they do not seem to rub.
BTW I checked tire pressure and they were all uniformly 28psi (all 4 tires) - topped up to 31psi and tire light went out on its own. |
With the bite of this wheel/tire combination I have yet to have any of the control function (ABS, etc.) kick in unless I am purposely trying to find limits. Daily driving is a non-event. EB |
Do you have any pics of your asa rims on your car? |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
