Old 01-27-2008, 04:15 PM
kneedeepinit kneedeepinit is offline
Mein Auto: 2004 525
location of block heater plug
1st post, 1st stupid question.
I have a 2004 BMW 525i. Today is the first very cold day and I want it to start tomorrow. I looked for the plug in and can't find it./ I have a 96 3 series and it is on the passenger side.
Any ideas? What side, possible locations? Under the bumper?
BTW, it is too cold to spend 1/2 hour looking.
Old 01-28-2008, 10:47 PM
jcl10 jcl10 is offline
Mein Auto: 2003 X5 3.0
There isn't one, unless a previous owner added an aftermarket one. BMW doesn't offer them on current models. Not a problem for the oil, but your battery may not be able to cope without a battery blanket (they used to be available at Canadian Tire, not sure if they still are).
2008 535i 6 MT, Premium, M Sport, Space Grey
2007 X3 3.0si 6 MT, Premium, White
Retired:
2003 X5 3.0 auto, Premium, Titanium Silver
2004 Z4 3.0 SMG, Sport, Premium, Maldives Blue
2002 325xi 5 MT, Steel Grey
Old 01-29-2008, 10:13 AM
ansetou ansetou is offline
Mein Auto: 08' 535xi white
not that I'll ever need one but how does a battery blanket help? if it's just a better isolation of heat the battery will still turn cold after enough time of left alone.
08' 535xi, White/Black, Premium, Cold Weather, Navi, Logic 7, iPod USB
Old 01-29-2008, 08:45 PM
A battery blanket is a heating pad, basically. It plugs in to 120 volts, and it keeps the battery at a normal temperature with a thermostatic control. Batteries lose a lot of cranking power when very cold, and a warm battery spins over the engine at normal cranking speed.
It has been -30 C in Calgary this past week (location of the OP) and that is about the point that a heated battery helps ensure reliable starting.
Retired:
Old 01-30-2008, 06:39 AM
Dirk885 Dirk885 is offline
Mein Auto: 540i, X3
Yeah, I'm thinking a battery blanket is required for my 540i. It hit -37C and all I got was clicking when I tried to start it. :S
When I bought it used the dealer was very reassuring about not needing the block heater due to the low temp synthetic oil being used in BMWs. However, silly me forgot that buying a used car meant buying a used battery with unknown history. I don't know if the battery is old, but I'm sure going to check when it gets a little warmer, deal with that car then.
Does anyone have a battery blanket? If so, how was the install? Did you run the cord from the trunk through the center console, out the firewall and out to the front of the car? Seems like a lot of work.
Old 01-30-2008, 10:45 AM
Alpha Alpha is offline
Mein Auto: 2008 535 XI
Minnesota Trick
I used to have a 92 Explorer when I lived in Minnesota. If you know you have a decent battery, flcik your lights on for about 5 seconds then crank the car. These starts the juice flowing. My Ford always started even at 40 below before windchill. ANother tip is once started let it idle for the oil viscocity to thin so that you do not burn a bearing prematurely. You can have an after market block heater added or a dipstick heater. I do not know if any of these are available for a bmw. The block heater is usually $150 installed and they replace a freeze plug with one that has the heater element. Nice thing is when you go to start your car you have almost instant heat.
Old 01-30-2008, 01:45 PM
djfitter's Avatar
djfitter djfitter is offline
Mein Auto: BMW '08 535i
Why would you not just run it out from under the hood and plug it into the wall if it is 120V?
dj
'08 535i
Deep Sea Blue
Cream Beige
Dark Poplar
6 Sp Manual
Sport
Premium
Rear Shades
BMW CCA #392316
Old 01-30-2008, 01:54 PM
iversonm's Avatar
iversonm iversonm is offline
3 pedals only!
Mein Auto: 2008 550i Carbon Black
dj
Because the battery is in the trunk?
2012 E88 128i, Alpine White/Black
2011 E90 328i, Crimson Red/Black
2008 E60 550i, Carbon Black/Natural Brown, ED 2 November 2007 (retired)
2006 E83 X3, Silver Grey/Black, ED 15 May 2006. (retired)
2005 E46 330i, Jet Black/Black (retired)
2002 E46 325i, Electric Red/Black (retired)
Old 01-30-2008, 01:58 PM
djfitter's Avatar
Why would you not just run it out from trunk and plug it into the wall if it is 120V?
FIXED IT.
DJ
'08 535i
Deep Sea Blue
Cream Beige
Dark Poplar
6 Sp Manual
Sport
Premium
Rear Shades
BMW CCA #392316
Old 01-30-2008, 02:44 PM
iversonm's Avatar
3 pedals only!
FIXED IT.
DJ
Perfect!
Old 02-01-2008, 08:48 PM
reidconti reidconti is offline
Officially Weird
Mein Auto: Clownshoe,Miata,WeeStrom
Is it a stupid question to ask why you assumed the car did have one? I don't know much about cold regions, though I know that block heaters exist. Is it just that every car sold up there has one, so it's a reasonable assumption? Otherwise I'd think it would be the first question you'd ask when buying (assuming you live somewhere that requires one).
Old 02-03-2008, 07:27 PM
obi.wan obi.wan is offline
Mein Auto: 06 XC90x2(me) , 07 530xiT
some things are standard up north (not saying BMW for sure) like
1- larger washer fluid reservoirs.
2- Heated outside mirrors on similar models that don't have them in the US
3- engine block heater.
4- Heated seats
Fair to say, cannot assume anything. By the way, the block heater heats the coolant and oil, nothing to do with the battery
2007 530XiT Monaco Blue/Beige
