Old 01-30-2008, 06:07 PM
Ryan M Ryan M is offline
Mein Auto: .
Sorry razzy no idea.
For Sale: M60B30 intake manifold, M50 intake manifold, 2.81 differential, new OEM upper control arm bushings, 8 M62 fuel injectors.
Old 01-30-2008, 08:07 PM
Steve530 Steve530 is offline
Mein Auto: 2001 530i
Originally Posted by razzy530 View Post
ok, what about on a 2002 530i? where is it located?
Not sure and I'm too lazy to go look now, but I think it's still under the intake manifold, but just not attached to the manifold. The easy way to find it is to follow the large plastic tube that comes off the valve cover at the front of the engine.
Old 01-31-2008, 08:02 AM
Bimmerfied Bimmerfied is offline
Mein Auto: 1998 Bmw 528i
awsome
great write up i need to do mine also i have the same problem. never worked on a bimmer but it doesnt look that bad. how much for the part (ccv) ?
Old 01-31-2008, 09:37 AM
Ågent99's Avatar
Ågent99 Ågent99 is offline
Moderator, 5-Series
Mein Auto: Trek 6500 MTB
Do you want me to move this to the DIY section or would you like to write up something separate for in there?
2001 530i/5 (E39), Topaz Blue/Stone Green/Black (sold) *very rare interior/exterior color combo*
2005 545i/SMG (E60), ED Order, Titanium Grey/Grey (lease over)
2014 335i/8-spd, Mineral Grey/Black (lease take over)
Old 01-31-2008, 11:45 AM
jfive96 jfive96 is offline
Connections Etc.
Send a message via MSN to jfive96 Send a message via Yahoo to jfive96
Mein Auto: 1998 528i
- -Price- -
- -The correct part costed me $60 and some change.- -
[SIGPIC][/SIGPIC]* *Guns Don't Kill People, Crazy Mutherf*%$ers Like Me Kill Theives!!!!!!* *
"Connections Etc." I got what you need! Get at me!!!
I'm Rich B@*#$h!!!!
Old 01-31-2008, 11:46 AM
Connections Etc.
- -Good ?- -
- -If you think the write up is ok how it is then sure move it to the DIY section. If there are areas I can improve the write up on I can redo it. Will it also be linked to this forum?- -
I'm Rich B@*#$h!!!!
Old 05-04-2008, 12:58 PM
psmoodey psmoodey is offline
Mein Auto: BMW X5
Hello,
I am replacing my oil separator on my BMW 2002 X5...looks like the layout is a little different from other model. Has anyone replaced the oil separator on an X5? Any insights, write-ups or pictures you can provide would be most helpful.
Paul.
Old 10-19-2008, 08:32 AM
TxTorqueMade TxTorqueMade is offline
TxTorqueMade
Send a message via Yahoo to TxTorqueMade
Mein Auto: 2002 330i
CCV/oil separator for 2002 330i DIY requested
Would love to see a DIY on this. Anyone up on this one?
Old 10-19-2008, 09:52 AM
synenergy52's Avatar
synenergy52 synenergy52 is offline
Send a message via AIM to synenergy52
Mein Auto: 2016 Lexus Hybrid
My 528i's engine stumbles and rocks back and forth for about 10-15 seconds @ cold start up every morning... then its as if something clicks on and the engine idles smooth as butter after that. Could the CCV do this? I'm also thinking its the SAP.
Complete BMW E46 Cooling System Guide
Shop at FCPEuro.com and use code MangoFCP5 at checkout for 5% off your order!
Old 10-19-2008, 03:00 PM
poolman poolman is offline
Mein Auto: 525i station wagon
Don't know if this will help you but this is the way that I replaced my ccv valve a month or so ago, this is for models 2001 and newer
To replace the ccv valve--do the following--remove the air box-remove the hoses all the way to the throttle body and idle control valve-remove the disa valve -two torx bolts hold it on then just pull out towards you--remove the bolts under that that hold the mounts for the idle control valve and remove that part
then remove the throttle body and then there is a electrical junction box just left of the throttle body--unbolt that and move it out of the way--next there is a bolt that holds down the oil dipstick--take it out and swing the dipstick back to the side--then you can remove the throttle body----now you will be able to see the ccv valve--there are three plastic hoses hooked to it---BREAK THEM--there is no way to remove them and remove the ccv valve belive me (order all three hoses) There is one or two sheet metal screws that hold the sucker in there--You may have to remove the purge valve from its rubber mount also--it just slides out and you can move it off to the side as well---along with that I really belive that you should replace the 0 rings in the distributation unit as well---I'll post along a thread I started back a few weeks ago to give you better understanding on some of the parts I'm mentioning above. Read all the way to the end on the below.
The hose that goes to the distribitor unit from the ccv is keyed at the ccv fitting--you put the hose on the cvv and turn it clockwise and it is then locked---don't miss that or you can have trouble
Lets try again--
http://forums.bimmerforums.com/forum....php?t=1079942
Old 10-20-2008, 12:26 PM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
Poolman, linky not worky
Old 10-20-2008, 03:14 PM
Thanks Doru---Can't figure what happened there--I edited the post and added the link back and checked it three tims and it worked OK--lets see what happens--It is the link for Battleing Vac links along with a couple of new posts I made there the other day.
Old 10-20-2008, 09:49 PM
lild's Avatar
lild lild is offline
livin the 'Fest
Mein Auto: 97' 528i, 06 ninja
i just cleaned mine, out while i had replace the the cps on my car. the car starts up better and seems to hold the rpm's up durring warm up, and the rough idle seems to be better for now. but it was and is still nasty. i had clunks of stuff come out when i cleaned it. but i plan on replacing it. the hardest part about removing it was not breaking the plastic hose.
The more you complain, the longer God makes you live. SPHOBA #00002
Old 10-22-2008, 11:07 AM
xisco44 xisco44 is offline
Mein Auto: 528i
whats the name of this part or the part number
Old 10-22-2008, 12:37 PM
rivercity's Avatar
rivercity rivercity is offline
Mein Auto: BMW 1998 528i
It's called the purge valve, or the technical name is the "fuel tank breather valve", part number 13901744150.......
Old 11-06-2008, 07:19 PM
01530iwhite 01530iwhite is offline
Mein Auto: 2001 530i w/ steptronic
subscribed to this thread thanks to poolman...great info hope it helps me to get my CCV replaced
Old 03-13-2010, 09:11 AM
Kardanill Kardanill is offline
Mein Auto: 2001 530i and 1997 328ic
CCV and Oil filter housing
Just thought I would add a couple of comments of my own. I recently went to remove my oil filler cap and found it to be ceased, could not remove. I tried to remove when the engine compartment was warm and sure enough cap came off, as it was frozen on due to moisture built-up. To my surprise, the cap looked like a milkshake exploded on it. I also found a massive oil leak around the head gasket area. Of course my first thought was head gasket and huge $$$ to fix. Long story short, I took an oil sample in to have checked and sure enough, water in the oil. After reading all of the forums, I decided to spend my $2.00 for oil filter housing gasket and $180 for winter version of CCV (I'm up in Canada and we easily hit -40 Celsius in winter) and see if I could fix this problem, as I could not believe it was the head gasket. I have read many forums that say the winter version of the CCV is a pia to change, I didn't find it that hard. I took the filter housing off and sure enough, leaking like a SOB. Then started disconnecting all lines leading to CCV and guess what, water started to pour out! I also found a big hunk of ice in the line that leads to the bottom of the CCV, check out the attached pics. All-and-all both problems fixed in a few hours. I'm sure the stealer would have charged be well over $1500 to fix! One thing to watch out for on the new CCV. The insulated jacked is held together by these lame o-rings that kept coming off when trying to squeeze the CCV in place. Some forums write that you need to modify the new CCV by shaving and cutting. I found that I did not have to do this, just have a lot of patience and a couple of cold beers. To boot, I did this in my garage in -15c!
ID:	221482   Click image for larger version
ID:	221483   Click image for larger version
ID:	221484   Click image for larger version
ID:	221485   Click image for larger version
Old 03-29-2010, 09:24 PM
Breez II Breez II is offline
Mein Auto: 1997 528i 5speed
Thumbs up
This looks like a great discription on the DIY for the CCV...will tackle the job on my '97 528i..thanx for the great info.
Old 03-30-2010, 09:45 AM
cn90 cn90 is offline
Actually you need to do more than the CCV.
I wrote a comprehensive DIY here:
1- Replacing Oil Line to Vanos (mine is leaking).
2- Replacing CCV and hoses (preventive).
3- Cleaning ICV and replace its hoses (preventive).
4- Cleaning Alternator Air Duct and Installed Gutter Guard to prevent leaves from being sucked in.
5. All vacuum hoses
6. Intake Gaskets etc.
http://www.bimmerfest.com/forums/sho...d.php?t=379225
Old 11-19-2010, 07:29 PM
MDrive MDrive is offline
Mein Auto: 99 M Coupe
CCV replaced in 45 min
These posts helped me do my 99 M Coupe (S52) in about 45 minutes. My task may have been simpler than others because of model differences, but here is what I did.
I bought a 10mm ratcheting box end from Sears...
Removed the air filter box.
Removed the crankcase vent pipe (to CCV).
Removed the vent tube from the lower connection leading to the dipstick tube.
Loosened one hose clamp to give access to the first of the three 10mm bolts holding the CCV on its bracket.
Removed the 3 10mm bolts (thank you, Sears), then removed the CCV...snaking it forward over the alternator into the space made available by removing the air filter box. Minor maneuvering required.
I then attached the new vent tube to the bottom of the new CCV and installed them (after inserting a new rubber grommet to the underside of the intake manifold). The 3 10mm bolts installed easily with the ratcheting box end.
Attached the vent tube to the dipstick tube. Attached the crankcase vent pipe. Tightened the hose clamp. Installed the air filter box.
Done in 45 minutes. No misadventures in this case.
Hope it helps.
Old 11-20-2010, 10:14 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Originally Posted by MDrive View Post
here is what I did.
FWIW, I've never done any of this, but, I tried to collect the relevant threads together to help others (and perhaps even me, in the future) do their CCV properly.
Here's what I've come up with (so far):
- CCV FAILS: crankcase ventilation valve diaphragm tears, freezes (1), &/or clogs (1), necessitating CCV replacement (M54,M54,M54) (M52,M52) (M52TU) (M62,M62) ('99 528i) ('98 528i); raising pressures, often causing the OFH oil filter housing to leak (1); frequently blowing the VCG valve cover gasket (1); and sometimes the head gasket (1); often causing vacuum leaks (1) (2) (3)
Please improve!
Old 04-16-2011, 10:32 AM
bluebee's Avatar
Originally Posted by bluebee View Post
FWIW...Here's what I've come up with (so far)
Recently added this combined reference:
- E39 (1997 - 2003) > How to test the BMW E39 pressure-controlled crankcase ventilation system (CCV)?
Old 04-16-2011, 10:35 AM
540indiana's Avatar
540indiana 540indiana is offline
Mein Auto: 2000 540i Sport
Blue, Check for PM
Old 06-10-2011, 09:07 PM
ztitans1 ztitans1 is offline
Mein Auto: 1997 528
This post helped a lot. Replaced my CCV in about 3 hours (taking my time so I would not break anything). Engine was cutting out at idle and running very rough with a loud vacuum leak somwhere below the intake. It was the CCV and/or the two hoses connected to it. Replaced all the above spending less than $100 total.
I just love this logo...
Old 07-30-2012, 07:44 PM
gdharvey gdharvey is offline
Mein Auto: 04 530i Sport
Replace Crank Case Vent Hose "ONLY"
Anybody just replace the Crank Case Vent hose (from VCG to CCV)?? I see all the posts related to replacing either the CCV and everything attached to it but I'm only looking to replace my cracked hose. The car is otherwise fine. I noticed it was cracked during routine maintenance of replacing the VCG.
