Old 01-28-2008, 11:44 AM
540ig5's Avatar
540ig5 540ig5 is offline
Mein Auto: new york metro area
Flashing check engine light????????
2 days ago after starting my car and driving for about 30 seconds my check engine light started blinking. I slowed down but kept driving. The light stopped blinking but then came back on after about a minute. The car did not drive different in any way. I pulled over, turned off the car and then started it again, and the light was gone. Iíve been driving the car for 2 days now and the blinking check engine light has not come back on. Any ideas on what that was all about. I didnít get the codes read, is that something I should do ASAP or it could wait?
Old 01-28-2008, 11:57 AM
Waveho Waveho is offline
Mein Auto: '07 335xi 6MT 4door
Yes get the code read at a place like autozone; the CEL will come on for a reason that is usually detrimental to the car....
'07 335xi 6-spd 4dr, Montego blue
'98 540i 6-spd Sport, Jet Black II(sold)
'92 325i 5-spd 4dr, burgundy(sold)
Old 01-28-2008, 12:33 PM
Brian McKinney's Avatar
Brian McKinney Brian McKinney is offline
BMW Nuthead
Mein Auto: e92 M3 6mt
umm a fuel tank breather valve and or a slightly loose gas cap are not really that detrimental to the car....which it could very well be
08 M3
TMS pulley
RPi scoops and drop in filter
DRB Motorsports axle back exhaust
Old 01-28-2008, 12:36 PM
lild's Avatar
lild lild is offline
livin the 'Fest
Mein Auto: 97' 528i, 06 ninja
i'm think somethings lose. if the light is not on, a code reader may not be able to retrive the codes.
The more you complain, the longer God makes you live. SPHOBA #00002
Old 01-28-2008, 01:00 PM
I said "usually."
Old 01-28-2008, 01:01 PM
My Peake reader is able to revive codes even after the CEL light is extinguished.
Old 01-28-2008, 01:11 PM
lild's Avatar
livin the 'Fest
that's what i get for having a cheap code reader.
Old 01-28-2008, 07:19 PM
Ryan M Ryan M is offline
Mein Auto: .
The CEL usually only comes on if it's an emissions related problem. Even with the CEL out, the codes should still be stored and able to be retrieved, if there were any.
For Sale: M60B30 intake manifold, M50 intake manifold, 2.81 differential, new OEM upper control arm bushings, 8 M62 fuel injectors.
Old 01-28-2008, 07:46 PM
dbruce dbruce is offline
Mein Auto: Sold 00 528iT, 06 Mazda6
Solid CEL means something that can wait (emissions related etc). Blinking CEL means stop the car immediately, it usually points to misfires.
If you got a blinking CEL, you have a problem.
http://forums.bimmerforums.com/forum...ferrerid=56200
Old 01-28-2008, 08:34 PM
540ig5's Avatar
Interesting, the only thing that's wired is that the car was driving absolutly fine.
Old 01-29-2008, 06:41 AM
KTrostel KTrostel is offline
Mein Auto: 1998 540i and 2002 M5
Yes and, a blinking CEL means the OBDII thinks that the problem it is monitoring will damage the engine. You do not need to stop immediately if you are in a dangerous position but you should gently drive the car to a place that you can park the vehicle.
Detonation can be very hard to detect and very quick to damage. If you CEL continues to flash get it checked immediately.
Old 01-29-2008, 09:08 AM
Al's540i's Avatar
Al's540i Al's540i is offline
Mein Auto: '00 BMW 540i; '11 BMW X5
You most likely had a misfire caused by an intake/vacuum leak, or a failing VANOS unit.
Old 01-29-2008, 09:47 AM
540ig5's Avatar
Would a failing air pump cause this. It as been making a high pitch winding notice lately.
Old 01-29-2008, 10:45 AM
Mein Auto: .
Yes, the secondary air injection pump could very well cause this. It's part of the emissions system.
