E60 (2004 - 2010)
BMW 5-Series (E60 chassis) was first seen in the Unites States in the fall of 2003 with a 2004 Model Year designation. The E60 is now available as a 528i, 528xi, 535i, 535xi, 550i and a 535xi sports wagon! -- View the E60 Wiki |
#201
I tested out my drains again...and both sides dripped water. I was kinda hoping they would be clogged. Now I have to wonder what caused the leak...or if the high pressure car wash made a difference.
#202
Welcome to join my facebook group uniting all victims of BMW sunroof leaks
The Facebook group's name is 'BMW paranormal sunroof' and you are welcome to join and post your pictures and feedback. This group is primarily meant for owners of a BMW with a 1st generation (2005) panoramic sunroof and that are suffering from leaks (in the rear, due to clogged drains). I am curious about the global scale of this problem. Best regards and thanks for joining! |
#203
Recently purchased a 2006 530xi. Went thru the car wash this past weekend and my son in the back notices that the column panels connecting the roof to the frame behind the back seat are soaking wet. I think this is officially referred to as "C-pillar trim panels".
After doing some quick research here i quickly went back out to the car and took the spare tire out to see if water entered there and to dry it out as I understand there are electronic modules under the spare. Thankfully, no water. But i was also suprised to find that my vehicle does not have any of the circuitry in the spare wheel cavity! I also checked the battery cavity and no traces of water there either ![]() I tested the drainage in the sunroof. with car pointing down hill, poored water into the sunroof drain track. water immediately flowed out of the front door hinge area. this is good. Parked with rear downhill and repeated. water eventually trickled out, but I would say it took at least 30 secs. I am guessing there is a semi-blockage. my plan is to take wheels off and rear wheel well inside trim to observe the drainage plug and clean. I have seen other posts about removing the interior trim to expose the drainage tube... this seems a little complex and trying to avoid that! Next is to replace the rubber molding around the sunroof as this is identified as one possible culprit in svc bulletin: SI B 54 02 08. Part Number: 54 13 7 117 551 ; Description: Perimeter Seal My question: has annyone else replaced this seal? Any challenges? Advice? thanks much!! -OX
2006 530xi | Silver Gray Metallic | Packages: Cold Weather, Premium, Sport | Logic7 |
#205
The local indy says they blow compressed air up the drains from the real wheel wells at every service. Would think that is a good thing to do.
Pax vobiscum. 2008 535xi Estate | Deep Sea Blue Metallic | Bamboo Anthracite | Sexy Charcoal Interior Except for Posh-Spice-Cleavage-Colored Comfort Seats | Belly Button Lint | Magic Don't Need No Key Package | Get Very Bad Directions Package | Intra-Uterine Bass Drum | Doesn't Work With Most Phones Package | Fila Brasileiro Snot All Over Rear Windows | Heated This, That, and the Other | Very Considerate Headlights | White-Knuckled-Passenger Package | JB4 | |
#206
I think there must be some seepage even with new seals. the trick is to keep them clean.
My 2008 528xi only has a very small electronic box in the well. It may be the sat radio?? I think they got the message and moved them all!! LOL |
#207
My dealer replaced ours three times, requiring a new seal each time. First time, the edge of it ripped. The second time, it puckered up unevenly after a few weeks. Third time was the charm.
#208
#209
clogged sunroof drains
I drive a 530i and about 3 days ago I began to get TPM malfunction sign, then every other light on the instrument panel you can think of and finally engine light came on with a warning not to drive the vehicle. I was not able to start the car and end up towing it to the dealer.
The dealer told me that they found the sunroof drains clogged, in result of which the water leaked into the trunk and damaged the computer module. I was told that my warranty did cover the repairs and would cost me $1,400 to repair it. North America BMW was not any help and kept referring me back to the dealer because they are just customer service representatives and are not technical advisors. These very kind customer service representatives told me that I've must parked my car under the trees all the time falling leaves caused the drains clogged. STUPID!! I've owned over 10 cars (American and Japanese) and have never had clogged drains. I am reading over 200 quotes/complaints related to the clogged drains. It is obvious that the sunroof on BMWs is poorly designed and BMW should recall the vehicles with the defective sunroofs or supply plumber's DRAINO with the car and advise in the car's manual on daily flushing of the drains. |
#210
You should ask the dealer to at least do that TSB which could reduce the damage if it happens again. |
#211
I did print out the article and brought it with me to 2 BMW dealers in northern NJ last week, both of them denied to check on the issue. They said this is not an internal authorized article and they do not have the same article in their database. They told me it will cost me $140 to have the drain cleaned on my E61. Rats!
#212
If you are filing the action, please count me in. I just brought my 06 CPO E61 in to 2 seperate BMA dealer in my area, both of them denied the article and told me they do not have that in their database. I'm not sure what I can do next; wait until the iDrive gone wild?! My Navi already acting up and they sai dit will cost me $490 plus tax to have it replaced! I suspect it might be damaged by moisture. |
#213
I was told then with my '05 X5 3.0 not to park on inclines, under trees, or out in the rain....
'00 GS 300-sold '04 325ci black/black-sold '05 X5 3.0i-black/biege - aka "work horse"- sold ![]() '08 535i-"never more HPFPs"-sold ![]() '05 ///M3 'vert - my Valium '11 X5 50i:blck/blck-all the goods, except the M package |
#214
BTW does anyone know if the roof drains are connected to the front cowl drains??? |
#215
What?! That was such a lame excuse. They assumed we all living in the desert I guess! But then, I'm sure they are trying everything in trying to get away with this. I own numerous Audis and my Audi dealer never asked twice on this kind of service bulletin, they always address the concern and a few times I don't even aware of that and they did the work free of when I brought my car in. BMW makes nice cars but their attitue on backing up their products is disappointing to say the least.
#216
----------------------------------- Nube1Kenobi 2008 535i Monaco Blue/Dakota Black/Dark Poplar | Sports Package | Premium Package | Cold WX Package | Navigation, Voice | RTTI | PDC | L7 | HD | I-Pod/USB | PWR rear shade | Sports Auto - paddles | Active Steering | Comfort Access | Fold Down R/seats | Rear DMS Airbags | Adaptive Xenons | Now with recalled and replaced -446 HPFP Do not argue with an idiot else he lowers you to his level and beat you down with experience.. |
#217
2010 5 series wagon
This thread has been very helpful and informative - thanks to all. I'm looking at a 2010 535xi wagon. I'll certainly check with the dealer, but did BMW fix this issue when they produced this version of the wagon? Many thanks.
#218
AFAIK, the sunroof design remains problematic through all E61s. It is easily checked:
1) look for water in the bowels of the boot, under the spare and the electronics; 2) open the sunroof with the car on a slight upward incline. Pour a small amount of water into the outside - OUTSIDE, mind you - gutter around the sunroof. It should very quickly find its way to the drains and come out behind the rear wheels. If you have problems, blow some compressed air up the drains from underneath. I ask the dealer to check the drains every visit so that I get a written record of their condition. I think they might be less inclined to try to put one over on someone who has been watching for the problem for donkey's years.
#219
Also remove the left and right side (first aid kit cover) panels in the wagon trunk area, if the roof is leaking and water is wicking you can see it drip down both sides.
#220
Thanks for the articles. I think I used the original one dated back in 2006 cause that one mentioned the wagon model in the article. I'll try again with yours and see if they will do anything. Keeping my finger crossed. |
#221
Sunroof drain leak
Most sunroof leaks are caused by clogged drains. Best to have dealer blow them out with a compressor. It's so common there is a class action for BMW, Mercedes, Lexus and Acura owners to recover the cost of repairs and for any water damage to the car. Send me an email or call 1-800-279-6996 for details on getting your money back and for free damage repairs.
#222
Known that this is an issue after getting tagged last September.
Been keeping an eye on the rear trunk compartment for any water issues. It has always been clean and dry every time I check since the "fix". Washed the car last Wednesday at the car wash, and as always I check after for water. Rained Thursday night and flooded the compartment. Noticed the bells of death upon startup before driving. Immediately shut off the car, vacuumed out the water and dried off everything I could. Now... after resetting every code I could I still get shadow codes that will not go away on the body section. The rear lift gate will make noise but will not raise on its own anymore, though it will close itself. Every time someone gets out of the car the rear gate lock goes through the snug and lock cycle. Any advice here on how to troubleshoot these issues? I don't want to go to the stealer, and BMWNA can b*^w me. Last edited by BMPEOPLES; 04-18-2011 at 01:50 PM. |
#223
And now a really stupid question--do you think I need to use a pro-style compressor, or could I use compressed air in a can of some kind? I love driving my 2008 535xi sport wagon, so I've got to stay on top of this--thanks so much for your insightful comments. |
#224
I would be really careful about using high pressures, as people have mentioned before you don't want to blow the hose off the sunroof cassette tube fitting.
#225
My 2008 Certified Pre-Owned530xi wagon has been in the shop for two weeks. While, driving in the last heavy rain, all of the electronics suddenly started to fail and the warning lights came on telling me that it was not safe to continue to drive the vehicle. I had it towed to the dealer and I now come to find out that water had collected in the spare tire well frying all of the electronic modules. I was told it was a result of a roof drain clog. Of all things. Now the SA wants me to pay over $3500 for the repairs and tells me that my expensive extended warranty won't cover water damage. I called BMW customer service and got the same answer. I have found this thread very interesting and am armed with new knowledge. If anyone is involved in a class action, I am in.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
