Burning smell of oil coming out of vents inside of car - Bimmerfest - BMW Forums
Old 02-02-2008, 09:34 AM
flyboyy's Avatar
flyboyy flyboyy is offline
I glow in the dark
Mein Auto: 2003 BMW 530i
I have burning smell of oil coming from the vents inside of the car, the problem is it happens whenever it wants, so far It has happen about 3 times, after a while of driving, maybe 5 minutes the burning smell will disappear.
I did get a S.E.S light come on few times as well in the past, I took the car to Autozone and they read the code as Spark plug misfire error code.
my car was shaking alot once it started up in the morning, but after driving a little bit the car felt like normal again, the S.E.S light stayed on for a few hours of driving without any problems, I then turn off the car because I had to goto the store to buy something and when I came back out, I started the car and it was fine, the light was off, and everything was normal again.
anyone experience smell of burning oil from the vents inside ? or experience the same problem that I am having ? any opinion would be helpful, what should I do next ? Thanks.
btw I have a 2003 530i with about 53k miles on it.
Old 02-02-2008, 11:20 AM
lild's Avatar
lild lild is offline
livin the 'Fest
Mein Auto: 97' 528i, 06 ninja
you got an oil leak. the vlave cover needs to be replaced.oil is leaking onto your exusht which is why your getting the oil smell in the car. and the shaking is comimg from oil getting into the cyl. and on the spark plugs. it is a common problem on these cars. use the serch engine and look up oil leaks or valve cover replacement
The more you complain, the longer God makes you live. SPHOBA #00002
Old 02-02-2008, 11:27 AM
dboy11 dboy11 is offline
Mein Auto: 99...540i
Plus on this!!
Do a search on valve cover gaskets for the e39 there are plenty of DYI on the subject
Its Going To Cost How Much???????
Old 02-02-2008, 12:15 PM
poolman poolman is offline
Mein Auto: 525i station wagon
Here's a good how too on doing your valve cover along with ---well---read the whole write up--
http://www.beisansystems.com/procedu..._procedure.htm
1bad540's Avatar
1bad540 1bad540 is offline
could also be the oil seperator, have a good shop check it so youdont waste $$ on nothing
[SIGPIC]
e39 540i sprt, acs type 2's,acs pdls,clrs(sold)
e65 745i sprt,21's aib's acspdls, rf splr(sold)
e46 328i 18" 335spt whls(sold)
c5vette 6sp,z51,2"drp,19"ccw'sshrt shft,corsa exh,dd nav(sold)
e53 X5 3.0, pna rf,nav,xnon,cldwthr,20"4.6rims.(sold)
e65 750I aw, sprt. 21's,acs pdls,acs rfsplr,mtecs,8k hid(sold)
Srt10 VIPER, 19-20" forged,tune,corsa ex,intake.
w221 S550 amg,dia white,5%3m tint.20"s63rims,lwrd
e70 3.5 aw.mtec, powdr blk whls.
e46 M3vert,6spd,19"HRE,bbk,ext,intke
Old 02-03-2008, 04:20 AM
If it were the crankcase vent valve-he would not smell oil inside the car--he has an oil leak
that is being oxidized and then floated into the cabin--hence the valve cover gasket
shows a great perpencity for chance------
Old 02-03-2008, 06:11 AM
devroots's Avatar
devroots devroots is offline
Mein Auto: 98 528i
Originally Posted by dboy11 View Post
Plus on this!!
+2 on this I had the very same symptoms with my 528 & it turned out to be the valve cover gasket too.
Old 02-03-2008, 07:57 AM
Steve530 Steve530 is offline
Mein Auto: 2001 530i
First, check your oil level. If you have a leak, the level might be low and that's not good.
I replaced the valve cover gasket on my 2001 530i a few months ago. The odor was the first thing I noticed. The oil leaks out around the cover, drips onto the exhaust manifold, and burns. If you look at the exhaust manifold, you may find oil stains. In my case the leak was worse after driving hard. I think the increased engine speed raises the level of oil under the valve cover above the gasket.
The gasket I replaced was very brittle. It came off in one piece, but broke in half when I held it in my hands. Replacement was easy and just about any BMW I6 DIY will give you enough information to do the job.
Here's a few tips:
Get a good low range torque wrench and torque the bolts in stages. You want the pressure on the cover to be uniform around the circumference.
When you buy the gasket, get a the seals for the bolts. I think you can re-use the seals (I did), but if you find one that you need to replace, you can't finish the job. I'd probably buy a few spares, but some people just replace them all.
Apply sealant where the DIY instructs and wait a couple of minutes for it set.
Old 02-03-2008, 09:36 AM
1bad540's Avatar
Definately replace the seals around the bolts otherwise your doing it for nothing, those seals are just as old and you want an even seal around...
[SIGPIC]
Old 02-03-2008, 10:44 AM
turbobladz turbobladz is offline
Send a message via MSN to turbobladz
Mein Auto: 2003 525I
yup 100percent valve cover gasket, happened to me , the dealer replaced it under warranty
A Friend will bail you out of Jail, A best friend is sitting next to you telling you how cool that was!
Old 09-26-2008, 06:16 PM
flyboyy's Avatar
I glow in the dark
how much is to replace valve cover gasket ? and the seals around the bolts ? from an indy shop ?
I get this burning oil intermitten...it does not happen all the time.... its like..really werid.. i did not get it for a while...and today i got the burning smell again......
Old 09-26-2008, 08:33 PM
Vadim540i's Avatar
Vadim540i Vadim540i is offline
Coole Russen
Send a message via MSN to Vadim540i
Mein Auto: e39 540i/6, Lexus GS430
Replace your valve cover gaskets.
Jet black 1999 BMW 540i 6 MT
Black SC'd Lexus GS430
Old 09-26-2008, 09:39 PM
lild's Avatar
livin the 'Fest
he already knows
Old 09-27-2008, 05:20 AM
gtxragtop's Avatar
gtxragtop gtxragtop is offline
Mein Auto: 2003 530IA
Common problem. It tends to leak externally on the pass side outside corners. Especially the rear corner. I just did mine for this exact reason. It was only seeping, never enough to create a spot on the driveway. Never enough to lower the oil level. Drove me mad for months due to being so intermittent. It was there when I bought the car from BMW dealer. I brought it back and they did not find this, but thought it was a leak on the oil filter housing which they replaced. Another reason dealers suck... (A) common problem with I6 E39 (B) did not look close enough to realize what the issue was. Despite this being a CPO, I replaced it myself. Wanted it done right. YOU MUST HAVE an inch pound torque wrench to do the job properly.
Hah, your next common issue will be the rear door vapor barriers (sound insulation) on the rear doors. One day after a driving rain you will have damp or soaked rear floors.
