E36 (1991 - 1999)
Old 02-07-2008, 12:07 AM
inspir3 inspir3 is offline
Mein Auto: BMW 316
Question: Shaking and jerking car, RPM going up and down
Lately, the car seems to be jerking and shaking and the RPM goes up and down while stopped at the lights or stationay. The jerking lessens when i put it into neutral. It is a automatic '94 316 model BMW
Old 02-07-2008, 12:14 AM
Andrew_BR Andrew_BR is offline
Yep...Im from far away...
Mein Auto: German 95 325i Coupe
Only on low RPMs? or always?
It may be spark plugs or cables....
Old 02-07-2008, 02:08 AM
Mein Auto: BMW 316
RPM moves up and down only when the car is stationary i.e stopped at the lights. sometimes when the RPM goes up n back down quickly the car jerks forward a bit.
Old 02-07-2008, 02:09 AM
stephenslyman's Avatar
stephenslyman stephenslyman is offline
Send a message via MSN to stephenslyman
Mein Auto: 525mtech|'74 o2tii|e36
few things..... from my experience. il go from easy to not so easy.
a) cracked in your air intake pipes.(check for cracks around idle control valve part number 6 on link) the cracks can take in unneccesary air and messing with the fuel - air ratio. which happened to be a problem for me.
http://www.realoem.com/bmw/showparts...81&hg=13&fg=15
b) the idle control valve could be faulty.(i bought new one and wasnt the problem for me!!)
c) o2 sensor http://www.pelicanparts.com/bmw/tech...-O2_Sensor.htm
d) gunk in your engine throttle bore
http://www.2carpros.com/how_to/how_to_tune_up.htm
e) check your plug leads for cracks, they might be arcing off the engine head.
to date i fixed all these but my car still idles irratically sometimes so i still haven't got a complete fix but its ALOT BETTER THAN IT USED TO BE
Steve
666, the beast *September 16th* 2002 tii BEAST is ALIVE.. ITS A LITTLE DEMON!
back wheels will spin allllll daaaaay long! its impossible to drive this thing without a grin on your face.
Old 02-07-2008, 02:28 AM
Mein Auto: BMW 316
thnks alot for that. i'll take a look at those things. update ya on any improvements!
Old 02-07-2008, 03:54 AM
Pirate_copy's Avatar
Pirate_copy Pirate_copy is offline
Still here
Send a message via MSN to Pirate_copy
Mein Auto: M3
Could also be your Intake Temp Sensor. Mine is playing up too and just keep forgetting replace it
Get your codes pulled, you may just get an error code if your car supports it. if it doesn't work after a few attempts, you will need to get a scan tool or get a garage/Autozone to pull them for you - http://www.forum.edirty6.com/showthread.php?t=65 (top post)
330i M-Sport in Topaz Blue
Edirty6 for life
