Old 04-14-2003, 10:46 PM
Ron Stygar's Avatar
19,585 Miles
Instument cluster sport mode indicator
Can someone with an automatic transmission non M-Z3 with front fog lights respond if their is an instrument cluster indicator when the tranny is in sport mode?
In my '01 M coupe there is a sport mode indicator where the normal front fog indicator is on the non M-Z3's. When I posted this, someone said that it was for the automatic transmission sport mode. Made sense at the time.
My guess is that the transmission in sport mode does not light an instrument cluster indicator since this place is already taken by the front fogs.
My coupe has neither front fogs or an automatic.
My guess, again, is that this is for the throttle related sport mode in the S54 M-Z3's.
If the case, I'm curious what switch (and its location) they planned on using.
Old 04-15-2003, 03:33 PM
01silber's Avatar
01silber 01silber is offline
Im here
Send a message via AIM to 01silber
Mein Auto: 2001 Z3 3.0i
ill email me friend now and ask him
ill get back with you this evening
Old 04-15-2003, 04:19 PM
01silber's Avatar
Im here
Ron i spoke with goldy and he has a 2000 z3 2.3 or 2.8 well its not a m// and it is the automatic w/front fogs and he said there is no sport button at all , only dsc
hope this helped
max
Old 04-15-2003, 08:33 PM
acao acao is offline
Respect my authoritah!
Mein Auto: 2001 M Coupe IR/IR
If I recall correctly, there is no "sport" mode. The comparable feature is Steptronic. The indicator for that is on the information center underneath the speedometer.
2001 IR/IR M Coupe
Old 04-15-2003, 08:41 PM
Ron Stygar's Avatar
19,585 Miles
Originally posted by acao
[B The comparable feature is Steptronic. The indicator for that is on the information center underneath the speedometer. [/B]
The M sport instrument cluster indicator is in the same spot as the non M front fog instrument cluster indicator.
Old 04-15-2003, 09:58 PM
DanT DanT is offline
Cars Suck
Mein Auto: I drive your cars
ok Ron shot in the dark here but is this what youre talkin about??
Cars Suck
hmm
Old 04-15-2003, 10:18 PM
Cars Suck
oops sorry
I think this one should work.
Old 04-16-2003, 06:04 AM
DannO's Avatar
DannO DannO is offline
Mein Auto: //M Coupes
What document is that from?
Old 04-16-2003, 06:07 AM
Randy Forbes's Avatar
Investigative Tinkerer
I was just about to ask the same question...
Looks like I did!
Randy Forbes
2001///M Rdstr Steel Gray
Old 04-16-2003, 10:49 AM
hdd3md's Avatar
hdd3md hdd3md is offline
//m-powered
Mein Auto: 2013 X5M; 2010 535XiT-MSp
wait a minute!! does this mean....
ron--
am i reading between the lines? is there a sport mode that is possibly accessible on our S54s that might be activated by modulating a -12v signal to our ECUs?????
is there a "sport" mode on the M3s (non-SMG manual or automatic) that can make things more aggressive??
i am in vacation in miami, and my sister's Z4 has a sport mode button (its a 2.5)... ps by the way ron, would you like any pics of anything in particular on that car (for future planning??)? i would be more than happy to comply!
thanks
ps interesting post at other board:
same discussion on another forum....
Old 04-16-2003, 02:21 PM
Ron Stygar's Avatar
19,585 Miles
Question reworded
hope this helped
max
I thought that the Z3's with automatic transmissions had a transmission sport mode.
If so, when a Z3 with an automatic transmission places the transmission in sport mode, does it light an instrument cluster icon?
Old 04-16-2003, 03:22 PM
Maybe a clue?
I got on the Owner's Circle and downloaded the Z3 3.0i manual for 2001. Ron's car is a 2001 I believe (just in front of mine from County Line). Not that the manual is absolutely authoritative, but the stuff here jibes with what I saw on a Z3 3.0i auto I drove frequently.
In this pic, we have the instrument cluster showing the foglight indicator on the lower left.
Name:	z3 instrument cluster.jpg
2001 IR/IR M Coupe
Old 04-16-2003, 03:25 PM
01silber's Avatar
Im here
Ron sorry if i wasnt clear, his 2000 2.5 z3 with automatic/steptronic has no sport button at all and it does have front fogs
also went by my dealer they had a 99 z3 with auto and it had no sport button either
Another page of the manual
In this pic, we have a description of Item 13 from the instrument cluster illustration. As you can see, Item 13 points to indicators and warnings for front fog lamps and engine electronics. BTW, the engine electronics on page 22 have no reference to sport mode-- just your standard EML light, etc.
Name:	z3 instrument cluster description.jpg
2001 IR/IR M Coupe
Old 04-16-2003, 03:27 PM
Z3 Sport mode
Finally, I've attached a picture from the Z3 3.0i manual page that references Sport Program. The indicator shows up on the gear indicator along with the odometer. S1 - S5 indicates Sport/Steptronic.
Name:	z3 sport mode.jpg
2001 IR/IR M Coupe
Old 04-16-2003, 03:57 PM
Re: Question reworded
In an X5, when the shift lever is moved towards the driver (lhd), an indicator changes from D to S. Once you manually downshift/upshift, the S changes to a Numeral (1-5 depending).
Never having driven one, I would guess that the Z3/auto works along those same lines.
Randy Forbes
Old 04-16-2003, 04:33 PM
wernst wernst is offline
Mein Auto: 2000 Z3 2.8
On a 2000 Z3 (non M) with an automatic transmission, the tranny is in "normal" mode when the gearshift lever is in "D" and the Automatic/Manual switch is in "A."
It is in "Sport" mode with the gearshift in "3" and the switch in "A." This has the effect of locking out overdrive, changing the shift points, and allowing engine braking to occur. There is NO indicator light on the dash.
The AT is in "Manual" mode when the Automatic/Manual switch is in "M." Then you move the gearshift to either 1, 2, 3, or D to pick and hold a gear. Again, there's no dashboard indicator when in manual mode either.
-Llama
Old 04-16-2003, 05:18 PM
ARC///M's Avatar
ARC///M ARC///M is offline
Mein Auto: BMW 01 M Rdstr 00 M Coupe
Fire Storm
I thought that light(sport) lights up when you when you beat your handicap on the links Or ya beat Ron down route eleven in a side by side.That listed document has a lot to say.?
Old 04-16-2003, 05:39 PM
Ron Stygar's Avatar
19,585 Miles
Re: Fire Storm
You will think that your light is not working.
Put the fan back on.
Old 04-16-2003, 05:43 PM
Ron Stygar's Avatar
19,585 Miles
Re: Re: Question reworded
Yes, the Z3 steptronic one does.
Looks like the instrument cluster sport light in the S54 M-Z3's was for sport mode (throttle) that BMW chose not to enable.
Old 04-16-2003, 06:05 PM
01silber's Avatar
Im here
i assume this is not a hidden item on the 3.0i
Old 04-16-2003, 06:18 PM
01silber's Avatar
Im here
Ron
so sorry to bother you about this , ive searched the etm and etk but i am unable to understand how to look up wireing connectors for certain parts , i need to build a harness and need the oem connectors but , in the etk they are not labeled for a specific conntector, what am i not seeing on the disc to look up the connector
max
Old 04-16-2003, 06:39 PM
Max,
Have you got the ETM (electrical troubleshooting manual)?
That's where you'll find real in depth info on the wiring, location of connectors and all.
Randy Forbes
Old 04-16-2003, 06:47 PM
Ron Stygar's Avatar
19,585 Miles
Have no idea.
