Old 02-11-2008, 08:01 AM
pbum5 pbum5 is offline
Mein Auto: BMW 328i xDrive
Final warranty service 2004 X3 3.0
Hello All,
My wife has a 2004 X3 3.0 that we purchased last year.
It is indicating that it I now due for an oil change. It is still under the BMW warranty for service so we would like to take full advantage of the final warranty service.
What should we ask to have done?
-Oil Change
-Brake fluid Change
Anything else?
Thanks.
Old 02-11-2008, 08:04 AM
Andrew*Debbie's Avatar
Andrew*Debbie Andrew*Debbie is offline
resU deretsigeR
Mein Auto: Leaf Tekna
Before you take the car in:
Look at the hoses and the belt. If any are worn, ask for new ones.
Go over the entire car and check everything for correct operation. Check all the lights. Check any accessories you don't normally use. If possible, make sure the AC works. However, if it is really cold, you may not be able to get the AC compressor to come on.
Check that the parking brake will hold the car.
At the dealer:
Ask the service adviser to check the service history of the car. As you know, coverage expires 4 years after your car's original in-service date. Ask what is due before coverage expires.
Ask them to check the brakes. If you are 3 or 5 months away from a brake job, it may be worth spending the $$$ to buy a maintenance extension. You can get that at a discount and you can buy it from any BMW dealer in the US.
Tell them wipers streak the windows. They will give you new wiper blades.
Ask them to check the thrust arm bushings.
The models and equipment (standard and optional) illustrated in this post reflect my misunderstanding of vehicles supplied by BMW AG to the German market. In other EU member states, the truthyness of my posts may vary. Please ignore this post. Subject to change.
Old 02-11-2008, 11:21 AM
Mystic1's Avatar
Mystic1 Mystic1 is offline
Mein Auto: '11 328xi, '09 550i
^^^What A*D said. Might want to check to see if the brake fluid has been changed within the last 2 yrs also as that is a 2 year interval item.
Old 02-11-2008, 12:13 PM
sfca-325i sfca-325i is offline
humanum est errare
Mein Auto: which day is this?
Since you have a 2004, roll up all the windows. With the radio off, do you hear creaking as you drive slowly over irregular road surfaces? The window guides/door deals have gone through a number of permutations since the 2004 model year, as creaking seals were very common. I am planning to have my seals replaced just before the warranty expires (yes, they are creaking, now).
David
2004 e83 3.0, 2003.5 e46 M3 Cic, 2008 e9x 335xia, 2008 Sienna XLE Limted AWD
Gone: 2006 B7 A4, 2003 Honda Pilot EX-L RES
Old 02-11-2008, 02:29 PM
mumsa mumsa is offline
Mein Auto: x3 3.0
My 2004 x3 3.0 will come off the warranty period on 3/31/2008. After 4 years only 34k miles. Last year I had Inspection I performed. Brakes are still good since I try to take it easy on the pedal. I do not plan on buying the extended maintenance and will just "pay as I go". I'm concerned that I will not hit Inspection II (60K) on the extended maintenenace and then I will have wasted the $ on the ext maint program.
Old 02-11-2008, 02:49 PM
resU deretsigeR
Yeah. You need brakes and inspection II to make it worth the price.
Old 02-11-2008, 05:08 PM
Eric in SD Eric in SD is offline
Mein Auto: '03-540i/6
Radiator Flush and fill due every 4 years. Ask for an inspection I. Plus what everyone else said. The dealer should be on your side with this, since they get reimbursed by BMWNA.
Lift up your floor mats and check your carpets for dampness. Report any dampness you find.
Eric in SD - '98 M3/4, '03 540i/6, '04 MC, '08 X3
Old 02-11-2008, 05:59 PM
Thanks for the advice..
Any more??
Old 02-11-2008, 09:07 PM
AzNMpower32's Avatar
Tar Heel Faithful
If it's not broken, don't fix it.
If the passenger airbag off light comes on intermittently with a passenger occupying the seat, tell them this. There is a service bulletin out for this, where the seat mat sensor is replaced under warranty.
Old 02-12-2008, 10:10 AM
bmwadam bmwadam is offline
Long LIVE ZFHP22!
Mein Auto: 2006 330i 6MT Sport
One more thing.... Roll down all of your windows, then roll them up. Do this on each one individually and listen for a "popping" or "creaking" sound. This is the early signs of a failing window regulator. These are common failures on these cars. I was able to convince them to replace the two of mine that were doing this. If you wait until the CPO kicks in you have that 50 dollar ded. to deal with. Best to get them now if you can....
The DIYer BMW rant:
Cursed plastic impailor waterpumps, plastic bleeder screws, m20 timing belts, anti rattle clips, window regulators, CDV valves, digital odometer displays, evaporative emissions circuit, aux cooling fan, sunroof drains, heator cores, door seals, control modules, M62 cam covers and of course GM autos.... (more to come)
Old 02-12-2008, 12:39 PM
Tar Heel Faithful
Oddly enough, the window regulators seem to be holding up alright. Time will tell though.
There is a service bulletin out for noisy window regulators though, so if any one of them present a problem, go ahead and get it fixed.
Old 02-15-2008, 12:41 PM
Thanks for the info and Tips.
I made an apt. for Tuesday..
Old 02-20-2008, 06:21 PM
Thanks for the advice. They has to keep the car over night but.
-Got the oil changed
-New wipers
-New blower motor (fan was making a noise)
-New Tensioner for the belts
-Window guides cleaned and lubed.
-Tires rotated (had to pay for that)
The said the rear brakes will need to be replaced soon. Don't know what soon means but I hope it's in less that 5K or September when the warranty runs out.
Old 02-21-2008, 01:42 PM
Mein Auto: x3 3.0
-New wipers
I was wondering why the tires were rotated. I thought that the X3 does not require tire rotation.
Old 02-21-2008, 03:19 PM
diehlryan diehlryan is offline
Mein Auto: Audi TT and X3 3.0
-New wipers
Quit being easy on the brakes and see if you can get the rears to wear enough within 5k and a few months to warrant a change.
Old 02-21-2008, 04:30 PM
dashiell dashiell is offline
Mein Auto: '08 X3 AT loaded no nav.
BMW told me not to rotate the tires on my X5, they said the amount of extra wear I would get was not worth the risk driving it while the rotated tires were not re-worn in.
Old 02-21-2008, 08:33 PM
Yeah, I asked for the tire rotation because it is force of habit with my other cars. The service manager said that BMW does not require it, mostly because many of their cars have staggered tire sizes. My X3 does not so I figured it couldn't hurt.
Brakes - It's my wife car and she babies it so I doubt that will happen.
Old 02-22-2008, 08:25 AM
Long LIVE ZFHP22!
Its best to rotate the tires, I do it every 5k, unless of course they are staggered. I know what BMW says about rotating, them, But I dont care. I need my tires to last me! Ive never had any problems with uneven wear issues, if you go easy on it, and rotate frequently, wear should not be an issue...
The DIYer BMW rant:
Old 03-13-2008, 10:35 AM
islandbuds islandbuds is offline
Mein Auto: 2004 x3 3.0
Talking Many thanks to all in this thread!
Just picked up my 04' for it's final service warranty call with 49,650 miles. As a direct result of the incredibly helpful information found here, blower motor replaced, both rear window regulators replaced, oil service, front and rear wipers, and other misc to the tune of almost $1,500 of covered repairs. If I had not known what to look and listen for from all of you I do not think that any of this would have been discovered until it was too late. As an aside I would lve to post pics of mine but being a certified " tecnology dinosaur" It will have to wait until my son "helps".
Thanks again,
Old 03-13-2008, 04:29 PM
MPBX3 MPBX3 is offline
Mein Auto: 2004 X3
Thanks again,
Was the blower motor and the rear window regulators broken or did you just wanted them replaced?
Old 03-14-2008, 09:45 AM
although there was some associated noise with the fan when the vehicle was turned on I would have not placed the blame on the blower but the tech informed me that the blower motor was in fact "bad". With regards to the rear window regulators I told the tech that there was some popping noise when the windows were being raised and again the tech said that the regulators were either bad or going bad. I also advised them that one of the reverse indicator lights was not working. They said that the housing was loose and they replaced the bulb. Now neither of them work.
Old 04-19-2008, 08:59 AM
An update. Just had all 4 Brake pads, sensors and rotors replaced at 47,500k. Good timing. Not sure how much that saved me.. Now have a little rattle in the exhaust. Got to take it back in soon.
