Old 05-16-2008, 11:14 AM
x3ml x3ml is offline
Mein Auto: X3 2007 3.0si AT
Originally Posted by Snow-man View Post
Just curious....I was looking at a 1 series the other day and I noticed the transmission mfg said, French.
Is this the same AT as the X3?
Think it goes like this:
E82 AT:
128i GA6L45R (GM)
135i GA6HP19Z (ZF)
E83 AT (2007-08):
X3 3.0si & 3.0i(Canada) GA6L45R (GM)
X3 3.0sd GA6HP26Z (ZF)
E70 AT:
X5 3.0si & 4.8i GA6HP19Z (ZF)
Cheers!
Old 05-16-2008, 06:38 PM
jdeday's Avatar
jdeday jdeday is offline
Send a message via AIM to jdeday
Mein Auto: 2005 BMW X3 3.0
Originally Posted by Havelcek View Post
Hey guys...haven't posted in a while because I've been busy with work but I have turned 5K miles on my '08 X3 and the transmission is still as bad as ever. I am counting the months until the lease is over and I can get a different vehicle. In the meantime I'm making it a personal challenge to dissuade as many people as possible from buying a new BMW. Cheers!
Havelcek,
What is the build date of your X3?
Thanks.
Jeff
2005 X3 3.0, Mystic Blue Metallic, Sand Beige Leather Interior, Birch Grain Light Wood Trim, Steptronic Transmission, Premium Package, Heated Seats, Privacy Glass, Satellite Radio Prep, Xenon Adaptive Headlights, Heated Steering Wheel, Premium Sound, Power Folding Mirrors and NAVIGATION RETROFIT
Old 05-16-2008, 09:11 PM
AshesBMW AshesBMW is offline
Mein Auto: 2007 328XI
There must be a lot in common with the 3 and the X because we have had the same complaints about the transmission in our 07 328XI (lag, delay, hard down shifts,) as you all describe in your 07 and 08 X3's.
I did a search on the 3 series section and didn't find much but there is plenty of info here.
BMW tells us that it is programed to start out in second gear to save fuel and that this is normal operation? I'm thinking we need to say we don't accept this and we want it fixed now? Has anyone else heard of this problem in a 3 series car? I'm going to post this over at the 3 forum as well. Thanks!
Old 05-16-2008, 09:24 PM
AzNMpower32's Avatar
Tar Heel Faithful
The gearbox is programmed to start in 2nd if it is a short stop, i.e for a stop sign. If you've waited at a stop light, it should start in 1st gear. This isn't anything new; older BMWs did this as well.
Old 05-16-2008, 09:49 PM
Seems to me like it does it all the time but I will pay more attention at a stoplight to see if it does it there. It also has a huge lag when you step on it to pass. It takes it about 2 seconds to finally shift down. We also get some hunting between 30 and 45 mph on level driving. It's her car but I will drive it a little more to get a better feel of what it is doing. Thanks for the reply!
Old 05-16-2008, 10:28 PM
E90 Automatic Transmission (GM or ZF?)
The problem with "lag, delay, hard down shifts" is not related to starting out in 2nd gear. I have driven different 3 series and X3's and they all start out in 2nd gear in the D mode. Not only should it save gas, it should give you a little more comfort by saving a gear change. It's completely normal. At the same time, having lag and delay is NOT acceptable.
By the way, interesting to note that your 328xi has the "same complaints"...
E90
323i 2006 GA6HP19Z or GA6L45R
323i 2007 GA6L45R
325i & 325xi 2004-2006 GA6HP19Z
328i & 328xi 2006-2007 GA6L45R
330i & 330xi 2004-2006 GA6HP19Z
335i & 335xi 2006-2007 GA6HP19Z
I think 323i not available in US?
Old 05-16-2008, 10:44 PM
We have this car at the dealership 3 times with these complaints and keep being told that can't replicate and it it operating "normal". So I did a search and end up here with the x3's. most of the descriptions here are exactly what we have been saying to the dealership. one can't help but wonder?
Old 05-16-2008, 11:00 PM
Wonder? Wonder no more... G-A-6-L-4-5-R
Old 05-16-2008, 11:55 PM
So how do I know if my 328xi has the GA6L45R transmission? Is there a door code? Thanks!!
Old 05-17-2008, 01:18 AM
Snow-man Snow-man is offline
Mein Auto: 330Xi, Acura RDX, 968
AzNMpower32, once again stick to what you really know. What should happen and what does happen are two different things. If you wait at a stop light slap it over to SD and you will see it does not start off in 1'st gear , but 2'nd unless you force it down to 1'st. The 5 speed may have done this but the 6 speed AT definitely does not revert to 1'st gear.
Old 05-17-2008, 07:52 AM
MJS MJS is offline
HMFIC
Mein Auto: 2002 ///M3
My 2007 X3 starts in 1st gear in D mode. I've confirmed it numerous times by counting the gears. If I use Manual mode, it starts in 2nd. I don't use SD mode because it FVCK1NG SVCK$!
46 & 2 just ahead of me...
Old 05-17-2008, 09:10 AM
Ga6l45r
How can you tell? When you have a BMW 6 speed automatic transmission that is a mess and your dealer keeps telling you "no problems", "cannot duplicate" and "it's the characteristics", you have a GA6L45R GM transmission!
I think this GA6L45R is so much of a problem that's why even Vatkens' too scare to touch this subject. I have driven a 323i (07) loaner and I can swear it has the same GA6L45R because it has pretty well the same "characteristics". Too bad the dealers can't hide so they have to play along with this approach.
Ashes, I found a March 07 CNET review of the 328XI and this is what they say about the AT:
CNET:
Acceleration in the standard drive mode feels sedate, but greatly improves in the sport mode. We found the accelerator was difficult to get used to, and we could never really tell when we were going to get power. Sometimes there would be lag and sometimes not. Regular drive mode produced acceleration lag, while sport mode minimized it. But even in sport mode we sometimes got odd lags while cornering. We could never quite pin down how to use this accelerator to get consistent performance.
Link: http://reviews.cnet.com/sedan/2007-b...-32329714.html
So, I think your 328XI most likely "normal".
Old 05-17-2008, 02:48 PM
Oh boy isn't that great news! Well next trip to the dealer we make a much bigger deal out of this. Thanks for all your help!
Old 05-19-2008, 08:35 AM
burtbmw burtbmw is offline
Mein Auto: 2008 128i, 2008 X3
2008 X3
Not sure if we just were lucky or there has been another "fix", but my wife and I picked up her new X3 in Munich on May 8th and spent 10 days driving in conditions from the Autobahn to the high passes in the Dolomites and the backroads of Tuscany. While I tried to talk her into a manual due to all of the reported problems she insisted on the auto and all I can say is wow. It performed flawlessly in all conditions and drove like a dream. Having the Sport package on the twisty mountain passes and winding through Tuscany was a real bonus and neither of us thought the ride was too harsh even when the roads were less then perfect. We ended up putting over 1,000 miles on during the trip with two long days on the road transiting from Germany to Northern Italy and back up to Munich for the dropoff. We had one transit on the A22 where we hit 115 mph for a prolonged period and it was smooth as silk.
In short, no regrets with the X3 up to this point, but will withhold final judgement until we take redelivery and have the chance for day to day driving in American traffic.
Old 05-19-2008, 09:22 AM
Havelcek Havelcek is offline
Casual Fan
Mein Auto: 2011 X5
Originally Posted by jdeday View Post
Havelcek,
Thanks.
Jeff
October 2007...it was delivered the day after last Thanksgiving. When I took it into the dealer I was told I had the most recent software and was sent on my way with a pat on the head. Silly consumers.
Old 05-19-2008, 09:37 AM
Burt, congrats on your new ride! Thanks for your writeup and maybe you can share some pictures with us too . Apparently, I think BMW do listens and I hope they will make good on those who are having problems in a hurry.
Old 05-25-2008, 12:33 PM
markd markd is offline
Mein Auto: bmw x3
almost got in an accident
Well, I had the major update last year, which actually seemed pretty good. Not perfect, but maybe I could live with it-I thought.
Hesitation was practically all gone. Lately it has gotten worse again.
Almost got clocked while making left turn into gas station today. I had plenty of room to make left turn, but it lunged forward slightly, then nothing!!!!! Then the oncoming traffic was approaching, and beeping their horn. All of a sudden, I got power, and the tires chirpped!
it is weird-you push the gas down, and it does not respond.
Not safe!
I am not happy. I bought it April of 2007. It has been in for this problem at least 5 times.
It is going in again-this time for good!
I want a new vehicle-this is a lemon!
Old 05-26-2008, 07:18 AM
dmbhr1 dmbhr1 is offline
Mein Auto: 2007 x3
I just found this site and it's remarkable how well many describe my '07 x3. My second week of ownership, it quit and was in the shop 9 days. Something with a computer having to be re-programmed and the engineers were all out on holiday. Then the hesitation and down shifting started. It's been re-programmed twice. A lens cover on the driver side had to be replaced and the sun roof rattles so loud, I just close the shade so it's not so annoying. It was supposed to be fixed during the last 8 day trip to the shop for re-programming.I hate to be so pessimistic, but I don't see any change in the downshifting when stopping. I' m sure the hesitation will happen again also. My dealership has been responsive but it's not fixed yet either. My first bmw and I'm so dissappointed!
Old 05-27-2008, 09:08 AM
BMWNA BMWNA is offline
BMW NA Customer Relations
Mein Auto: B M W
Not safe!
I'm with BMW of North America, LLC. I've passed this message on to a BMW NA Customer Relations Representative who will be in touch with you soon.
Old 05-27-2008, 10:08 AM
kjboyd's Avatar
kjboyd kjboyd is offline
Drink the koolaid or else
Mein Auto: 2015 X1 sDrive XLine
Hey Vatkens! where ya been man?
Kevin
2015 X1 sDrive XLine - "Hamilton Maxwell"
2009 MINI Cooper Clubman - "Oxley"
2007 Volvo S60 2.5T
2007 X3.0si PlatBronze/Beige
2006 X3 3.0i, Flamenco Red/Beige
1997 528iA, Oxford/Tan
1994 318iS, Black/Gray
1979 528iA, RubyRed, Tan
1971 2002, Sahara, Saddle
Old 05-27-2008, 10:42 AM
Zoltar's Avatar
Zoltar Zoltar is offline
Your Wish Is Granted
Mein Auto: 2009 X3 MT
And what exactly will they say when they are in touch with you soon?
There are no new fixes, at least none that any of us (or my dealer for that matter) know about.
Is there a secret fix for certain people who complain in a forum?
Old 05-27-2008, 12:26 PM
MJS MJS is offline
HMFIC
I have the exact same problem and have been living with it for a year and half(with all the currently available fixes, of course). Is there a new fix?
Old 05-27-2008, 06:32 PM
Mein Auto: 2007 x3
Well, it happened to me today and only 10 days out of the shop and the latest fix. What happened today was really weird! Not just the usual hesitation that scares the bejesus out of you because you don't move. Today, when I pressed down on the accelerator, the engine raced, the tach rose and it just sat there. Those of you out there, who know what happened, explain please. I'm a female and not as knowledegeable as most of you.
Old 05-28-2008, 08:51 PM
Viking69 Viking69 is offline
Mein Auto: BMW X3 (07), BMW Z4 (04)
Smile A new angle to the problem
Hey everyone,
I've been the owner of an '07 X3 since April last year (built in March) and can say that I share many of your experiences. At first I thought it was just me but after spending some time on the forum I realized I was not alone.
I hesitated taking the car into the shop just for the software update so waited until my first scheduled maintenance. So last week at a little over 17,000 miles the car got serviced. I explained the whole transmission problem to the technician and we test drove the car together. He claimed that it wasn't realy a transmission problem but rather a throttle problem. (Mind you before driving the car he claimed BMW had not recorded such problems.)
He said he had a fix for it so I waited eagerly for my car to return.
After 1 week driving I must admit that it has improved tremendously.
According to the invoice, I received the following updates:
SIB 121707 DME update for poor throttle response
SIB 240807 EGS Update for harsh downshifts
The car behaves totally different. It's always ready to go either from a standstill or accelerating after braking / slowing down. I'm now a very happy owner of an awesome performing X3.
Old 05-28-2008, 09:10 PM
kjboyd's Avatar
give it a month.
Kevin
2007 Volvo S60 2.5T
