X3 E83 (2004 - 2010)
Talk about the E83 BMW X3 in this forum! |
#1626
That would mean unlimited access to all the diagnostic tools - but they would have to proactively keep on top of updates. And they wouldn't have the ability to pull up service records of any BMW vehicle, of course, nor any of the corporate communications. This gives a good description of GT1 and what an indy shop (or individual) can buy to emulate it on a standalone basis: http://bmwgt1.com/ I think ISIS comes in for the newer and faster (than CAN bus) protocol FlexRay. Not sure if any of the later E83's had FlexRay - maybe starting with 2009's? See: http://www.bmw.com/com/en/insights/t.../flex_ray.html So yes, any good indy shop should be able to do the latest transmission update. |
#1627
Thanks for the info Supercourse. According to the indy, if the X3 has been hooked up to the dealership computer systems within the past ~2.5 years, then the software on there is through the ISIS program and they are unable to program things like DRL or 3 click blinkers through SSS. He stated that if it hasn't been in the dealer in the past couple years for anything more than an oil change (which mine hasnt) then the programing/coding is extremely simple through SSS, otherwise ISIS would take alittle more time.
2011 328i SA SULEV Black Sapphire Metallic, Dakota Beige, ZPP, Nav Prod Date: July 1, 2010 ![]() Traded in with 90K Miles: 2007 X3 3.0si Black Sapphire Metallic, Grey Nevada, M Sport Package, Premium, Cold Weather, Navigation, and Xenon. Prod Date: March 2, 2007 |
#1628
I am starting to notice the gear shifting transmission problem everyone talks about.
What will this cost me at BMW to have this fixed without under warranty? Do I just tell them it's a software issue? I basically realize it doesn't pick up the gears 1-2 very well when driving 5-10 miles per hour. It also is worse when the car is not fully warmed up... |
#1629
Thanks man I will keep you posted! Saturday now no one is open. Will call when I get back from vacation. Thanks for the quick reply!
#1631
EE
2013 S4 Loaded (and NO RFT's) Awesome is an understatement 2008 MT X3 2007 AT X3 RIPOS ![]() 2005 GC 2000 Jeep Cherokee 1997 Twin Turbo RX-7 1984 GTI Wolfsburg Edition Neuspeed and more Last edited by Evlengr; 03-10-2012 at 07:00 PM. |
#1632
Remember a "service information bulletin" is not a recall and the service center doesn't fix the SIB's free when you are out of warranty. A recall is another matter and BMW has to fix those free. From what I have seen on the board recently the "goodwill" program that was doing pretty well a couple of years ago is now pretty hard to find, unless you are right out of warranty of have the "right" dealer. Just an observation -- still worth a try however!
#1633
Any idea exactly how I should word it to them? |
#1634
If they say it is up to BMWNA that is a redflag that they are full of $h+t. The goodwill tsb was written to give dealers the ability to make "The Call". Since this is not parts or major labor they should acccomodate given you are only 100 miles out and they should have asked you about it before warranty expired. Good Luck
2013 S4 Loaded (and NO RFT's) Awesome is an understatement 2008 MT X3 2007 AT X3 RIPOS ![]() 2005 GC 2000 Jeep Cherokee 1997 Twin Turbo RX-7 1984 GTI Wolfsburg Edition Neuspeed and more |
#1635
What he said. BTW, its called "Customer Assistance Program" and there is a link to the SIB on the "Pay it Forward" sticky right below this thread. It would help if you read this and printed it out so you would know if the dealer is blowing smoke or not. Good luck!
#1636
I spoke to my BMW service dept. and their head manager was very helpful. He knew exactly what I was talking about even had the 08' X3 himself. I now have an appointment in 2 weeks(needed to be on a week day for this). I had no problem with that and is going to do under as if I still had warranty. So lets hope this works which from all the posts it seems it will. Whether I get charged the $50 service charge or $0 I will be happy that they are doing the upgrade to the software! ![]() Thank you for all the replies and help! |
#1637
I plan to make a visit to my dealership sometime to get the software updated. I have a slight hesitation in between 1-2 gears after the transmission fluid change. I want to give a shot at it by updating the software to see if it helps. Can you tell me where you found all the bulletins? I would like to take it with me to the dealership so that I don't have to fight with them over this issue. Thanks!
Difference between factory reset+operator/driver adapability memory reset
Can someone please tell me what the difference is between the factory/dealer transmission reset and the transmission reset that resets the driver adaptability memory function (the one where you hold your foot down on the gas for 25s)? There have been mixed posts on here if that can even be done on the X3 by yourself. I am still having transmission issues since getting all the software updates (not sure if there is a 2011 update I am missing) but also want to make sure I understand this so that at the very least I can have the dealership truly reset this transmission. Thanks!
Please post a link to the newest SIB for this transmission problem! Thanks! Last edited by sb12759; 04-16-2012 at 05:06 PM. |
#1641
The SIB is an actual change in the way the transmission and engine work together with shifting points. This effectively changes the baseline of that relationship. And UJ, no disrespect intended, but it is NOT a software only issue. If it was there would be no X3's out there with this problem. At least not for as long as it has been (6 years).
#1642
I am not a mechanic but I agree with Evengr that it can't be just a software issue or my car would be fixed. Its been through every update multiple times, reset, etc. That's what BMW gets for putting in an american part as important as the transmission (and the customer gets all the aggravation and problems, thanks BMW)
The first time, with the key in Position 1 where only the fasten seatbelt icon lit up. The second time, with the key in Position 2 where the entire console lit up with all the icons. I pressed the Pedal all the way more than 30 seconds, and have not heard any clicking sound. And obviously I didn't notice any difference, hence why I'm writing this. Any thoughts? |
#1644
This has official been fixed! I can't believe the difference. It is just great to be able to cruise around in the X3 and not have to worry about it. During the day Open Road called me, wasn't the original guy I made the appointment with I guess it was the service guy. He said we couldn't find any problem with the car or anything while hooked up to the computer. I am like well did you drive it and understand my problem? He said we couldn't find any issues but we did the software upgrade for you since your cars production time fell in the time frame. I was over 50k, but since I made the appointment so far out I told them when I show up I am going to be over my miles, they noted the account and had no problem. $0 balance and car drives nice and of course extra clean and vacuumed now after a service appointment! Thanks for all the help I got on the forum page. You all rock! |
#1645
Cheers, EE
#1646
Can you just post the SIB now whilst it's fresh on your mind? And not to risk you forgetting to post it here later?
#1647
The quoted SIB 12 17 07 above has been UPDATED as of 6-2008. The NEW update now lists NEW versions of the DME and EGS software. DME software update version # 7603270 EGS software update version # 7586452 They said they did exactly what I asked for... |
#1648
I never tried it myself. Nothing in this thread?
Madurodave My garage: 2007 BMW Z4 3.0si Manual, 2007 BMW X3, 2006 BMW 530xi Retired: 1998 BMW Z3 Member of BMWCCA! |
#1650
No clear indication that it works for either GM or ZF transmissions. Or both, or neither. Some BMW techs. have been quoted as saying no such reset exists, whereas others have said online that it is real. See: http://www.bimmerfest.com/forums/sho...83&postcount=5 (From a 7 series forum, I believe.) Anyway, I don't think you will hear a click or anything after the 25 -30 secs. - that may be distorted info. arising from the instruction to first press the pedal beyond the kickdown point where you may hear a click. Others say that if it does anything, it puts the transmission into a sport mode (among the 5 mappings it has), and will be effective for the next start only. Can't see that the 25 secs. has to be precise - just that holding the accelerator down that long is interpreted the same as when actually driving with a heavy foot. |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
