E46 (1999 - 2006)
Old 02-15-2008, 08:02 AM
vinitmurthy vinitmurthy is offline
Mein Auto: 2003 330XI
Angry Mechanic says replace secondary air pump
Good fellas,
Three days back my SES light comes on unexpectedly. So, I drive down to Autozone and get the codes read (P0491 and P0492) to find out that there is a problem with the secondary air system. I took it to a local European car mechanic in Albany, NY (Bavarian Rocket Scientist) and he hooked it to some equipment of his own and saw that vacuum pump was not working. He quoted me $325 for replacing the part and $95 for 1 hr labor. He also mentioned that the the air valve seems to be working fine, however, their might be a problem with the circuitry, which might be leading to the apparent vacuum pump problem. So my question to you guys is:
1. Is the $ for part+labor unusually high?
2. Is there a cheaper way to solve this problem?
3. Can I look for something else to narrow down on the problem?
4. Someone on this forum suggested that valve needs to be changed too, with the pump. Is that necessary?
5. Has anyone experienced this mechanic before (Bavarian Rocket Scientist, Albany, NY)?
Any other advice on this issue would be real helpful.
FYI: My car is 2003 330XI with 55K miles on it. The car runs just fine without any startup or continuous operation problems.
Thank you very much, in advance.
2003 Silver 330XI
Old 02-15-2008, 10:31 AM
oembimmerparts oembimmerparts is offline
Mein Auto: 2001 Z3
Originally Posted by vinitmurthy View Post
Good fellas,
It is common practice to do the valve at the same time, The oem pump is $231.00 so if the $325.00 above is not including labor then it is to high for just the part.
Old 02-15-2008, 10:33 AM
G. P. Burdell's Avatar
G. P. Burdell G. P. Burdell is offline
Rambling Wreck
Mein Auto: E46
The failure of the valve is usually what causes the pump to break down. When the valve sticks open, it allows moisture-laden exhaust gases into the pump. The pump doesn't like water.
~$300 for the pump and valve, plus an hour of labor, sounds about average. You can replace the parts yourself if you are so inclined. If you're a BMW CCA member, you may qualify for a discount at your local BMW dealer parts department.
Old 02-15-2008, 12:21 PM
Thanks folks, for your replies. The quote from the mechanic includes only the pump...no valve. How much do I expect for the valve in addition? Also, this one is a little tricky for DIY. I don't have the right tools nor the time for it. I am not a member of the BMW CCA club, either. In fact, I am planing to fix this problem and sell the car...but that's worth another thread.
Any one else has had this experience? Please please let me know.
2003 Silver 330XI
Old 02-15-2008, 03:25 PM
Rambling Wreck
Mein Auto: E46
The valve costs about $100.
Old 07-02-2009, 08:19 AM
mawana's Avatar
mawana mawana is offline
Mein Auto: 330i ZHP
I know this thread is old, but I searched, so my question is: what are the symptoms of a secondary air pump failure? Is this pump the same as the auxialliary air pump or are they different? The reason I ask is I have this growling sound above 4500rpms only in 2nd gear and sometimes 3rd. Various inspections at the dealership and indies have left the 'it's normal sound' but I don't buy it....
Any ideas would be appreciated!
Old 07-02-2009, 08:27 AM
Solidjake's Avatar
Solidjake Solidjake is offline
The one and only
Mein Auto: 2002 330i
The secondary air pump comes on only when you turn on the car (always when it's cold outside) and it helps heat up the O2 sensors and turns off after a minute.
You would get codes if it is failing/failed.
I doubt that it would make any sound if you're driving. The growling is probably something else, maybe a catalytic converter.
_______________Going to Bimmerfest East AND West
Youtube - Electric Fan Swap/Aux Fan Removal - Projector Retrofit - E46 Bulb Guide
Old 07-02-2009, 08:31 AM
jcourcoul jcourcoul is offline
Supporter of Bimmer Lore
Mein Auto: 2006 325Ci
While we're on this resuscitated thread, could someone explain what the secondary pump you guys have on your Bimmers is for? Mine doesn't have one, never has, and none of the local ones I've seen at the dealer do either. So? Does it do something useful, besides keeping the ecologists happy? Or just another failure point (as if we didn't have enough already...)?
2006 325Ci
Old 07-02-2009, 08:38 AM
Solidjake's Avatar
The one and only
You don't have an air pump? Well, I'm just guessing, but it's function is for cold climates and aids in pre-heating the O2 sensors like I stated. Maybe because you are in Mexico where it is always warm, pre-heating is irrelevant.
But what would happen if global warming went crazy and it starting to snow in Mexico? Would your car start properly? Idk, HAHA
Old 07-02-2009, 08:53 AM
mawana's Avatar
Mein Auto: 330i ZHP
... thanx, does a failing catalytic convertor make or contribute to this growling sound. At firts I thought it was the trans, but the dealer dismissed that after spending sometime with the car. When I reproduced the sound to them, they said 'these engines are not supposed to be revved that much', rather I need to up-shift around 3-3.5k always..
Old 07-02-2009, 08:56 AM
Solidjake's Avatar
The one and only
HAHAHA, what a lie. Our cars love high RPM's, but lets not get started on that as we have already discussed that numerous times.
Does the car make any growling sound when you have it in park and rev it a bit?
Old 07-02-2009, 09:03 AM
mawana's Avatar
Mein Auto: 330i ZHP
It's a manual, and no growling sound while revving in neutral. Last week I did the ATF clean-up procedure that Fast-Bob recommends and revved it big-time but no growling sound at all. The moment I'm driving, when in 2nd after 4k rpms, the sound starts building-up and gets really annoying the more I push the car before up-shifting...
I thought of wheel bearings, but one indy I paid $40 to inspect, said they are okay..
Old 07-02-2009, 09:09 AM
Solidjake's Avatar
The one and only
Hmm, how are your brakes?
Old 07-02-2009, 09:24 AM
mawana's Avatar
Mein Auto: 330i ZHP
The brakes were last checked 3 months ago before my 100k mile warranty expired and the tech said I still have lots of pad to go... However, I now have over 50k miles on those pads and rotors. I sometimes get a slight shake over 85mph...I'm not the type that brakes a lot - I usually just change lanes when the driver in front starts braking or brakes when there is room on the other lane.
The rotors though could be the originals since I picked up the car used, but I'm not sure!
Old 07-02-2009, 09:37 AM
Solidjake's Avatar
The one and only
Idk, I would say cats, but that would be all the time.
ZHP owners, any help?
Solidjake's Avatar
The one and only
Old 07-02-2009, 10:08 AM
tturedraider's Avatar
Freedom isn't free!!
Nope, that's exactly what it's for.
I feel sorry for the guy who posted this if he paid for the repair. I'm sorry I missed the post back then.
This problem is probably covered under the federal emissions warranty, which is 8 years/80,000 miles.
My SES light came on one day while I was out driving so I just drove straight to the dealership to get them to check it. They must keep a lot of air pumps on hand, 'cause it took them about a minute to diagnose the problem and they did the repair immediately. I nearly fell over. I've never seen a dealership work so fast.
"People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf." -- Geo. Orwell
Keep Right, Except to Pass
Then & Than usage - "It was hotter than ever (comparison). Then (time) it got cool."
2006 330i Sonora w/ ActiveAutoWerke flash tune - I like it!
2004 330i ZHP Imola/NB - missed
2000 328i TiAg - gone but not forgotten
BMW CCA member #388003 - www.bmwcca.org Use me as a referral, you could win a one day ///M Driving School!
Old 07-02-2009, 11:54 AM
Rambling Wreck
Mein Auto: E46
If you have a failing secondary air pump, you may hear a whistling/growling/screeching noise, or no noise at all, from the pump during the first couple of minutes after a cold start. The bearings can make a racket if water gets into them. An undamaged pump makes a gentle whirring noise, sort of like a muffled vacuum cleaner, under the hood.
See above. If the growling sound persists more than a few minutes after a cold start, then it's not the secondary air pump.
It isn't only for cold climates. The purpose of the pump is to inject extra air (specifically, oxygen) into the catalytic converters to get them up to their operating temperature faster. They have a very high operating temperature (think several hundred degrees Fahrenheit), and getting up to temperature faster lets them treat the engine exhaust gases faster.
Mexico's emissions regulations probably don't require BMW to install the pump on cars sold there.
Old 07-02-2009, 01:03 PM
mawana's Avatar
Mein Auto: 330i ZHP
Originally Posted by G. P. Burdell View Post
If the growling sound persists more than a few minutes after a cold start, then it's not the secondary air pump..
I guess I don't have a secondary air pump problem - ah well, maybe time to start a new thread!
Old 07-02-2009, 02:56 PM
Thanks for the air pump explanation. I'm also quite thankful we don't have to have that, one less doodad to fail. At least there was something good to compensate for the fact that I have to bake my headlamps to install angel eyes!
2006 325Ci
Old 07-03-2009, 12:05 AM
akhbhaat akhbhaat is offline
In vino veritas
Mein Auto: German Civic
That's just it - it warms up the cats and such to reduce emissions a bit on a cold start. That's all it does, and that's the only time it functions. It's a US market thing that goes along with the vacuous orange reflector requirement.
The car will function just fine without it.
P.S. it's not a cold weather issue; European markets don't have a secondary air pump, either.
No significant quantities of judgment-impairing narcotics were consumed during or before the creation of this message.
Old 07-03-2009, 06:46 AM
K.I.M.POSSIBLE K.I.M.POSSIBLE is offline
Mein Auto: 05 X5, 04 S430, 02 325i
Exclamation
I'd also lke to add that if your thermostat sensor has failed ( stuck in the cold Position ), the Secondary Air Pump will run all the time and you will get a SES ligh because the car will run too lean when its warm.
This pump is only supposed to come on temporarily when the car is cold an only for a breif peroid of time during warmup. Otherwise it's just sitting there doing nothing.
Just had the same issue with my 02 and after the thermostat replacement the pump started working when it was supposed to.
Old 07-03-2009, 08:27 AM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2004 ZHP Sedan
Sounds like a classic case of the infamous ZHP VANOS rattle to me.
Check out my BMWBLOG!
Old 07-03-2009, 09:27 AM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
VANOS rattle is most noticeable between 2 and 3 grand, especially on the down-rev....
The road goes ever onward....
(R.I.P. Jever)
*Please support the Wounded Warrior Project*
Old 07-03-2009, 11:14 AM
mawana's Avatar
Mein Auto: 330i ZHP
I had an appointment with my indy this morning - he was suspecting the idler pulley. Upon inspection, he said there is some 'insignificant play' which he highly doubts could cause such a noise. His suggestion is since I haven't done the cooling overhaul, maybe this is the opportunity and include all the pulleys..
He did mention the vanos as well, and is aware of the a/m vanos 'fixes' out there but he said that's a job he is not willing to undertake.
Fast Bob, it's not the vanos, what do you suggest could have failed or is about to fail given this sound and other symptoms I have highlighted?
