Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Do-It-Yourself H.Q.
Do-It-Yourself H.Q.
Share your DIY projects or ask questions about how to fix something on your own. Help fellow Bimmerfest members improve your wrench turning skills! All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need!
Old 04-18-2003, 06:56 AM
mwette's Avatar
mwette mwette is offline
Mein Auto: 03 330Ci 5M SP
brake fluid change on E46
I am considering Driving Concepts school on Jul22. The tech inspection form says brake fluids should be changed semi-anually (vs owner manual 2yr period). My car will be 6mo old on Jun 11. I guess this implies a brake fluid change. What flavor brake fluid? What tools? Maybe a TechSession item?
03 330Ci 5M SP Topaz-Blue/Gray
Old 04-18-2003, 08:31 AM
Nick325xiT 5spd's Avatar
Nick325xiT 5spd Nick325xiT 5spd is offline
Send a message via ICQ to Nick325xiT 5spd Send a message via AIM to Nick325xiT 5spd Send a message via Yahoo to Nick325xiT 5spd
Mein Auto: M3 & 323i/999 KP
ATE Typ 200. Just like superblue, except without concerns that your dealer will give you crap about it.
You NEED six feet of .170 ID clear plastic tubing and a soda bottle. (for waste) You should get a pressure bleeder as well. You'll need a couple small metric wrenches as well.
2006 GMC Sierra 2500HD 4WD Duramax LBZ/Allison 6-speed
2002 BMW M3 Alpinweiß/Black
1999 323i KP/GTS2 Alpinweiß
1990 325is Brilliantrot/Tan
1989 325is S50B30US Alpinweiß/Black
1989 M3 Alpinweiß/Black S50B32 (321hp, ITBs)
Old 04-18-2003, 03:39 PM
2001E46 2001E46 is offline
Mein Auto: 2001 325i
Just curious, why six feet of tubing?
Dedicated to the E46 325i
Website: http://www.bmw325i.net
Email: bmw325imail@yahoo.com
Old 04-18-2003, 03:40 PM
The HACK's Avatar
The HACK The HACK is offline
Rest in peace, Coach
Mein Auto: '06 MZ4C, '09 WRX Wagon
I think Nick meant six INCHES. He's always trying to make 6 inches a lot longer than it really is.
Yeah, come by the TechSession on May 31st, bring fresh brake fluids and we'll show you how it's done.
"Bench racing" about track times driven by professionals are like a bunch of nerds arguing which Princess Leia is hotter, the slave Leia or the no-bra jail-bait Leia. No matter how compelling your argument is, the plain and simple fact is, none of you will EVER get to hit that.
Old 04-18-2003, 08:34 PM
mola's Avatar
mola mola is offline
Mein Auto: E60, E70, E39
yeah about 12 inches works for me...
Old 04-18-2003, 08:36 PM
Well... I personally find that it's a lot easier with lots and lots of slack in the tubing. And at $0.13 a foot...
Old 04-18-2003, 10:18 PM
The HACK's Avatar
At six "foot" it becomes harder to overcome the "friction" inherent in such a long, um, tube.
Old 04-19-2003, 03:38 PM
mwette's Avatar
OK, have patience with me. I went to Pep Boys and Kraagen today. I didn't see any ATE Typ 200, only random DOT 3 types. Is this a dealer item? Also, didn't find a pressure bleeder (Pep boys, Kraagen, Harbor Freight).
Also, with the six *foot* tubing it will take a lot longer to get all the fluids out. Isn't that supposed to prolong the enjoyment of the task at hand?
Matt
Old 04-19-2003, 03:41 PM
Matt
The best thing pep boys will have is Castrol GT LMA.
Go to bavauto.com and order 2 (or 3) litres of typ 200 along with a pressure bleeder there.
I recommend 3 litres so that you have extra in case you screw up. I've been VERY thankful for the availability of extra fluid on one occasion.
I also strongly recommend having a flashlight available.
Old 04-19-2003, 10:15 PM
The HACK's Avatar
Matt
Matt, try Eurasian Autoparts in Temecula, they carry SuperBlue and Typ 200 and if you buy multiple quarts the price drop to $8.99.
And if it's a manual transmission car, be sure to bleed the clutch as well, and it's two liters to bleed all 4 corners plus clutch if you're frugal, use 3 liters if you want to make sure all the old fluid comes out.
Old 04-20-2003, 08:03 AM
mwette's Avatar
Thanks guys. I ordered 3L plus pressure bleeder from BavAuto. Do people purge the reservoir(s) with nitrogen or dry air (to keep water out) before closing up?
Matt
Old 04-20-2003, 09:18 PM
The HACK's Avatar
Matt
Doesn't matter if you're using the pressure bleeder. I haven't had water absorption problems with using the pressure bleeder so I don't bother.
Old 04-21-2003, 12:10 AM
Raffi's Avatar
Raffi Raffi is offline
Hi
Mein Auto: Frankenstein monster
mwette, next time, you can also call Chris Rappas, the owner of XP Engineering, or ordering online at www.xpengineering.com. Chris is a great and very knoweldgeable guy. Tell him Raffi from the BMW CCA referred you to him.
'01 330ci
Old 04-21-2003, 01:29 AM
XKxRome0ox XKxRome0ox is offline
buy my window glass!
Send a message via AIM to XKxRome0ox
Mein Auto: 2001 BMW 325i
where will this be????
R.I.P. BMWPlanet.com Resurrected!
Old 04-21-2003, 09:06 AM
The HACK's Avatar
B&M Racing in Chatsworth. For more information visit www.bmracing.com.
Old 04-21-2003, 01:30 PM
Raffi's Avatar
Hi
HACK, wanna e-mail mwette with the info to join the SCTS e-mail group?
'01 330ci
Old 04-28-2003, 02:32 PM
so... can i safely assume that you can buy plenty of brake fluid and the tubing needed for under $30?
i was going to make an appointment at Pacific BMW for the brake fluid flush for $88.88+tax - $20 service gift certificate = $76.21
if i can get it done at a Tech Session with a little sweat + $30... i guess i should go that route
Old 04-28-2003, 02:42 PM
$32. Three litres of fluid, tubing, small funnel. (Seriously, you need to get the funnel if you're not using a pressure bleeder.)
Old 04-28-2003, 03:06 PM
mola's Avatar
3 L is more than plenty...
For my E39, I use less than 1 L of fluid.
When flushing/bleeding... you'll see the new fluid come out but it has some mix of old fluid so pump out a few more ounces after you seeing the new fluid before closing it off.
Using this method I still use less than 1L.
You are set for two more flush/bleeds with 3L of fluid.
Since it's a clinic, maybe folks could share the hose after use... dont really need a dozen hosese since they are reuseable. I've been cleaning mine and putting it away in a zip lock bag.
I've done a few cars with that hose so far.
Mola
