E46 (1999 - 2006)
The fourth generation 3 Series (E46 chassis) was introduced in 1999 and set the standard for engineering and performance during it's years of production including being named to Car & Driver's 10 best list every one of those years! ! -- View the E46 Wiki |
ABS light reset
Hi out there,
Anyone know how to "reset" the ABS light? I accidently disconnected the speed sensor doing a brake job. I have everything connected back up now but the ABS (and ASC) is still on. Thanks, |
OOPS. This is on a 2002 330CI
It should go out by itself after driving for awhile.
Thanks KrisL, a quick trip around the block turned the light out.
DC |
how long is a while
??? hope over night and a ride into work does the trick2001 X5 4.4 |
If the X5 is similar to the E46 in this regard, then it's not long at all. Maybe a minute or two
tried that =( is there a tool i can use to reset this? like an OBD scanner??
It seems a bit concerning that your car is telling you that your ABS is not working, however you are looking to try and turn the warning light off and ignore the problem? If you fix the issue properly then the light will go off after a minute or so of driving, and will stay off. ABS really can be a life-saver, I wouldnt ignore it! Have a look to ensure that the sensor is connected properly, if this isnt solving the problem then it might be wise to do a diagnostic check to find out exactly what is causing the problem. You can get diagnostic code readers for dirt cheap on eBay. |
Thanks Stuzor, but it all happen when I disconnected a few control module plugs under the hood.... =(
all woworked out drive, drive, drive, and drive some more maybe 1,000 miles or so but it should go off, if not maybe you should get a check.. but this happen to me and now the X% is running really well
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
