#201
An interesting tidbit arose today in this thread:
- E39 (1997 - 2003) > How to tell which 540 caliper: 96-2000 or 04/2000-2003 To check whether the previous owner changed the caliper, on the caliper, apparently, is stamped relevant sizes:
Today, someone quoted the old chart (see below) in this thread in order to ask what the key was for the supplier column A.
- Ok don't murder my face but... (front pads) The key to the chart is listed in post #8 of this thread: - Are these the preferred parts suppliers for OEM (only) by price? Quote:
With the question asked of each of them simply being "What do you have that is CLOSEST to stock for my 2002 525i?" Not all the parts were the same, as noted in post #22 (partially quoted below): Quote:
#203
For the cross-linked record, today a discussion on brake squeal:
- E39 (1997 - 2003) > Help with Brake Squeal posited that the metal-on-metal vibration of the pads against the pistons is a major component of brake squeal. I'm not so sure ... as I have no idea 'what' causes brake squeal ... but ... as a datapoint set, I re-iterate the following which came out of this thread over time: 1. My original Jurid/Textar pads did not seem to have an insulating material on the pad backing plate and they did not squeal ... 2. Likewise, as shown in this thread from March 2008, my replacement Jurid/Textar pads did not seem to have anything on the pad backing plate ... and they didn't squeal either. 3. The later PBR Duluxe Advanced replacement of the fronts (leaving Textar on the rears) in this thread last summer, DID squeal ... and they have an insulating material on the pad backing plate. Go figure. I should note that this PBR Deluxe Advanced squeal when braking at about 30 to 50 mph, did not happen for the first few thousand miles; and that it went away after about a thousand miles - and I no longer hear it (at about 5K miles later). All this data is confusing as it does not point to the cause of brake-related squeal. Sigh. EDIT: Note that I followed the Bentley instructions for lubrication of the caliper landings only (placing nothing on the pad backing material). Last edited by bluebee; 05-26-2011 at 11:48 PM. |
#204
Hey just to note- i tried calling OEM Bimmerparts and their number is no longer valid.. must be out of business? 210-445-7099 is someones random number lol
03 540 6-speed Dinan exhaust, short shifter, sway bars, so far... |
#205
I had updated the "general suppliers" thread, as shown here in post #28: Quote:
- OEMm Bimmer Parts (TX) 210-277-9625 http://www.oembimmerparts.com - SpeedNet Motorsports (CA) 800-530-3515 http://www.speednetmotorsports.com/index.html - Turner Motorsport (MA) 800-280-6966 http://www.turnermotorsport.com - Zeckhausen (NJ) 800-222-8893 http://www.zeckhausen.com Last edited by bluebee; 05-27-2011 at 11:49 AM. |
#206
bluebee always on the ball! good ****. we need to figure out a nice clean way to organize all the stuff you do for the site.. hmmm
#207
- What E39 street use brake pads (1) and rotors (1) and suppliers (1) (2) are most often recommended & how to do a complete four wheel brake job DIY (1) (2) (3) including the parking brake drum shoes (1) (2) (3) & exactly what lube/paste to use and not use (1) & where to lube (1) and not to lube (1) & what six brake hoses to check for wear (1) & how to do a preventive brake system & caliper rebuild (1) (2) & what tools are needed for a brake job (1) (2) and supplies for doing brakes (1) & what brake specifications you must know (1) including minimum specs for the brake shoes (1) (2) taking care to measure torque accurately (1) & how to crack friction material edge codes (1) & how far you can go once the brake wear sensor trips (1) (2) (3) (4) & how long do rotors last (1) & what's the real difference between drilled, slotted, and solid rotors (1) & what's the difference between various brands of solid rotors (1) & how to clear the check brake lining warning the right way (1) (2) and how to hardwire the sensor (1) (2) & how to diagnose brake-related vibration (1) (2) (3) & the truth about rotor "warp" (1) & how to rebuild the calipers (1) & how to measure runout (1) & should you just turn the rotors (1) & how to remove stuck rusted-on brake rotors (1) & how to remove a stuck 6mm brake rotor set screw (1) & how to replace the anti-rattle spring (1) (2) & what about unsightly rust (1) (2) (3) (4) (5) & how to bed (1) (2) & bleed or flush (0) (1) (2) (3) (4) (5) your brakes & what brake & clutch hydraulic fluid to use (1) and how much it will cost if you do not DIY (1) (2) (3) Last edited by bluebee; 07-26-2011 at 09:08 PM. |
#208
By way of newbie-to-newbie cross reference, see this thread from today, where a newbie asks the same kinds of questions we all have to learn eventually:
- E39 (1997 - 2003) > ~ ~ Need Advice on BRAKES qustion... ASAP ~ ~ Here's my response, now that I've done the job twice and have read all that I could on the net about the right way to do a BMW E39 brake job: Quote:
#209
Dealer wanted $1385. plus tax towels etc. t wasn't cheap but front and rears BMW parts was around $650. I used Wagner Thermo Quiet pads, no dust, no noise. It was Saturday so bought one sensor at O'Reilly and it cost more than BMW, and it broke on install. Recently did job on 04' 528, and they have redesigned the sensor making it thicker and stronger so you get earlier warning.
#210
Wow. That certainly isn't one of the most recommended pads for the E39!
- What brake pads are recommended for street use on the E39? Let us know, over time, how they perform for you so we can learn from you. PS: I'm surprised a sensor would be at an autoparts store. You have a well-stocked supplier. Me? I get 'em from the sponsors. Last edited by bluebee; 08-12-2011 at 03:40 PM. |
#211
Today, there was an interesting discussion about rotor grooves over here:
- E39 (1997 - 2003) > Fixed my shimmy while braking problem! Quote:
Q: What is the official BMW spec for the thickness of a groove that will fail a rotor upon measurement? See scoring below from this web site: Last edited by bluebee; 08-28-2011 at 11:04 PM. |
#212
So, the question I would like to ask here is:
Q: What is the official BMW spec for the thickness of a groove that will fail a rotor upon measurement?[/QUOTE] You're assuming such a spec exists. The real question is, how would you take such a measurement? You could use a depth mic (micrometer), but you need a smooth surface to rest the base of the mic on to get an accurate measurement, and a worn rotor has no such surface. Perhaps a specialty tool exists, but I don't know of any. Anybody??? Jerry
![]() 2002 530i 5 speed - 151,000 miles |
#213
RDL found, in this thread, a surface roughness spec from the BMW TIS:
- When do we fail our rotors due to scratches/grooves/roughness based on BMW specs? What he found was a surface roughness specification, included below. While he explained how to make the measurements, surface roughness measurement is beyond our garage tool means. Simple! - Popular Mechanics: Measuring scoring in brake rotors with a dime! Quote:
What do you think? |
#214
I was thinking more along the lines of mounting the rotor in a lathe, and with the lathe NOT running, mount a dial indicator with a mag base to the carraige. Move the dial indicator along the surface, and take your reading. Then at least you have some real numbers.
#215
Good point.
But, for me anyway, I'll take my Roosevelt dime, and, if any score is wider than the dime and/or deeper than the head, I'd replace the rotor. That works for me (unless/until we get an official BMW scoring spec). BTW, yesterday I had new tires put on based on this thread: - Curious what you think of my excessive tire wear (is it due to camber or toe-in?) When the mechanic noticed my rear brake pads were very low. The light hasn't lit, but it looks like there's yet another brake job (rear only since the fronts are about a year old) in my near future! That's what I love about learning: Reuse! NOTE: The mechanics knew nothing of the red dot; they removed the BMW hubcaps by hand; they tried to re-install them with channel lock pliers!; they used 100 lbs of torque on the nuts until I told 'em otherwise; & they put in the same air pressure in all four tires. That's what I hate about having someone else work on my bimmer! Last edited by bluebee; 09-01-2011 at 03:37 PM. |
#216
Apparently, the outboard pads on the OEM Textars, put in at about 75K miles in March 2008, at the very start of this thread, has a small knob on each end that sticks up, oh, about a half a millimeter, or so. My right rear brake wear sensor was scratched, but still intact (i.e., no light on the dash). But, those little nubs started to grind on the outside of the right rear rotor this morning! I immediately called all the auto parts stores in town, and found, in stock at NAPA, PBR Deluxe Advanced rear pads for $42 + tax (to match my fronts of PBR Deluxe Advanced, aka Axxis Deluxe Advanced). Total miles driven on the metal-on-metal were about 12 - and I tried to use engine braking as much as I could. An hour or two after arriving home, I had new brakes pads on the rear. It was uneventful, but, as always, I snapped a hundred or so pictures. The rotors are only lightly scored; but they are slightly below the wear limit of 0.720 inches, so I will need to get a set and replace them after the fact. Again, the brakes were dry as a bone; so, I did an experiment and put the set on entirely dry. We'll see what happens. Last edited by bluebee; 09-11-2011 at 12:04 AM. |
#217
#219
For the record, someone just asked today:
- E39 (1997 - 2003) > E39 brake job question |
#220
For the cross-linked record, today it was noted that rotors generally last about a pad and a half:
- E46 (1999 - 2006) > brake parts question- raceshopper has brake sale |
#221
For the record, the discussion of anti-squeal paste today is useful:
- Where exactly to apply anti-squeal compound on brake pads? |
#222
For the record, the cold/hot friction grade for the PBR Deluxe Advanced pads I put in are FF.
Apparently I should have used 'better' pads, based on preliminary information available here: - What is the friction grade for the most recommended E39 brake pads (e.g., EE, FF, EF) |
#223
For the record, someone asked today when to replace pads if the pad material is low.
- Brake job suggested on my 2003 e-39 The technically-correct answer, of course, is in the specs, but here is a 'pragmatic' answer that others may benefit from: Quote:
#224
I think we finally got an answer as to what the purpose is of the black pad on the back of the Axxis/PBR Deluxe Advanced FRONT pads of my E39 (but which was not on the back of the Axxis/PBR Deluxe Advanced REAR) pads for my E39.
This quote from post #13 today of this thread suggests an anti-squeal purpose: - E39 (1997 - 2003) > Brake job suggested on my 2003 e-39 Quote:
- How to check & replace your BMW front disc brakes and rotors That question is reproduced below pictorially from that post #159: NOTE: The part about Axxis no longer being sold was proved fallacious in this thread: - Why so hard to price Axxis Deluxe Advanced brake pads on the Internet? |
#225
check brake light
This means to check your brake light bulbs in the rear!!!!!
Not your brake pads!!!! |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
