Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E28 (1982 - 1988)
E28 (1982 - 1988)
Old 03-03-2008, 02:40 PM
pakruz pakruz is offline
Mein Auto: 1988 528e
coolant overflow problem
Hello all. new member here. I have an 88 e28 and I'm having a coolant overflow problem. I recently changed the thermostat and water pump. I'm having coolant discharge from the overflow tube although the temperature while running registers fine. I bled the air before filling with coolant. Any ideas? Thank you.
Old 03-04-2008, 07:12 AM
jimoreno jimoreno is offline
Mein Auto: 2006 X3
Replace the coolant tank cap. Cheap and easy fix. If that's not it you might have a bad head gasket pressurizing your system (guess why I know that! )
Good Luck!
Jimmy Moreno
1995 530i
1986 535i
HTML code is Off
