E36 (1991 - 1999)
The E36 chassis 3-Series BMW was a huge hit among driving enthusiasts from the first moment the car hit the pavement. The E36 won numerous awards over the years it was produced and is still a favorite of many BMW enthusiasts to this day! -- View the E36 Wiki |
Power steering whine anyone?
Hello!
Every now and then the power steering seems to whine and when you rev the whine goes with it if you know what I mean (gets louder and higher). Usually happens when the cars relatively cold when your parking or something. Any ideas what this might be if it's a fault or is it a common thing>? Cheers, Paul P.s Car is 1994 E36 320i 4dr Saloon 142k |
Hi
Have you checked your power steering fluid level? may need flushing
330i M-Sport in Topaz Blue Edirty6 for life |
mine wines when the wheel is in full lock... so im hoping that its normal... and im guessing the loudness in whining is getting louder due to increased speed?
better awsk someone more knowledgeable in here tho |
check your fluid level. When mine was whining really bad I just chalked it up to a cold engine until it happened several times. Turned out I had a leak in my hose and couldn't keep fluid in - if I had waited any longer it could've burned out my pump.
Why does everyone think they are smarter than generations of German engineers? |
I am having that too. Seems to be common for the clip under the steering fluid reservoir to fail. Aparaently, you could solve the problem by replacing them with the type with the screw n the side. Also, remember to fill up with ATF, not PS fluid.
![]() It's mine.. (correction, it was)1994 320i SE alpine white - RIP 1992 320i SE black, bilstein coil over, sparco buckets, star chiped - SOLD 1998 Alfa 156 2.5 V6 red - SOLD 1988 325 iS red -RIP 1993 MX5 1.8 BRG - Daily 1996 740i green - Daily |
Good call, I'll have a look in a bit and report my findings.
Cheers Paul |
Does your PS whine when you turn the wheel/get worse when you turn the wheel?
So Fresh and So Clean!!! '02 330xi ZPP/ZCW Springfield, IL |
Yep
Was dark so had to look by mobile phone light but seems the fluid is very low and doesnt even touch the dipstick so I'll get some tomorrow. Thanks for all the replies.
Check the unit for leaks, the e36 pump is prone to them
Every BMW i have had or been in whines when it is on full lock...is a characteristic
On very cold days -10 or more, My power steering is loud. It's happened about 4-5 times this winter and goes away about 10 mins after driving.
Topped up all sorted! Thanking you
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
