E36 (1991 - 1999)
Old 03-05-2008, 11:22 PM
BMWredneck's Avatar
BMWredneck BMWredneck is offline
Send a message via MSN to BMWredneck Send a message via Yahoo to BMWredneck
Mein Auto: 96 318is Auto
Wiper Issues
I have checked fuses, they all check good.
Im lost on what else to check.
The problem:
There are 3 speed settings. 2nd one doesn't work correctly.
From what I know of its supposed to be a continuous wipe as you are driving, but when you stop it switches to a fast intermittent wipe. Mine is stuck on intermittent wipe. Anyone have an idea on what i should check or what the actual problem is?
Old 03-06-2008, 02:11 AM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is online now
King of the Ballers
Mein Auto: Dreier, Fünfer & Siebener
Well, that certainly wouldn't be a fuse issue.
Let me see if i remember the E36 wiper switch.
Pos 0 - Off
Pos 1 - Intermittent, off at stops
Pos 2 - Slow Continuous, intermittent @ stops
Pos 3 - Fast continuous, slow continuous @ stops
If that's correct, and its stuck permanently on intermittent in Pos 2, then it would be a wiper control module problem most likely. Ask your dealer. Ask for a service adviser, they'll know for sure.
Chad // 2001 BMW 740i M-Sport // 2000 BMW 540i Sport // 1997 BMW 328i Premium //
E38 16" Style 5 Basketweaves, M52 Parts, and New Gaskets/Seals for Sale!! PM for info. .
Originally Posted by SlimKlim View Post
You're a derbanana
Old 03-06-2008, 03:18 PM
amrrashad amrrashad is offline
Mein Auto: 99 323 Cabrio
BMWredneck,
If your a DIY guy, my first guess would be some dirt on the Pos 2 connection that's preventing the wiper contol module from getting a connection to Pos 2. I'd try cleaning it with some electric terminal cleaner first. If it doesn't work, then my adive would be to follow Phantom's advice.
Take care!
Amr
Old 03-06-2008, 11:21 PM
BMWredneck's Avatar
Where would the general vacinity of this connector be at?
And the wiper control module, is that a decntly DIY or should i just stick with a mechanic for it?
Old 03-08-2008, 07:02 PM
vwvannut vwvannut is offline
Send a message via AIM to vwvannut
Mein Auto: 1992 325i
I've got another wiper question for you guys. My 92 (different control module) has a similar problem, but it will only work in fast pos 3, and will not return properly. Every once in a while it works. yesterday i was washing the car at a coin wash. I had the hood open and i was cleaning the engine a bit. low and behold the wipers worked for about 10min after, then returned to not working. Any ideas?
