5 Series DIY
Knowledge Is Power! ~ The place for do-it-yourself threads on a variety of topics. Start a thread describing a particular job (oil change, cooling system overhaul, brakes, shocks and springs, etc.) or search for one you need help with! |
#201
Thanks Lance: I will let you know
#202
Lance: Job is done w/new regulator installed. I did remove the window but the 10mm bolt at the top CAN EASILY BE REMOVED with the window still in place in the UP position. The problem is once you remove it and take the regulator out RESTARTING the bolt is very difficult with the window in the door.
The old MOTOR (which I reused) came undone from the old regulator with 5 screws and was easy to reattach. Thanks for your help. JOB DONE |
#203
The '98 540i has broken both its rear window regulators, the first one long ago the second one last year (in the CCA corral at the Monterey Historics as we were loading up to head to the hotel...) and I wish I'd found this then.
The '00 M5 right rear window is making the same clicking noise the '98 did (in large measure, no doubt, because our three-year-old now has control of her own window) and I'm assuming the failure is going to be similar. The part # changed midyear '99 - anyone able to tell me how different the new unit is? Lance, do you have parts for the later ones? Thanks. |
#204
JEM, Sorry for the delay in answering your post, No I don't have anything for the later regulators, I've never been able to get hold of one to see what it would take to repair one.
Lance |
#205
Busted regulator
Lance on one of my BMW528i's the regulator has crapped out. Do you still have those great kits you were making? Please
#206
Frantz, PM sent, I've still have kits available.
Lance |
#207
Regulators
Hey Lance-
I've got a 528 with both rear window regulators broken. I'd love to get a hold of one of you kits if they are still available. Thanks, Jordan Padgett |
#208
Hi Lance M,
I finished the repair on both my rear E39 window regulators and they work great now. I would like to mention that when I initially installed them the extra metal added to the slider by the kit rubbed against the door pillar. I didn't want to remove them and sand the pillar as suggested, so instead i pullled on the regulator track to create more space between it and the pillar and after about 5 minutes of bending it out the window moved up and down smoothly with no hesitation. Thanks for the kit ![]() -Fil |
#209
Good deal, yes some cars hit some don't one door of mine did and I spaced it out with a piece of folded intertube, pretty much the same thing you did just not as scarry
![]() Enjoy and Thanks! Lance |
#210
Need a kit and cable info
I'd like to purchase a kit. How do I do so?
Also the cables have come off the pulleys in the regulator. Any info on how to properly re-route them? Thanks!
PM sent on order info, To redue the cable, once you have the regulator out of the car you will see the 2 plastic cable housings that run betweent he motor and the regulator, pull one of them out of the regulator, that will give you the slack you need in the cable to restring the regulator. Once you have the cable restrung, push back on the housing you disconnected to compress the spring at the motor end and get the housing back into the regulator, this will retension the cable and you should be good to go.
Lance |
#212
Hi Lance,
Both rear regulators broke. 98 540i. Although I haven't read all the posts (and bimmerforums link has a problem for me), please sent email to d_d69@ymail.com with whats required. |
#213
Email sent
Lance |
#214
Left rear window needs your fix. Please send me the details of how to order your kit.
Thanks |
#215
PM sent.
Lance |
#216
Hello Lance,
I have a 540i that have the same problems in both the right and left doors. Can I get information from you to where I can send to get your kit? Thank you very much! |
#217
PM sent,
Lance |
#218
I would like to order that repair kit if still available.
#219
pm sent jjeff29
Thanks, Lance |
#220
Does anyone have instructions on how to route the cables in the regulator? I've got the kit to fix the issue, but the cable has come off all the pulleys and I can't figure out how to get them back on. I haven't been able to fine a good picture or instructions anywhere either.
I'd send you some pics but I'm in Korea this week... To get slack in the cables so you can restring it take and remove one of the plastic coated cable housings from the regulator, they run between the motor and the regulator. This will allow you to restring the cable and then when you are ready push the housing against the spring at the motor end and put the other end back into the regulator.
lance |
#222
Thanks Lance,
Any pictures you could post when you get back would be helpful. Thanks!
But it has many pictures and you can see how to reassemble the regulator back together. I did this 2 years ago and it is still good. (touch wood... !!!). It will be much easier for you if you have another pair of hands to help you. You need somebody with strong hands. You need to squeeze the spring all the way in when you put that together. But in the end, my friend did not help me good enough, and I did it by myself on my kitchen table. You'll need to have very strong fingers... ![]() Anyway, here is the link: http://www.bimmerfest.com/forums/sho...58#post2572558 Good luck, mw
MatWiz "Seeing is not believing. Believing is seeing." -Judy the Elf |
#224
diy kit
lance,
I am looking for a passenger rear window regulator repair kit for my 2000 bmw 540i.Can I purchase your kit from you? Last edited by sam siu; 09-11-2009 at 08:58 PM. |
#225
Hi Sam,
Sorry the kit only works on cars manufacutred up to 6/99, a different regulator was used after that date and my kit won`t fix it. Lance |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
