Old 03-12-2008, 07:46 AM
rudejamaican's Avatar
rudejamaican rudejamaican is offline
Send a message via AIM to rudejamaican
Mein Auto: 2008 335i Sport
My DIY Parrot 3100 Bluetooth Install
Well after seeing the price of the BMW dealer BT retrofit, I decide to get an after aftermaket BT, I decided on the parrot 3100. I when to my local stereo install and they quote me $250 to have it installed . I am electronic tecky so I decided to tackle the install myself, So here we go.
1: Check on the Radio Wiring Diagram. I have put a check mark on the Pin # that will be needed..
2 Remove radio by popping out the wood trim above the radio, loosen the 2 screws that are holding the radio and AC control face plate in place, Pop out the face plate.
3:Remove the 2 screws the are holding the radio.
4: Remove the radio to get to the back, the cable are short so becarful not to rip any cable out .
5: Remove the 16 pin Connector by pressing down on the 16 pin lever and pulling it out. ( see Radio Diagram (Key 1). and Pic labeled
16 pin connection.
6 Connect yellow mute cable to Pin #10 on the 16 pin connection. (the pin may be empty, so you have to find a way to make a connection, you can pick out some wire connecting ends at Radio shack
7 On the black socket (12 pin connector Right on the Radio Diagram). connect the Blue Line "+" to pin #2. connect Line "-" to radio ground.
8 Connect power cable as describe in the Power Connection Pic.
9 It is up to you to decide on where you want the Display and Mic mounted, I have included a couple of Idea, I first decided to put the display in the center, but later decided I wanted it at the bottom ( see Pics).
10 Cut away all unused cables and take and wrapped up everything nicely. place the blue control box and wires in the space below the radio.
11 Power up, pair your phone to make sure everything works. If all goes well, then put everything back together and you are all done.
This setup will mute your radio when you are using the BT, all sound will come thru the car speakers, and you will be able to control the BT volume from the radio volume control .
HOPE THIS HELPS. PS: Just want to give a hand to Daddys Little Helper, I am teaching her all that I know
Name:	16 -pin connection.jpg
ID:	138827   Click image for larger version
Name:	Line + connection .jpg
ID:	138828   Click image for larger version
Name:	Power Connection.jpg
ID:	138829   Click image for larger version
Name:	Radio mute cable.jpg
ID:	138830   Click image for larger version
ID:	138832   Click image for larger version
ID:	138833   Click image for larger version
ID:	138834   Click image for larger version
ID:	138835   Click image for larger version
Name:	Daddys little Helper.jpg
Old 03-12-2008, 09:13 AM
stream's Avatar
stream stream is offline
Mein Auto: '05 545i
Nice DIY!
2005 545i - sold
Old 06-08-2014, 06:38 AM
dycecooper dycecooper is offline
Mein Auto: 520d
Nice job but why did you use line 2 for the speaker input when the diagram says the 6 is for telephone input?
I'm sure there was a reason for it and your obviously works, I will be doing this soon so just wondered.
Old 06-08-2014, 09:43 AM
H F H F is offline
Mein Auto: 2005 545i
Not sure if you noticed that this thread is 4years old . U might not get a response.
Old 06-08-2014, 11:31 AM
Mr. Orange 645 Mr. Orange 645 is offline
Mein Auto: Jet Black 2008 535i
If you have an AUX input, this is the best and cheapest way to go to add BT to your car:
http://www.amazon.com/Kinivo-BTC450-...kinivio+btc450
My 535i has BT for phonecalls, but not for media, so I hooked the BTC450 up, hid the wiring, and put the control button just below the iDrive controller. Music sound great, and you can either still use the stock BT for phone calls, or use the BTC450 for both music and calls.
If you don't have an AUX input, there's some DIY guides to add one, but you'll have to code the iDrive to accept it.
Just another option in case the OP no longer posts here.
Old 11-08-2014, 05:24 AM
christophe123 christophe123 is offline
Mein Auto: bmw
Thumbs up parrot diy
Hello,
very nice threat, but where do the speakercables go?
I don't see how the sound comes through the speakers ?
sorry for this maybe stupid question .
