E90/E91/E92/E93 (2006 - 2013)
Old 03-12-2008, 11:59 PM
craig1214 craig1214 is offline
Mein Auto: 335d sedan
inline 6 vs V6
On this forum when other cars are compared to 3-series, I see frequent comments that the inline 6 is superior to a V6, in more ways than one. Is there some inherent advantage in the configuration? Or is it just the long experience and engineering that has gone into the BMW engine? Car manufacturers with V6's certainly aren't reticent about promoting them.
2011 335d sedan (ED 10/10), Space Gray, Premium, Step, CA, PDC
2007 335xi sedan (ED 8/07), Arctic, Premium, Step, CA, PDC
1998 328i sedan (ED 11/97), Black, Sport, Computer, 5MT
Old 03-13-2008, 12:02 AM
s2pidyeah s2pidyeah is offline
Mein Auto: e90
down side of str8 6(inline6).. lack of cooling of rear cylinders
Old 03-13-2008, 12:19 AM
galahad05's Avatar
galahad05 galahad05 is online now
Better with Butter
Mein Auto: 335i sedan 6MT
Upside: Typically more efficient and smoother. Efficient because of less frictional losses (more valve gears and camshafts for an equivalent V6) and the V6 has twin cylinder banks, which = more heat loss. More heat loss = power loss.
Smoother because the inline-6 is inherently balanced (vertical and transverse forces generated from individual cylinders are completely canceled out by the other cylinders). Not so with the V6.
Downside: Space. They're loooong. Thus damn difficult (don't know if anyone's ever done it) to package with a front-drive, for example. This also makes for a large engine bay (long hood).
Don't resent growing old. Many are denied the privilege.
-- Irish Proverb
Old 03-13-2008, 12:53 AM
ramos ramos is offline
Mein Auto: 08 E90 335 AW 6MT
The I6 is referred to as Newton's engine.. I think a reference to it's smoothness and balance
What Galahad said is spot on..
E90 335i 6 Speed MT
Alpine White, Terra, Burl Walnut Wood
Premium, Sport, I-Drive Navi
CA, Sirius, Heated seats, Ipod, PDC
ED pickup March 17th Re-delivery on May 24th
CCA Member # 403913
Old 03-13-2008, 12:54 AM
void.crusader void.crusader is offline
Mein Auto: '03 Altima 3.5 SE
Downside: space.
Means you can, say, pack 3.0-3.2L inline-6 into the bay and get 255-270hp from it.
Or you can pack 3.5-3.7L V6 into the same bay and get 300-330hp.
That's with all other things being equal - N/A and civil redline on both.
BMW was a long-time advocate of N/A engines. And for a good reasons. But when V6 competition pushed the HP envelope, BMW was forced to go turbo route. Sad.
Old 03-13-2008, 06:18 AM
redadair's Avatar
redadair redadair is offline
Mein Auto: 07 335i Sedan (Mieke)
Originally Posted by void.crusader View Post
Downside: space.
I think you forgot the M3 3.2L at 333HP and the 2003 M3 CSL at 360HP from 3.2L BMW can also make big HP without Turbos. It's just cheaper to do with Turbos. They save the big power naturally aspirated engines for the M's.
Red
2011 1M
Aug 8th ED
MADA drop off 8/18/11
Arrived at Port 9/21/11
Re-Delivery 10/10/11
07 335i Sedan
May 4th ED
MADA drop off 5/11/07
Arrived at Port 6/11/07
Re-delivery 6/27/07
04 330i ZHP
11 Mini Cooper Clubman S Hampton Package
72 BMWtii drove till dead - Remains one of the best cars I have ever owned
Old 03-13-2008, 06:22 AM
PhilipWOT's Avatar
PhilipWOT PhilipWOT is online now
Turn Burglar
Location: Atl: Come for the pollution, stay for the traffic
Mein Auto: Red Assless Chaps
Everyone forgot the most obvious advantage of the inline 6 configuration: The sound!
Old 03-13-2008, 06:32 AM
brashman brashman is offline
Mein Auto: '06 330i
Another couple of advantages to the I6 are
1) The straight-6 is smoother than engines with a fewer number of cylinders because the power strokes of pistons partially overlap. Since each power stroke lasts 180 degrees of crankshaft rotation, while a new piston starts its power stroke every 120 degrees, there are 60 degrees of overlap on each stroke in which one piston is finishing while the next is starting. (plagiarism alert - I copied the above from wikipedia)
2) Aforementioned minimized frictional/power-sapping losses from two valvetrains,
3) Balance advantages from all cylinders moving in the same plane
Good article here http://en.wikipedia.org/wiki/Straight-6
I believe another reason BMW has finally gone the route of forced induction is that you can bring to market a vehicle that will have the fuel efficiency of the NA vehicle while still delivering the power needed to be competitive (seemingly 300+ hp now). With good turbo/ecm management the engine can receive minimal boost in 'normal' driving, saving fuel.
Old 03-13-2008, 06:34 AM
ChanghisKhan ChanghisKhan is offline
Mein Auto: 335i Coupe
Red
Fuel efficiency is another motivator for going turbo. The enviro-f@#$sts in Germany is increasingly clamoring for speed limits on ALL of the autobahn
E92 335i | 6MT | Jet Black | Black 'ette | ZSP | BT | CA | Shades
Old 03-13-2008, 06:47 AM
Mein Auto: '06 330i
All things being equal, it's much more expensive to bring to market a high-revving engine (S54B32). The engineering, development, manufacturing, and warranty costs all go up at a much faster rate than does the horsepower. Also, on high-revving engines like these, the peak horsepower and torque comes fairly high in the rpm range of the vehicle. So while BMW certainly can development high horsepower normally-aspirated I6's, it seems the route going forward will be forced induction which they are quite good at too, see the 1986 Formula One engines they developed 1.5 liter, 4-cyl, 5.5 bar turbos making >1300bhp.
Old 03-13-2008, 07:36 AM
craigr's Avatar
craigr craigr is offline
my 335 with friend
Mein Auto: E90 335
Plus for me - having just driven a few M3s - the thing I love about my 335 is that if you want to blast around you can.. but if I am in the mood to cruise around quietly .. the 335 if not in your face like M3's can be. Of course there is a attaction to the M3's in your face at any speed.. but I have gotten to old to want that all the time.
I believe dual personality ability is because of the turbo, ... Gas milage? ...on a freeway stretch I can see 32 mpg on the computer just show you how little the engine has to work to do 75mph.
craig
Old 03-13-2008, 08:42 AM
jsc's Avatar
jsc jsc is offline
Mein Auto: E85 M-Roadster, E82 135i
Downside: space.
Or you can have more space to add turbos alongside the 3.0-3.2L engine, boosting it's power back up to or beyond the 3.5-3.7L, as the V6 is particularly fat compared with the I6 - you know, long and athletic I6 vs short & stumpy V6
Old 03-13-2008, 08:44 AM
HW's Avatar
HW HW is online now
lurking
Mein Auto: 323ci, manual
some great descriptions
http://www.autozine.org/technical_sc...ne/smooth1.htm
http://www.autozine.org/technical_sc..._packaging.htm
2010 Acura TSX manual
"You know, by the time you become the leader of a country, someone else makes all the decisions. You may find that you can get away with virtual presidents, virtual prime ministers, virtual everything" - Bill Clinton
"Give me control of a nation's money and I care not who makes the laws." -
Old 03-13-2008, 09:31 AM
Emission's Avatar
Emission Emission is offline
Automotive Monomaniac
Mein Auto: Schnelle Autos
Mercedes-Benz dropped their inline-6, and so did Lexus, in the interest of space (packaging under the hood).
Volvo shoehorns an inline-6 transversely under their hoods. In fact, the V8 in my XC90 sits transversely as well (see pic below)! Volvo is nuts, but they claim it adds "crush space" in an accident.
(37,000 miles on the Volvo engine. Yes, I keep my engines clean - that shot was taken on Sunday.)
My new Porsche site Flat6News http://flat6news.com/
I am fortunate to have unique press cars delivered weekly, but I own:
'13 Audi Q5 2.0T Quattro 8AT
'86 Porsche 911 Turbo 4MT
Gone, but never forgotten... E70 X5 35d, E90 335i, E46 330i, E36 328i, E70 X5 3.0si, E53 X5 3.0i.
Find my work on Autoblog or on my new Porsche site Flat6News!
Old 03-13-2008, 09:32 AM
chemgeek chemgeek is offline
Mein Auto: 2008 335i Sedan
I think the tradition behind the inline engines is the best part about them besides the sound they make.
2008 335i Sedan/Premium/Sport/Ipod-USB/Parking Sensors/Nav/Graphite on Black w/ Walnut
Old 03-13-2008, 09:34 AM
I swore Volvo cars (not the SUVs) had inline 5 cylinder engines. 5 cylinder mixtures of noramlly aspirated and higher performance turbo engines.
Old 03-13-2008, 09:46 AM
HW's Avatar
HW HW is online now
lurking
did they do that so that they can get their 4matic to jive?
Old 03-13-2008, 09:49 AM
Penforhire Penforhire is offline
Mein Auto: 2006 330i
I6's are magical. I suppose part of that is how I like long hood lines and the roar of an I6. Too many V6 engines sound like coffee grinders.
There is a 3.8L I6 sitting in a jumble of parts pretending to be a Jaguar E-type in my garage. Rumor has it the real output was around 220 HP so considering a 3.0L e90 is supposed to make 255 HP that is quite an advance.
Old 03-13-2008, 10:05 AM
Emission's Avatar
Oh, they do. They still use lots of inline-5's, but they also have used inline-6's in the past (with and without turbochargers) in their sedans and SUV's. Note: Volvo just came out with another six-cylinder last year... a 3.2-liter V6.
Old 03-13-2008, 10:07 AM
#5880's Avatar
#5880 #5880 is offline
Analyst + Therapist = ...
Mein Auto: people crazy
The overlap creates more torque
Short block v8s are great 1/4 mile engines, they rev fast
long block v8s are more for the track, they have power all through the band, they are forgiving of mistakes, this is the "feel" that most drivers want.
They are the "blue pill" types
"Those who do not learn from history,
are doomed to repeat it."
George Santayana
Emission's Avatar
According to Wikipedia:
The first design of 4Matic (or 4Matic) system was introduced in 1986 on the W124 series (E Class) saloons (four door) and estate (station wagon) cars. It was available with the 2.6 L and 3.0 L 6 cylinder petrol (gasoline) and diesel engines.
Their inline-6 was a 3.0-liter (I think), so that would be the engine noted above. It is hard to package an inline-6, so many manufacturers just drop them these days.
Old 03-13-2008, 10:09 AM
HW's Avatar
HW HW is online now
lurking
you mean oval tracks with only left hand turns?
Old 03-13-2008, 10:15 AM
JoeFromPA JoeFromPA is offline
Mein Auto: 01 M5, 08 535xit
Just a note: Several american companies have made inline six cylinders (I'm embarassed to admit but I BELIEVE my 97 Jeep Wrangler Sahara 4.0 was an inline six)...
I don't remember it being a model of newtonian goodness, although it was an awesome engine for around town driving
Joe
01 m5 - 118k miles 1/2013....08 535xit - 85k miles
Old 03-13-2008, 10:20 AM
Emission's Avatar
Joe
Yes, AMC/Jeep used the same basic inline-6 from 1964 to 2006!
http://en.wikipedia.org/wiki/AMC_Straight-6_engine
Old 03-13-2008, 10:27 AM
Bcube's Avatar
Bcube Bcube is offline
Combat Commuter
Mein Auto: 2007 E93 335i
I read an article where BMW considered 3.5L -3.7L for their inline 6 to make the requisite 300+hp NA. But the increased size of the pistons (with the elevated weight) compromised the inherent primary balance which meant counter-weight balancers, etc. Basically leading engineering down the path of over complexity in an originally perfectly balanced concept.
Another area that BMW has used to their advantage is placement of the engine to optimize handling. If one is already "stuck" with a long hood and rear wheel drive style, then why not push the front wheels all the to front, move the bulk of the engine behind the front axle centerline, thus promoting mass centralization. And keeping the 50/50 handling that BMW markets.
The Japanese have mostly stayed with the V-6 due to their extensive experience in packaging that engine configuration in front wheel drive platforms.
-Brian
"Used cars are our entry cars." - Luca di Montezemolo
