E90/E91/E92/E93 (2006 - 2013)
Old 03-14-2012, 11:35 AM
Emission's Avatar
Emission Emission is offline
Automotive Monomaniac
Mein Auto: Schnelle Autos
Originally Posted by SteVTEC View Post
Could you please provide a good solid technical explanation as to why this is? I've yet to see one that was convincing.
GM currently has a 3.0L DOHC 60* V6 with Dual-VVT cam-phasing and direct injection and 11.7:1 compression and regular fuel is making 270hp/223tq SAE certified.
Look up engine code LFW: http://www.gmpowertrain.com/VehicleE...nProducts.aspx
This is practically the same as the Euro-spec full-tilt direct-injected N53 3.0L making 272hp and 228 lb-ft torque on a higher grade of gas. The biggest limitation here is finding engines that are truly comparable.
There Inline-6 does have the advantages of lower overall friction due to only driving two cams vs four, and having a short localized timing chain run vs a V-6 where it's going all over the place, but these are very small differences. In the grand scheme of things, I think other things matter a lot more having nothing to do with engine configuration. Such as specific cam profile selected, variable timing setup and strategy, head, port, intake manifold and exhaust system design, etc. The goal isn't always to give the maximum possible power at at very high RPM (like Hondas) but rather a good overall balance of power and a good powerband with accessible torque at low to medium engine speeds.
I love the Inline-6 and would always love to have one for its sound and feel and character. It really is something special, but I'd hardly argue that one is superior to the other. The V-6 does have a lot of advantages. Much more flexible in terms of layout. Can be mounted either transversely or longitudinally, and it's far more flexible in displacement ranges. Modern V-6 engine designs like from GM and Toyota and Nissan can span 2.5 to 4.0L in displacement. The Inline-6 due to the very long nature cannot have very large bore spacings or else it won't fit into smaller cars, so it's very bore limited and ends up needing longer strokes. You can't simply "punch out" most Inline-6 engines to 3.5L or 4.0L like you can with many V-6 engines. This is why pretty much everybody else except BMW (and Volvo) produces V-6 engines instead. V-6's clearly win in the marketplace and few people care, but I do. Nothing can match the sound and feel and character and refinement of the I-6. I've had lots of V-6's but the N55 in my 335i is the best 6-cylinder engine I've ever owned. It's tough to sell refinement to people, though. I hope BMW never makes a V-6 because the I-6 really is something special.
The inline-6 is a PITA with regards to packaging (it takes up more space than a damn V8 or V10), but it is easier to work on from a mechanic's standpoint.
It is insanely smooth, but that is less of an issue to today's engine mounts and computer-aided design.
I love me an inline-6, but I think it will eventually go away...
- Mike
My new Porsche site Flat6News http://flat6news.com/
I am fortunate to have unique press cars delivered weekly, but I own:
'13 Audi Q5 2.0T Quattro 8AT
'86 Porsche 911 Turbo 4MT
Gone, but never forgotten... E70 X5 35d, E90 335i, E46 330i, E36 328i, E70 X5 3.0si, E53 X5 3.0i.
Find my work on Autoblog or on my new Porsche site Flat6News!
Old 03-14-2012, 11:37 AM
SteVTEC's Avatar
SteVTEC SteVTEC is offline
Mein Auto: '11 E93/335i
Originally Posted by Inline Sixer View Post
Here's a Car&Driver article that sheds light on the subject, entitled: "The physics of the V angle"
http://www.caranddriver.com/features...re?redirect=no
Didn't see a date, but that article seems a bit old. GM no longer makes their 90-degree V-6 engines aka the "3800" line. Retired a few years ago, but it did run very smoothly and was quite refined, so whatever they did to it to make it run so well worked. That engine has lots of fans to this day, myself being one of them. Mercedes also dropped their 90-degree V-6 awhile ago too. The 3.5L DOHCs are all dedicated 60* designs. It's a big advantage being able to share architecture with 90* V8 engines, but with the markets moving towards lower displacements it makes less sense to base a hotter selling V-6 off of a V-8 design, that doesn't run as smoothly and requires balance shafts to run well at 90*. Hence moving to dedicated 60* block designs for V-6 engines.
Originally Posted by Emission View Post
Never say 'never' when profits drive engineering and design.
"Porsche will never sell an SUV." (Heard back in 1999 when the first X5 was introduced.)
"BMW will never make the M3 with an automatic transmission." (Heard back when the E30 M3 arrived.)
It would be rather easy for BMW to slice a few cylinders off the 4.4-liter V8 and create a compact and lightweight turbocharged 3.3-liter V6... making about 350 horsepower...
- Mike
I know....
But a 90-degree bank angle = required balance shafts on a V-6, so hopefully they won't do it. BMW has had larger displacement Inline-6 engines before, up to 3.5L or larger I think. I'm guessing the newer I-6 block designs are smaller? I know some of those older engines were also iron blocks too. Better rigidity, and you can squeeze out just a little bit more bore size from those too vs the modern aluminium and magnesium-alloy blocks. I remember looking up the specs on some of those and being wowed at how little cylinder wall separation there was on those.
BMW has the money to spend on trick materials and R&D. Maybe they'll come up with some advanced new alloy that will allow them to squeeze a few hundred extra cc's out of the N5x design I-6 engines using a new material?
I like V-6 engines up to about 3.0L. All the newer ones to me don't sound quite as good and you start to feel a lot more of the vibrations as thrashiness as you get to the 3.5L sizes. Plenty fine for luxo-barges where you're probably not going to be going past 4000rpm all that much, but if you want an engine to scream I just love the I-6's. They're in a whole different league compared to V-6's IMHO.
Steve
2012 E70 X5d (IT'S HERE!) Deep Sea Blue / Sand Beige, Premium, 3rd Row, Multi-Contour
2011 E93 335i Deep Sea Blue / Oyster, Step, Premium, Convenience (PDC & CA), and that's it
more pics here
Old 03-14-2012, 12:24 PM
floydarogers's Avatar
Pedant and Curmudgeon
Mein Auto: 335d
Originally Posted by rtgirard View Post
Gotcha. I knew the N52/54 were really tight, but i didn't know about the V8/10.
All of BMW's engines have the same cylinder spacing - they only have to order/build one set of machine tools to bore/hone the cylinders.
The older M30 block had different spacing.
Old 03-14-2012, 12:40 PM
Emission's Avatar
+1.
This is the reason why automakers knock cylinders off engines... tooling costs.
The N20 is an N55 minus two cylinders. The M3's S65 V8 is a chopped version of the M5's S85 V10... and the list goes on and on.
Even the 6.0-liter V12 is two 3.0-liter inline-6s...
- Mike
Old 03-14-2012, 12:54 PM
Mein Auto: 335d
A tidbit of BMW history: The older M70 ('88-> '94) had TWO OF EVERYTHING! It was constructed from two M20 engines, and had two distributors, etc. And you guys swear at the cost of maintaining just one engine!
Old 03-14-2012, 12:58 PM
Emission's Avatar
Yes, that is why the '88 BMW 750iL has a resale value lower than the '88 325i of that era... maintenance is a bitch.
- Mike
Old 03-14-2012, 01:34 PM
Inline Sixer's Avatar
Inline Sixer Inline Sixer is offline
smooth like butter
Mein Auto: 2011 E93 328i | 2010 X5
This article was from last year. It offered a good scientific basis for the smoothness of an inline 6, a boxer flat 4 (180deg) and a V8 (90 deg). "Physics is always relevant" is the elegance of it.
Old 03-14-2012, 03:54 PM
Mark K's Avatar
Mark K Mark K is offline
Mein Auto: 2011 E92 335i MT
Yup. Or, as many a young man learnt the hard way on a racetrack (or, if unlucky, on the street), it is always better to call Lord Newton just that instead of being intimate on a first-name basis with him.
Too bad they grow up, forget the lesson and buy an SUV. Which needs $50,000 in mods from manufacturer in order to create the appearance of defeating Lord Newton. But that is a fable for another night. Good night kids.
Old 03-14-2012, 05:02 PM
DSXMachina's Avatar
Automaticallyparsinglinks
One of the real advantages a straight six has over a V6 is that there is room for more and wider main bearings, and larger diameter crank journals. When an engine is constantly pushed near the limit this is a real advantage toward keeping them together. As for smoothness, a V6 can be just as smooth but it's done with smoke and mirrors, balance shafts and silicone filled 'tuned' motor mounts.
BTW, some of the most rugged engines, not neccessarily the most fuel or emission efficient, in US history have been I6's. The Chrysler 225, the Jeep 4.0, and the Ford 170 and 200 and 262, and the GM 194, and 230 and the 3.8 Litre. Aha you say, the 3.8 was a V6! Not in the early Firebird it wasn't. It was a 3.8L DOHC I6. A few of the Fords and GMs had 7 main bearings!
I agree with Emission that BMW will have a V6 sooner rather than later. There are just too many design and cost advantages over the I6 for a company with their mass market aspirations to ignore forever. The company isn't run by engineers, it's run by accountants beholden to stockholders.
Old 03-14-2012, 05:27 PM
Mark K's Avatar
Well, this is the truth only for those who can't learn from somebody else's mistakes. Namely, the whole **** Sapiens Sapiens genus.
Ferdinand Porsche allegedly said "I was looking for a car, but I couldn't find one that fits my needs. So I built it.". Let's spare comments on why Feruccio Lamborghini created his own car after a bout with Enzo Ferrarri (Not Safe For Work - if you speak Italian, that is ).
The point is, GM already tried "proven and trusted" method of "This is how much it needs to cost, make it work!" and we all know how THAT ended up. It seems to me that we also have a whole another casualty of ignoring engineers - Fisker Karma. Can you say "This is how it needs to look, make it work!" ?
EDIT: isn't it cool how Bimmerfest replaces H*mo to asterisks (H*mo Sapiens Sapiens). Wow, we are really proper f*cked as a society! Time to move to another continent.
Old 03-14-2012, 06:51 PM
Squidget Squidget is offline
Mein Auto: 2011 335i E90 (MT,Sport)
Can't ignore the marketers either. Cases in point: the Edsel, 1980s Apple.
BMW CCA Member
Old 03-14-2012, 07:09 PM
DSXMachina's Avatar
Ah, but what about Steve Jobs who insisted on just that with the iPhone, iPod and iPad, and would not accept anything less?
Old 03-14-2012, 07:16 PM
galahad05's Avatar
galahad05 galahad05 is online now
Better with Butter
Mein Auto: 335i sedan 6MT
Wow, this thread resurrected from the dead.
Good follow-on conversation though.
Don't resent growing old. Many are denied the privilege.
-- Irish Proverb
Old 03-14-2012, 07:54 PM
DSXMachina's Avatar
Great posts by you regarding heat and efficiency. A very misunderstood subject. I suppose it's because we were trained to think hot engine, bad, cool engine, good!
A few years ago I read a powertrain engineer's comment that he wouldn't be happy until engines were all ceramic, ran at a thousand degrees, and were cooled like exhaust valves, using liquid sodium. He knew what he was talking about.
Old 03-14-2012, 10:27 PM
captainaudio's Avatar
Worlds Foremost Authority
Mein Auto: 335i E93 - 750Lix
[quote=DSXMachina;6701794]One of the real advantages a straight six has over a V6 is that there is room for more and wider main bearings, and larger diameter crank journals. When an engine is constantly pushed near the limit this is a real advantage toward keeping them together. As for smoothness, a V6 can be just as smooth but it's done with smoke and mirrors, balance shafts and silicone filled 'tuned' motor mounts.
quote]
I believe the Firebird Sprint 3.8L inline 6 was an SOHC engine. It was also not the only American OHC 6. In 1962 Jeep introduced the Tornado SOHC 6. Jaguar had a 3.8 (later 4.2) DOHC 6 during that era that both American engines were frequently compared to. The Firebird Sprint was introduced at the start of the Ponycar/Musclecar era and was soon eclipsed by the large V8s that Pontiac was offering in the Firebird. As good as the engine was in those days 6 Cylinder was synonomous with low performance in the eyes of most American car buyers and performace oriented Firebird drivers were more interested in the 326 and 400 (and later 454) cubic inch V8s.
Drivers Club at Lime Rock
The Glen Club
BMWCCA
Cayman Club Nor'Easters
Sports Car Club of America
American Mural Project
Old 03-14-2012, 10:53 PM
SteVTEC's Avatar
The Hudson Hornet was an Inline-6.
Steve
more pics here
Old 03-14-2012, 10:55 PM
F3 F3 is offline
Mein Auto: 2009 BMW 335i xDrive
Have to love the smoothness of the I6
Old 11-05-2012, 12:22 AM
mr29 mr29 is online now
Mein Auto: bmw
great thread here
Old 11-05-2012, 05:49 AM
adc adc is offline
BMW Fahrer
Mein Auto: E90 M3
Have you guys ever driven, been in, or just heard an NSX? There are V6's and then there are V6's...
And wait until F1 switches to turbocharged V6 engines in the near future...
adc
09 M3 Sedan ED
12 MINI Countryman S All4
93 Miata LE
Old 11-05-2012, 08:40 AM
Mein Auto: 335d
I had one. It's not as smooth as the inline 6. It wasn't even very smooth for a V6, as it was 90 degrees rather than 60. However, the very low mass of the pistons (titanium rods!) made it really zingy.
They're fabulous cars, extremely well-built and reliable. But just as costly as an M3 to work on. The ABS controller went out on mine just before I traded it in: $2500 for the part alone.
Old 11-05-2012, 08:42 AM
Chris90 Chris90 is offline
Mein Auto: '04 330i
I was just thinking of nice sounding V6s. I got a ride in a supercharged NSX, sounded sweet. VW's VR6 also sounds nice but I guess that's not really a V6.
Can't think of any others that stand out. I don't like sound of the Nissan V6.
"When you were born, you cried and the world rejoiced. Live your life so that when you die, the world cries and you rejoice." - Cherokee Expression
Old 11-12-2012, 11:39 AM
Mein Auto: 2007-335 HTC
the Datson 240 thru 280 had a I6, Triumph TR6 has an I6,( I have one) toyota supra had a I6, My TR6 redlines at 5000, and my 335 at 7000. which all has to do with the stroke of the piston, longer stroke, lower redline, also more torque in the low end.. the other thing about I6 vs V engines is the crankshshaft are shorter, and one rod per journal where as V6 or V8, you have 2 rods sharing the same single journal, so shorter cranks shaft save weight too
Hondo
