Old 03-13-2008, 09:30 AM
Specwar Specwar is offline
Mein Auto: E39 540iA Sport
Cable routing from trunk to dash
I know you can get from the trunk to the dash tucking a cable near the driver's side door sills but the cable has to be pretty thin to fit. I need to run several cables and one is pretty thick. I was thinking running via the center console but not sure how to hide the run from the trunk to center console. Anyone done this?
Old 03-13-2008, 10:05 AM
Fragzem's Avatar
Fragzem Fragzem is offline
Ouch
Send a message via MSN to Fragzem
Mein Auto: 2000 540i/6, 1964 Wildcat
i'd be crazy enough to run it underneath the car and in through a grommit someplace.
  • 2000 BMW 540i/6 (Anthrazit Metallic 397)
  • 1995 BMW 525iA (Schwarz II)
  • 2001 Buick Park Avenue Ultra (Bronzemist Metallic)
  • 1964 Buick Wildcat (Sunburst Yellow / Arctic White)
Fan Blades Can Explode.. Read My Thread
Old 03-13-2008, 10:23 AM
velvetMonkey velvetMonkey is offline
Send a message via MSN to velvetMonkey
Mein Auto: 1999 523i
if you look at the retrofit instructions for oem satnav, it'll show you the factory routing for cabling. The satnav harness is very thick in places, so it will fit.
UK 05/99 BMW 523i SE, 190k miles, steptronic, black leather, hella AEs and cellis, style 32s, MTEC front and rear bumpers, sport exhaust tip, shadowline, HID headlamps, OEM satnav retrofit
Old 03-13-2008, 12:08 PM
mmm635's Avatar
mmm635 mmm635 is offline
Mein Auto: '02 525i Sp/5, 95 FJ80 LC
I ran about 4 cables during my HD/Dice install. Once you get the cabling from the trunk to the driver's side back seat, it will need to run in a diagonal underneath the carpet and into the center console. You will need to make a cut int he carpet inside of the console to pull in the wires. I stuck my arm underneath the carpet to loosen it up because it is in there pretty good. I also used a fish tape to get things through. Once you get to the center console, the rest is a piece of cake.
Here is a link to some pics I took: http://picasaweb.google.com/mmm635/HDDiceInstall
Old 03-13-2008, 12:53 PM
Great pics, those will help immensely.
Old 03-13-2008, 02:05 PM
eE jeremy eE jeremy is offline
Mein Auto: 98 528i sport
I ran a nav cable from my trunk to my aftermarket deck it was pretty thick and fit along the doors no problem, there is quite a bit of room if you go that route.
