2002 e46 M3 TPMS light... - Bimmerfest - BMW Forums
E46 M3 (2001-2006)
Old 03-14-2008, 12:51 PM
RYM Racing RYM Racing is offline
Mein Auto: 2002 M3
Sequence for resetting TPMS light manually..... anyone?
Just completed a DIY oil/filter change, and reset the oil service interval, found a thread with the manual steps for doing that.
Thanks all!
Old 03-18-2008, 06:35 PM
jch197 jch197 is offline
Mein Auto: 2009 Z4 3.0i Jet Black
I assume that you mean the flat tire monitor system.
Steps parapharsed from the 2003 owners manual...
1) Inflate the tires to the proper pressure when cold.
2) Turn ignition key to position 2
3) Press and hold the flat tire monitor button (located on the center console below the climate control panel) until the indicator light in the instrument cluster lights up (could be up to ten seconds) and release.
4) After a little while, the indicator lamp will go out by itself.
Old 03-18-2008, 09:26 PM
ThatOneGuy's Avatar
ThatOneGuy ThatOneGuy is offline
Mein Auto: 2006 M3 ZCP
FYI - you can download an owners manual from the BMW NA website, it's a free pdf. All you have to do is register as an owner in the Owners Circle area.
Old 07-14-2008, 11:05 PM
ranicete ranicete is offline
Mein Auto: m3
can you please send me the procedure to reset the maintenance. I have a 2002 M3. Thanks in advance.
Old 07-14-2008, 11:24 PM
ej205gdb ej205gdb is offline
Mein Auto: 03 wrx wagon / 02 E46 M3
