X3 - Noise at rear of car - from exhaust ? - Bimmerfest - BMW Forums
Old 03-14-2008, 11:56 AM
pyoung1213 pyoung1213 is offline
Mein Auto: 2005 X3 and 2003 530i
I have a 2006 X3 with 70K miles. High-pitched fast-paced chattering just started - sounds like it's coming from rear driver-side exhaust area. When the car "warms up", it goes away. After 5 min off, and restart - same issue, but again - goes away after running for a bit. any ideas?
Old 03-14-2008, 03:31 PM
Mystic1's Avatar
Mystic1 Mystic1 is offline
Mein Auto: '11 328xi, '09 550i
The only thing I can think of from the exhaust is the butterfly valve in the right exhaust tail pipe. Some owners have had complaints of them rattling.
Old 03-14-2008, 03:46 PM
AzNMpower32's Avatar
Tar Heel Faithful
It could be under the hood- worn belt tensioner. That's what happened to us, and it was replaced under warranty.
Old 03-15-2008, 07:49 AM
Ninja333 Ninja333 is offline
Ninja Power
Mein Auto: E70 X5 3.0d, E90 LCI 320d
i have a similar noise related issue from the exhaust on my '08 X3 3.0si...
seems to be louder under acceleration, like a rocket-launcher - is this normal?
Old 03-15-2008, 08:38 AM
UncleJ UncleJ is offline
Mein Auto: '09 Cayenne "S"
py, the "butterfly" valve sounds like it might be the source. You have a fair amount of milage and I suspect all that hot exhaust has taken its toll on the valve. There were a number of posts about the valve much earlier, and something called a golf tee modification that was suggested for a better exhaust sound.
Old 03-15-2008, 10:12 AM
llando88 llando88 is offline
Mein Auto: Ram 2500 4x4
+1. The valve in #2 tailpipe is sucked shut under vacuum and opens under load.
The mod was to remove the pipe providing the suction (i.e. the valve stays open) and plug it with a golf tee and zip tie it out of the way.
Ours is being driven like a Madwoman by Mrs. Wingspan at the moment (just kidding, she is at work) or I would go peer at the exhaust and see.
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.”
- J.C. Watts Jr.
Old 03-15-2008, 05:07 PM
Mystic1's Avatar
An even easier way to do the mod is to open the rear driver's side cargo panel and there is a vacuum servo there. Remove the tubing coming off the side and cap the outlet on the servo with a 1/8 vacuum cap. That's it.
