What is this spring thing??? - Bimmerfest - BMW Forums
Old 03-19-2008, 11:21 AM
jupitor2 jupitor2 is offline
Mein Auto: 1987 325 me, 2004 x3 wife
This is strange and I am wondering if any one else has seen this or knows about it. I was installing a trailer hitch on my 2004 x3 last weekend and noticed something strange inside the right rear spring. Laying there inside the spring at the bottom was what appeared to be a broken piece of spring. I “fished” it out and yes it was a piece of spring. A small piece about 2.5 “ in diameter, about one coil. One end was square cut and the other was a sharp point as if it had broken. It was loosely laying there. I examined the entire spring and noticed nothing broken or missing, so I checked the left spring. There was the same thing but this one is not loose and appears to be anchored to the cone shaped lower spring pad. ??? I’ve never seen anything like this? Anybody?
2004 3.0..FLAMENCO RED
Old 03-19-2008, 11:36 AM
Mystic1's Avatar
Mystic1 Mystic1 is offline
Mein Auto: '11 328xi, '09 550i
It's possible that is the pigtail at the end of the spring. But if it is, that should not break off. I would take that to BMW and see what they have to say about it.
Old 03-19-2008, 11:49 AM
Andrew*Debbie's Avatar
Andrew*Debbie Andrew*Debbie is offline
resU deretsigeR
Mein Auto: Leaf Tekna
What is the build date of your X3? We can look at the parts lists.
Maybe it is a noise suppression ground???
The models and equipment (standard and optional) illustrated in this post reflect my misunderstanding of vehicles supplied by BMW AG to the German market. In other EU member states, the truthyness of my posts may vary. Please ignore this post. Subject to change.
Old 03-19-2008, 12:02 PM
build date 4/04.
Its not the end of the spring broken off, both springs are intact
Old 03-19-2008, 12:53 PM
Mystic1's Avatar
Can you post a pic of it? If it would be the pigtail of the spring, the spring itself would still look normal from what you can see. The pigtail is just a sharp bend at the end of the spring that basically sits inside (where a shock would sit). It just seats the spring on the mount more securely and/or gives the spring a little more progressive rate.
Old 03-19-2008, 01:12 PM
doubledeclutch doubledeclutch is offline
Mein Auto: 2005 BMW X3 3.0i
Very weird
Old 03-20-2008, 05:42 AM
this is the "spring thing"
Here's a photo. Seems odd that if it is a pigtail that broke off, it happened on both left and right rear springs. Also odd that they broke off in the exact same place.
Old 03-20-2008, 06:32 AM
Mystic1's Avatar
That definately looks like the bottom of the spring. Take it into BMW and have them take care of it. Is it still under warranty? Very odd that that would break off like that.
resU deretsigeR
Forget my earlier comment. Photo changes everything. That looks like the end of a spring. Most likely that come off the spring installed in your car.
If you are still under 50,000 miles you should be able to get new springs under warranty. CPO might cover it too. Not sure.
If you are just over 50,000 miles BMW NA might pay for part of the repair if you ask.
Old 03-20-2008, 06:52 AM
Thanks for your input..I am waiting for my SA to call back. I don't disagree that is the end of a spring. However, the weird part is that it must be the broken off end of another spring(s) not the ones installed on my car. I checked the springs installed on my car and they are intact, in fact the ends of the pigtails of those springs are square cut and not snapped off in a jagged point like the pieces laying inside my springs. I'll update after its been in for service. 35,000 mi CPO with extended maintenance, good till 2010 or 100K!
Old 03-20-2008, 07:33 AM
resU deretsigeR
Possibly those are left from a spring that broke during assembly.
Spring broke so they got a new one from the bin and didn't clean up the bits before your suspension moved on down the line.
Maybe an angry worker put it there on purpose. Years ago a neighbor found a screwdriver inside their car door with a note attached. It read something like "So you finally found the rattle you rich xxxxx"
Magna Steyr isn't known for sloppy work, but anything can happen.
Keep us posted. This is interesting.
Old 03-20-2008, 07:34 AM
MJS MJS is offline
HMFIC
Mein Auto: 2002 ///M3
There have been reports of broken rear springs on E46 M3's as well. I assume the rear suspension design of the X3 is similar to the E46.
http://bimmer.roadfly.com/bmw/forums...8836350-2.html
46 & 2 just ahead of me...
Old 03-20-2008, 08:35 AM
Sonoman707 Sonoman707 is offline
Mein Auto: 2008 X3 3.0si
Possible... or more likely the spring broke after after being put into service and the dealership service center didn't clean up the bits when replacing it.
Old 03-20-2008, 09:15 AM
Mystic1's Avatar
Did you check the top mount of the spring also? It's possible it fell down into the rear mount and stayed there.
Old 03-20-2008, 09:17 AM
HT417's Avatar
HT417 HT417 is offline
Mein Auto: 2008 BMW X5 3.0si
Good possibility. Have the dealer run your VIN to see what repairs it's had.
Old 03-21-2008, 07:13 AM
Service record shows no spring replacement. Its going into the shop Monday am. I'm pulling the wheels this weekend to look at the springs again. I must admit I concentrated on the bottom half of the springs when I checked them. Perhaps it is the top pigtail that broke off and fell down. But....to have that happen to both sides and one side the broken bit was loose and the otherside is was jammed into place at the lower spring pad?????
I do enjoy a good mystery and this is a good one. Thanks all for your possible explanations. I will report on my findings after re examining the springs.
Old 03-22-2008, 08:49 AM
Mystery Solved
OK I'm a little embarrassed....Pulled both wheels to look at the springs again and contrary to what I posted earlier I found that both springs broke, on the bottom, in almost exactly the same place. The shape of the break is the same as well.
Just as MJS referenced:
Thanks all for taking part in this mystery....
Scheduled Monday for replacement under original warranty 35K, 2004...
Old 03-22-2008, 05:16 PM
Mystic1's Avatar
Glad it is getting taken care of. There is absolutely no reason that a normally driven vehicle should have this happen. Do you drive over any severely rough roads?
On a lighter note, did you have any annoying rattles you couldn't pinpoint? If so, this may be it. LOL.
Old 03-22-2008, 09:00 PM
This x3 has been driven on normal roads....since I have owned it...... I bought it in October 2007. I suspect this happened before I owned it. No noises or other symptoms. Only noticed it when I was installing a hitch last weekend!!!!
Old 11-10-2009, 10:17 AM
BJC BJC is offline
Mein Auto: 2004 X3 3.0i sport
So I was changing over to my snow wheels/tires this weekend, and found the exact same problem on my 2004 X3! Both rear springs are cracked at the end in the same way and I found one piece of spring on the left lower perch (the right one was missing). Best of all my truck is out of warranty and the dealer wants $230 per spring - plus labour!!! F*&$.
Looks like I'll be searching online and then doing some DYI spring installing... just as it's getting colder/darker out. Fun times.
Old 11-10-2009, 11:59 AM
X3-terrestrial's Avatar
X3-terrestrial X3-terrestrial is offline
Aficionado
Mein Auto: '05 X3, '02 M3, '91 E30
Not good....was the suspension doing some noise or behaving abnormal?
Old 11-10-2009, 12:39 PM
enamoured enamoured is offline
Hmm... could this be the cause of clunk I get every now and then...? I will be looking in there this evening.
http://www.bimmerfest.com/forums/sho...d.php?t=392399
(OO \ (|||) (|||) / OO)
Old 11-10-2009, 06:45 PM
b-y's Avatar
b-y b-y is offline
Mein Auto: 328xiT & M roadster
Originally Posted by BJC View Post
...Looks like I'll be searching online and then doing some DYI spring installing... just as it's getting colder/darker out. Fun times.
I'm all for DIY repairs, but not involving coil springs. You heed a high-quality spring compressor and experience. It can be a dangerous job for the inexperienced. (Don't ask how I know this.) If you don't want to pay BMW dealer shop rates, any good indie shop or frame specialist will have the right tools.
Recent ED: 25 June 10, 328xiT in Red. Then headed SW to Italy & France. Flew home via Rome. Hoegh Kobe departed 22 July; unloaded at PH 17 Aug. Redelivery 11 Sept. (Re-redelivery 14 Sept....read the details here.)
Previous ED: 7 June 08, X3 3.0si in rosso corsa (*), then off to Italy, Austria, Slovenia. (*Note: A61 Crimson Red north of the Alps.)
Back-up vehicle (while waiting for re-deliveries): 1999 M Roadster in Estoril Blue.
Old 11-10-2009, 08:15 PM
BJC BJC is offline
X3-terrestrial, enamoured: my X3 makes no weird sounds and drives just fine. The springs seem to have been broken for a long time as the tips are rusty (not a recent break). The pieces that broke off are very short and it seems like the springs broke right at the contact point with the lower spring perch - just the pic posted above.
b-y: I've assembled and installed struts in my Subaru Impreza. This looks like a fairly straightforward compress old -> pull out -> compress new -> install job, but I will do some research before I do it.
Does anyone know a good source for OEM springs?
Old 11-10-2009, 09:00 PM
minicrazy592's Avatar
minicrazy592 minicrazy592 is offline
about the mini part....
Mein Auto: E90 M-tech, E30 M-tech
Hmm I might tell my mom to check this out, she has my old X3. Build Date: 3/04
-J.T.
Will be missed: 04' E83 M54B30
