Old 12-17-2015, 09:09 AM
fratan fratan is offline
Mein Auto: 2006 750i
E65 Wheel Bearing
Has anyone had to replace a rear wheel bearing because it wasn't communicating with the speed sensor? I'm getting a bad way detection in Inpa as well as a rear wheel speed sensor. The speed sensor is new and we swapped sensors to test and no communication. Also, my new DSC module is lit when I drive 30 feet or so.
2006 750 I
Old 12-23-2015, 11:31 AM
jermariolc jermariolc is offline
Mein Auto: 750li
I had to but not because of a sensor but because it was making loud roaring noise
Old 12-23-2015, 12:57 PM
ThAnks for getting back. Had a bad speed sensor right out of the box from BMW. The main cause was a bad DSC/ABS module not a bad speed sensor.
2006 750 I
Old 12-23-2015, 01:49 PM
Mein Auto: 750li
How many D.Sc./abs modules are there?
Old 12-23-2015, 06:55 PM
Only one DSC module
2006 750 I
Old 12-23-2015, 06:58 PM
Mein Auto: 750li
Not sure what you drive but I drive 07 750li. Do you know where it located
Old 12-24-2015, 06:16 AM
See-5 See-5 is offline
Mein Auto: E66 750li
I get the Rear right speed sensor fault too, but I haven't done anything to deal with it since I am not noticing any difference in the ride.
It has been more than two years now. And I can't tell if the bearing is bad because the tires make the noise of the road, however on new roads there doesn't seem to be noise.
Old 12-24-2015, 08:27 AM
dvanlare dvanlare is online now
Mein Auto: '95 E31, '05 E66, '15 F02
Also looking for DIY
I could use a DIY as well if anyone has it. I am going to replace just because of age and a little noise. I am already doing the complete rear suspension so I might as well do this also. I found several for the front which looks relatively simple. The rear seems more complicated because you need to pull the drive flange and it looks like special tools may be required. Just trying to get some advice if something rented from Autozone or purchased from Harbor Freight can do the job.
Old 12-27-2015, 06:42 PM
I didn't think that my problem was the rear wheel bearing because usually you can hear the bad wheel bearing. I was getting a bad way detection and a faulty rear wheel speed sensor using INPA. When I checked all 4 wheels I was getting no movement from the right rear. I wouldn't replace the wheel bearing until you know the DSC and rear speed sensor are working correctly.
2006 750 I
Old 12-29-2015, 06:25 PM
chamilun chamilun is offline
Mein Auto: 2008 535 ix
I did a DIY somewhere posted here.
Wheel bearing nothing to do with any sensor FYI
Old 12-29-2015, 08:29 PM
The wheel bearing in the rear communicates with the rear speed sensor. I had just replaced the rear speed sensor so I was leaning towards a bad wheel bearing but it turned out that the speed sensor was bad out of the box.
2006 750 I
