Old 03-21-2008, 09:22 PM
estuff estuff is offline
Mein Auto: BMW 528i
Arrow P1749 Secondary Pressure Solenoid Communication Error
I am getting the check engine light with the P1749 on my 2000 528i. Does anybody know what could be wrong? I dont seem to be able to find anything on this code.
Old 03-22-2008, 09:33 AM
Bimmer_528i Bimmer_528i is offline
Mein Auto: BMW 528i
Your transmission pressure solenoid is bad.
Old 03-22-2008, 10:40 AM
Mein Auto: BMW 528i
Thank you. Do you know what part do I need to replace, or how should I go about it?
Old 03-22-2008, 10:41 AM
Mein Auto: BMW 528i
Any more info is greatly appreciated.
Old 07-30-2011, 01:58 PM
i.pharaoh i.pharaoh is offline
Mein Auto: E39-530
Exclamation P1749 pressure solenoid valve
well, maybe the valve is bad maybe not, it could also be bad connection, well on my car i had the same problem, when i diagnosed my car i got the same code, but when i clean it out, it disappears for a while and comes back after couple of driving, my doubts was (bad connection or my transmission oil need to be replaced)
anyway i checked out the connections with the valve it was good, No damaged signs of the connectors with the valve no signs of damaged wires, then decided to replace my oil transmission and no more codes no headache. car is working perfectly.
Old 07-30-2011, 05:10 PM
alarmin alarmin is offline
Mein Auto: 528i
I also had that code once. I was having alternator / battery issues as well. I replaced the alternator and the battery, cleared the code and it has not come back.
The family that rides together, stays together
